Page 19 of 20 1 2 17 18 19 20
Re: Moparts official power adder thread [Re: hemi-itis] #2765559
04/18/20 04:45 PM
04/18/20 04:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My data logger is showing me IAT's of 165* or more where my power just goes flat. I want to intercool with nitrous and a plate will not work because the throttle blade hits the crossbar at 1/3 to open.I want to install a pair of fogger nozzles in the 1 inch spacer plates.
Has anyone used juice to intercool??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Moparts official power adder thread [Re: hemi-itis] #2766910
04/21/20 09:04 PM
04/21/20 09:04 PM
hemi-itis Offline
hemi-itis  Offline
I can't be the only one shruggy
Re: Moparts official power adder thread [Re: hemi-itis] #2768909
04/27/20 11:00 PM
04/27/20 11:00 PM
hemi-itis Offline
hemi-itis  Offline
FWIW we installed the extended fogger nozzle in the carb adapter than bolts to the blower housing spraying wight into the rotors. After I get my plumbers licence I will practice social distancing with a few test hits on the empty practice no prep road. Nozzles can flow up to 175HP each,I wll put 50/60 HP under each carb.
Hope we are out and about by Carlisle in JULY work grin
Re: Moparts official power adder thread [Re: hemi-itis] #2849530
11/21/20 01:02 PM
11/21/20 01:02 PM
Reading PA
duster400 Offline
duster400  Offline
Reading PA
Monte posted this years ago.
Re: Moparts official power adder thread [Re: duster400] #2850296
11/23/20 09:40 AM
11/23/20 09:40 AM
an8sec70cuda Offline
That was the plate he built for an NMCA class that mandated a plate system if I recall correctly. It was quickly outlawed, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: an8sec70cuda] #2859932
12/14/20 04:41 PM
12/14/20 04:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's so awesome! laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: Moparts official power adder thread [Re: hemi-itis] #2886343
02/10/21 02:03 PM
02/10/21 02:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Anyone adding a power adder over the winter or turning there [censored] up ?
I found about 10mph in the 1/8 last year so I'll be changing my car setup
trying to take advantage . Hope to leave under more power and let it eat out the top end.
Re: Moparts official power adder thread [Re: FastmOp] #2886346
02/10/21 02:08 PM
02/10/21 02:08 PM
Not necessarily turning it up, but mine is definitely making more power since Induction Solutions "fixed" a problem w/ my old system. Had a bad leaking spray bar that was really screwing up the distribution. I've now been quicker and faster w/ the same amount of nitrous I used before, more delay, more ramp time, and a lot less timing. Now it's time to keep the front down and get after it!
CHIP
Re: Moparts official power adder thread [Re: an8sec70cuda] #2886373
02/10/21 03:05 PM
02/10/21 03:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I need to keep my front-end down as well. Its a good problem but I hate adding wt. But that's how I got the Valiant under control
Re: Moparts official power adder thread [Re: FastmOp] #2886441
02/10/21 05:11 PM
02/10/21 05:11 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I jetted up to the 250 shot from 200 at the last day of the season and ran a 10.01. A tick faster than the previous best of 10.33. This was with 55 lbs. in the trunk that I'm not sure we even needed so very happy with that on just the second pass with that jetting. Probably going to kill about 100 lbs. or so to get us solidly into the 9's.
'63 Dodge 330
11.19 @ 121 mph
Re: Moparts official power adder thread [Re: GY3] #2889145
02/16/21 12:14 PM
02/16/21 12:14 PM
What rpm window switch is everyone using for their nitrous systems? I've been running w/o one, but thinking I should put one in.
The little MSD 8956 only handles 1.5 amps...nowhere near what the solenoids pull.
I have a Leash progressive which uses the (-) negative side for activation, if it matters.
CHIP
Re: Moparts official power adder thread [Re: an8sec70cuda] #2889179
02/16/21 01:10 PM
02/16/21 01:10 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Yes make sure you have some window switch, nitrous on a limiter is not good as exhaust ports are usually too thin to handle combustion ( i found this out the hard way a few times) and you will crack exhaust ports and they start leaking water.....
Any way, just use the MSD rpm switch to trigger a relay that supplys your activation power thats all. Use the MSD rpm switch for the ground side of the relay
....BAD A$$ STREET CAR.....
Re: Moparts official power adder thread [Re: n20mstr] #2894784
03/02/21 12:52 PM
03/02/21 12:52 PM
Penna
70satelliteguy Offline
Penna
Thinking about this summer and some of the heads up races I will be attending. Things are getting tougher every year with the turbo guy's showing up. Used to do really well but now am first or second round fodder! Got to thinking if my stuff is still up to snuff after 10 years.
