498 Eagle stroker kit
#2883800
02/03/21 09:59 PM
02/03/21 09:59 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
Hey guys, I need some input on the Eagle brand stroker kits. I am building a 500-ish hp Eddy headed 400/498 motor for my ramcharger and saw this kit as I was shopping the various web stores. At 2k this seems very reasonably priced even though unbalanced. I know eagle has been around for fair amount of time, I just want to know if there is any reason to steer away from this kit. https://www.jegs.com/i/Eagle/356/21...PyXik-nbqDcqH8PFwvSEb5zZaa_oaMqXPRc1VpEwthanks
Re: 498 Eagle stroker kit
[Re: MrMayhem]
#2883832
02/03/21 11:13 PM
02/03/21 11:13 PM
Posts: 6,142 Melbourne , Australia
LA360
The crank and rods will need to be checked over for sizing. The Eagle stuff usually requires a touch up on their finishing/sizing.
Alan Jones
[Re: MrMayhem]
#2883872
02/04/21 03:22 AM
02/04/21 03:22 AM
Posts: 43,207 Bend,OR USA
Cab_Burge
Everything Eagle sells for Mopar engines is made in China and listed by them as made in the U.S.A. Did you call Ohio Crankshaft Company yet for similar parts made here in the U.S.A? It not maybe you should 800-333-7113
[Re: earlymopar]
#2883909
02/04/21 09:31 AM
02/04/21 09:31 AM
Posts: 10,030 MN
JERICOGTX
MN
I've had a Eagle crank and rods since 2003. If I were to buy now, and I just did, I'd look at a kit through Molnar.
69 GTX
68 Road Runner
[Re: MrMayhem]
#2883922
02/04/21 10:21 AM
02/04/21 10:21 AM
Posts: 12,131 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just out of curiosity, why would you buy an unbalanced kit?
I'll throw in another vote for Ohio Crank.
Master, again and still
[Re: DaveRS23]
#2883944
02/04/21 11:10 AM
02/04/21 11:10 AM
Posts: 143 North America
kwikblownhemi
North America
Just out of curiosity, why would you buy an unbalanced kit? Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed.
[Re: MrMayhem]
#2883970
02/04/21 12:59 PM
02/04/21 12:59 PM
Posts: 1,992 Apollo, PA.
B1MAXX
Apollo, PA.
They (Ohio)can whip you up anything you want. B-series mains are an option. Call them, see how much one of their kits would be in b-series.
[Re: DoubleD]
#2884001
02/04/21 01:58 PM
02/04/21 01:58 PM
Posts: 3,023 NY
B1duster
NY
[Re: tubtar]
#2884006
02/04/21 02:05 PM
02/04/21 02:05 PM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
After the machine shop corrects everything , they aren't the bargain they appear to be. That is not saying they are junk , but like anything else , you get what you pay for. They're decent parts, it's just that the finish machining usually isn't very good. Don't be surprised if your brand new Eagle crank needs to be turned .010/.010 to correct it. Same goes for the rods. The ones I've seen had the caps cut tapered inward...had to be resized to fix them. Once that's done you have decent parts, but now look at the money you have tied up in them. Molnar seems to have MUCH better quality for a similar price.
[Re: B1MAXX]
#2884029
02/04/21 02:40 PM
02/04/21 02:40 PM
Cab_Burge
[Re: kwikblownhemi]
#2884120
02/04/21 07:50 PM
02/04/21 07:50 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just out of curiosity, why would you buy an unbalanced kit? Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed. Frankly, I have never shopped for stroker kits by looking for the lowest price. Recommendations here and other places played a big role, along with the parts descriptions and finally, the way the salesman spoke on the phone. Some shops just didn't have time to answer the questions. Then, as long as the price was not out of line with their competitors, it becomes an easy decision. Consequently, the only companies that I have ever used have been Ohio Crank for my wedges and Ray Barton for the Hemi. I always have a local shop check it all. Everything has always checked out good. Ohio Crank even helps me calculate the comp ratio I am shooting for and machine the pistons to get there. I still have that first 499 engine that I built with an Ohio kit. It's probably 10 years old now and has had a lot of abuse including hurting it a time or two. $600 for balancing or parts in their original packaging would not fly with me, either. But I have not experienced those issues with Ohio or Barton. Knock on wood.
[Re: MrMayhem]
#2884402
02/05/21 04:29 PM
02/05/21 04:29 PM
Posts: 31,045 Oregon
AndyF
Hey guys, I need some input on the Eagle brand stroker kits. I am building a 500-ish hp Eddy headed 400/498 motor for my ramcharger and saw this kit as I was shopping the various web stores. At 2k this seems very reasonably priced even though unbalanced. I know eagle has been around for fair amount of time, I just want to know if there is any reason to steer away from this kit. https://www.jegs.com/i/Eagle/356/21...PyXik-nbqDcqH8PFwvSEb5zZaa_oaMqXPRc1VpEwthanks 'I've never used Eagle stuff and have no intention of ever using it but there are plenty of people who do use Eagle parts and their engines stay together. So take that for whatever it is worth. If I'm going to build a "budget" engine for someone then I'll typically use Molnar crank and rods and try to find a shelf piston that matches the compression ratio that they want. SCAT is also pretty good and I've used 440Source kits. I've used K1 before as well but Molnar seems to me to have the nicest parts in the "budget" category. The fact that I can buy at dealer pricing from him helps a bunch too. If a customer wants a serious engine then I step up to the "good" stuff. The Molnar parts work up past 700 or 800 hp but I wouldn't build a guy a 1000 hp engine using Molnar parts. Tom might disagree of course.
[Re: DaveRS23]
#2884405
02/05/21 04:42 PM
02/05/21 04:42 PM
kwikblownhemi
North America
Just out of curiosity, why would you buy an unbalanced kit? Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed. Frankly, I have never shopped for stroker kits by looking for the lowest price. $600 for balancing or parts in their original packaging would not fly with me, either. But I have not experienced those issues with Ohio or Barton. Knock on wood. Neither have I. This one didn''t come from either of those two. Anyone who knows Hemis would have not expected it. I didn't.
[Re: Cab_Burge]
#2884493
02/05/21 08:20 PM
02/05/21 08:20 PM
Posts: 3,081 Michigan
A727Tflite
Does a Molnar crank and rods with CP pistons count? I'm not sure which part fail first yet, block or piston But it wasn't the rods or crank though Yes it counts - in my book. Seems, looking at past posts, guys here argue that horsepower is not a factor in rod failure, more along the lines of engine speed and piston weight. Yet it still gets thrown in the discussions. Molnar explained rod failure and how to arrive at the conclusion that the engine broke the rod/s due to over speed.
[Re: A727Tflite]
#2884541
02/05/21 09:59 PM
02/05/21 09:59 PM
Posts: 2,047 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I bought Ohio Crankshaft H-beam rods about 8 years ago, thinking they had the best deal going. I saved a few $$'s on the cost, but then it cost me quite a bit more before I was able to use them. Pins would not even fit into the bushing, had to have them fitted at the machine shop. Then I find the big end is not round. I had ordered the ARP 2000 bolts as an option, but it looked like they just changed the bolts out. When I torqued the bolts to the lower torque (for 8740 bolts), the big end was round, but when torqued them to the higher 2000 spec, they were egg shaped. Back to the machine shop, more $$'s. When I checked the balance on them, 4 of them had to be corrected. After all that, they were pretty good parts. The last two sets of H-beam rods that I bought were Molnar. Out of the box, the pins fit correctly, the big ends were round and all 8 rods were weight matched perfectly, both ends. Clean them and use them. You get what you pay for.
Brian Dunnigan
