Re: Help an idiot fix a carb
[Re: racerlall]
#2885303
02/07/21 08:42 PM
02/07/21 08:42 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
aluminum solder like at the fair wear they stick pop cans together where do i get the aluminum solder and what do i use to melt it?
[Re: mopower440]
#2885315
02/07/21 08:58 PM
02/07/21 08:58 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Put a small nut on the end of the screw?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: mopower440]
#2885512
02/08/21 01:07 PM
02/08/21 01:07 PM
Posts: 4,768 Holland MI Ottawa
2boltmain
Holland MI Ottawa
wow! Just watched the video..never seen this before. Im assuming you have used them? If so, will this fill up the hole dense enough to when i go to drill the new hole it wont just fall back out of the old hole? I have never used the rods. I suggest lots of practice before actual repair. These rods have been around a long time under different names and sellers. I first saw this commercial on Sunday afternoon TV around 1999. This company named it Alumaloy: https://www.youtube.com/watch?v=TZ5sD9hQTyw
Keep old mopars alive.
[Re: 2boltmain]
#2885530
02/08/21 01:42 PM
02/08/21 01:42 PM
mopower440
middle Tennessee
wow! Just watched the video..never seen this before. Im assuming you have used them? If so, will this fill up the hole dense enough to when i go to drill the new hole it wont just fall back out of the old hole? I have never used the rods. I suggest lots of practice before actual repair. These rods have been around a long time under different names and sellers. I first saw this commercial on Sunday afternoon TV around 1999. This company named it Alumaloy: https://www.youtube.com/watch?v=TZ5sD9hQTyw I thougt about JB welding the hole the re-drilling and tapping a new hole, but figured that because the JB is so much softer than the carb aluminum, that the drill would just walk back over into the JB and follow the old hole..Surely these aluminum sticks would be arder than JB..?
[Re: mopower440]
#2885562
02/08/21 03:23 PM
02/08/21 03:23 PM
Posts: 13,574 md
mopars4ever
md
[Re: 3hundred]
#2885765
02/09/21 09:01 AM
02/09/21 09:01 AM
Posts: 4,713 Florida
BDW
Put a small nut on the end of the screw? The above should work, if the offset screw isn't making contact, a nut on the end would increase the surface area. You could even file/grind the nut to achieve the shape needed.
[Re: BDW]
#2885812
02/09/21 11:27 AM
02/09/21 11:27 AM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Put a small nut on the end of the screw? The above should work, if the offset screw isn't making contact, a nut on the end would increase the surface area. You could even file/grind the nut to achieve the shape needed. And, if the nut were to rub against the body of the carb, drill the hole on the right hand side of the boss. You can get another screw, put it in the original hole and cut it to fit flush so you have something to fill the hole and maintain strength in the boss. On the new screw on the right hand hole you can use the nut. If the nut is too far away you can fit an over-sized piece of metal and tap it to fit the screw. Something like this:
Mo' Farts
Moderated by "tbagger".
