Re: T56 / Viper / TR6060 / Magnum Tremec whatever
[Re: migsBIG]
#2884296
02/05/21 11:45 AM
02/05/21 11:45 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
That 572 must be really down on power to need 4.56's? 450 hp Vipers come with 3.07's and 6 speeds, and seem to move fairly quick. Might want to look into a supercharger to up the power on that 572 a bit and then you won't have to run them dump truck gears.
Mo' Farts
Moderated by "tbagger".
[Re: hemienvy]
#2885032
02/07/21 11:56 AM
02/07/21 11:56 AM
Posts: 619 nj
JAMESDART
nj
I put a viper t56 in my Duster like 10 years ago. Not big power buts it’s behind a 400bb with a small cam, Headers, usual stuff. The plan was to swap in a 431 but I haven’t touched it since. It’s set up as a pro touring/ cruiser. I have 3.73s with 26” tires. Sometimes id like to try 4.10. I’d also like to change the cam but I think that will also require a little more gear. The way it is now I pretty much can’t use 6th until I’m over 70 mph. I’ve beat on it but not like weekly trips to the track. When I planned it out I tried to get close to viper final drive ratio but the engines are apples to oranges kind of comparison.
[Re: hemienvy]
#2885114
02/07/21 02:11 PM
02/07/21 02:11 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Liberty Gears can set you up with a Tremec in a few different flavors depending on usage and budget . Check out their site for options and gear ratio charts. Most of these 5 or six speeds have a really deep low gear and if you go with a 4.56 first gear will be useless . I have a 3,27 low gear in my Richmond 5-speed and 5th gear is 1.1 so 3.23 or 3.54 are both good gears for a street/strip application. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hemienvy]
#2885328
02/07/21 09:33 PM
02/07/21 09:33 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I have a T56 maganum behind the 468" early hemi in my 31 Plymouth hot rod coupe. With 4.57 rear gears and 30" tires, and a 280 degrees at .050 cam, I can't even use 6th under 70 mph. But it really rolls nice down the freeway and gets really good fuel mileage.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: hemienvy]
#2885340
02/07/21 09:58 PM
02/07/21 09:58 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
On the gears, I just figured the 4.56 would work well with the .50 sixth gear OD. Plus, the more rearend gear you have, I would think the more torque you can get away with pushing through the tranny.
You might as well figure on starting out in second.
[Re: NITROUSN]
#2885347
02/07/21 10:20 PM
02/07/21 10:20 PM
Hemi_Joel
Minnesota
The choices are wide ratio at 2.97 2.10 1.46 1.00 .74 .50 or close ratio at 2.66 1.78 1.30 1.00 .80 .63
It seems to me that 1st and 6th are pretty useless on the wide ratio. So I went with the close ratio. Still 6th is too high speed unless driving on the Autobahn. I would recommend you use the close ratio, and use the 4.56 gears, or maybe ever 4.88.
Don't get it from American Powertrain, worst customer service ever.
[Re: hemienvy]
#2885351
02/07/21 10:23 PM
02/07/21 10:23 PM
Hemi_Joel
Minnesota
You'd need an RV cam to lug a .50 6th with 4.11's.
[Re: hemienvy]
#2885539
02/08/21 02:10 PM
02/08/21 02:10 PM
Hemi_Joel
Minnesota
Well how would it be with a big motor and a cam with a real wide lobe center / not much overlap ? With a big torque monster motor, it's hard to make use of 6 gears unless your trying to go 175 mph or pull a 20,000# trailer. But still 1600 rpm at 70 mph, is probably not efficient.
