Alt output question - roadrunner with AC and PW #2885189
02/07/21 04:34 PM
02/07/21 04:34 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I restored a 69 roadrunner that has factory PW and AC. I have always had an issue with windows rolling up all the way. Fronts do well but rears are mainly the issue. I know motors are working against spring rate going up.
I put it together not knowing if alt is a 37/46 or 60 amp alt. Still do not know. I know now that is should be 60 for my application.
Would an alternator of lesser amperage/output have an affect on window operation? Currently the rate going up does not change much when engine rpms are raised.
Thanks Moparts
Re: Alt output question - roadrunner with AC and PW [Re: 70mopes] #2885385
02/08/21 12:05 AM
02/08/21 12:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could try lubing the window slides etc.
Re: Alt output question - roadrunner with AC and PW [Re: 70mopes] #2885432
02/08/21 08:57 AM
02/08/21 08:57 AM
VA
dragon slayer Offline
VA
Thanks Moparts
No. Not for a motor that size. The load of the motor would have to be great enough to exceed the capacity of the alternator and cause voltage to droop. Lights dimming, etc...
Re: Alt output question - roadrunner with AC and PW [Re: dragon slayer] #2885433
02/08/21 09:06 AM
02/08/21 09:06 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
If the windows are dragging the motor will request more power from the alt/batt.
Now, you need to find the reason why they are slow, Glass dragging or motor needing service ? armature tracks and brushes into the motors could be needing a service.
ANYWAY, do it a favor yourself, get an alt able to source 45-55 amps minimun at iddle... the more, the better, but at least that. TRUST ME. The charging system ( including ammeter ) will be more relaxed