Went from a cheater kit to the Big shot upgrade(Big shot plate and super pro shot solenoid).. I notice that they still sell this upgrade but wondering if there is something better other than going to a fogger system. Maybe a newer better plate or solenoids. What got me wondering is that my tune up for 350 hp does not seem to go any faster than the 300 hp one(see attached tune up sheet). Is the Big shot plate up to the job?? This is the same even after a solenoid rebuild and cleaning plate and nozzles and hoses. System is controlled by rpm /timer off transbrake.
I am happy with the performance of the 300 shot but need to go bigger. Hoping not to have to go to 2 kits. 572 motor b body. mid 9's on motor mid to high 8's on 300 shot.
Thanks Mike
Re: Moparts official power adder thread [Re: 70satelliteguy] #2894895
03/02/21 04:39 PM
03/02/21 04:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thanks Mike
The best thing I can tell you is to send it off to Induction Solutions (regardless of brand you have) and they will flow it and make sure it is functioning correctly.
'63 Dodge 330
11.19 @ 121 mph
Re: Moparts official power adder thread [Re: 70satelliteguy] #2902378
03/24/21 01:31 PM
03/24/21 01:31 PM
N
N
Thanks Mike
probably the best plates to use will be and not in any particular order....
NX billet cross single entry
Induction Solutions Holey Moley
Nitrous outlet Stinger series
All of those plates are billet and do not use the old style brass tubes. The weakness in the older plates is the epoxy may come loose or the bars may not be clocked 100% in the proper position.
All of those plates can go from 200 to 600+ HP so most likely the last plate you may ever need. Different solenoids will different HP/PPH levels
Looking at your tune up sheet....IF you have a .116 orifice nitrous solenoid, yea its not picking up anymore over that .110 jet. You could look into a trashcan solenoid .178 orifice, but most likely you should step up to a better plate also.
Re: Moparts official power adder thread [Re: n20mstr] #2902596
03/25/21 09:01 AM
03/25/21 09:01 AM
Penna
Penna
Bought the Induction solutions Billet Saturday night special plate kit to replace my old Big shot kit. Has not arrived yet. Not sure if the plate is the Holey moley or not? Supposed to have tune up flowed with plate .
Thanks n20mstr for the reply.
Mike
Re: Moparts official power adder thread [Re: 70satelliteguy] #2932446
06/12/21 10:42 AM
06/12/21 10:42 AM
N
N
Mike
Its been a while. How has the new plate worked out for you ??
Re: Moparts official power adder thread [Re: n20mstr] #2941948
07/11/21 01:02 AM
07/11/21 01:02 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Random question for you guys. I have a mild 440 in my '68 Fury with ported 906's, 0.590 cam, flat top pistons and a TM7 intake with a 4 hole 1" spacer and an 850 DP on it.
I'm looking to spray it to get it into the mid 11's. I eventually want to fuel inject it and use a plate kit as a dry nitrous shot only and let something like a Holley Sniper control the additional fuel. I understand a ~150-200 shot should be safe on the motor as long as I use window switches and a WOT switch to keep it from activating when I don't want it to. I also understand I'll have to pull ~10 degrees of timing to keep it from detonating.
My question is what plate/kit would everyone recommend for this if I'm starting from nothing, for use with a carb for now, and then if I convert to EFI, can the wet kit be run as a dry kit only with no fuel through the fuel spray bar as long as the FI system is supplying the additional fuel?
Thanks!
Re: Moparts official power adder thread [Re: Blusmbl] #2945167
07/20/21 12:40 PM
07/20/21 12:40 PM
N
N
Thanks!
Cant beat Induction Solutions. The plates the sell now are billet, so no more delicate brass spray bars. Sat night special might be good for you. THey are a little pricey, BUT they are flowed when you get them and they offer some great tech support. I would call them. Honestly unless your car is super heavy or has the wrong converter in it, i would say your going to be in the 10's with nitrous. Have you ran it at all now on motor? and what converter is in it?
Re: Moparts official power adder thread [Re: Blusmbl] #2945169
07/20/21 12:42 PM
07/20/21 12:42 PM
N
N
Thanks!
Yes you can use a "wet" plate as a "dry" plate, just cap off the fuel side....OR add another nitrous solenoid and now you can use it as a two stage dry plate , or feed both sides (two jets) with one large nitrous solenoid and a good nitrous controlller . Plenty of options
