Vehicle Ratchet Strap Recommendations Wanted #2882861
02/01/21 06:40 PM
02/01/21 06:40 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking to purchase a set of (4) ratchet straps for a vehicle trailer and came across the wire hook style for a decent price. However, I'm concerned with the open hook compared with the snap/latch hook style. Interested what type/brand the forum is using to transport their Mopar vehicle(s).
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2882869
02/01/21 06:57 PM
02/01/21 06:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Those pictured look like the HF cheap nylon stuff.
Best ones are Mac's Tiedowns.
I don't like the open hook style for a car, myself.
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: topside] #2882892
02/01/21 08:09 PM
02/01/21 08:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have used MACS brand for years. I used to change out the straps every 4 years, but have used these are so well made that I have been using my last couple of sets for the last 12 years with no issues. Like always, if they get burned on hot exhaust, get cut, or start to unravel the stitching I replace them. https://www.macscustomtiedowns.com/
JB Rhinehart, Realist
A-Body's RULE!
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: Rhinodart] #2882901
02/01/21 08:32 PM
02/01/21 08:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have used the ones at the top in the picture forever
Never had an issue
Think they are all made out if nylon. As long as you dont let them rub on anything and fray, they aren't going anywhere. Most are rated well higher than what they are used for
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2882907
02/01/21 08:40 PM
02/01/21 08:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Another vote for Mac's, I love mine.
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2882913
02/01/21 08:51 PM
02/01/21 08:51 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive used the top ones for close to 20 years , never once had an issue.
I used them with some over the axle straps ( 2 straps each end )
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: Alaskan_TA] #2882914
02/01/21 08:52 PM
02/01/21 08:52 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
If your looking for a very decent buy in, check out Husky from home depot- they have a 3300lb rating, $10 a pop and are quite rugged.
Kinedyne are also very nice, strong straps. But they are more$$$
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: B3422W5] #2882954
02/01/21 10:41 PM
02/01/21 10:41 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Never had an issue
iagree
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2882960
02/01/21 11:03 PM
02/01/21 11:03 PM
I have some surplus military cargo straps rated at 5000 Lbs. each that have the closed latch on both ends, I do use axle straps on the car over the rear axle and the tie down loops welded on the front of my S/P cars front rack and pinion mounting bar. I use four of them on my cars, one on each corner up
I've had these straps for over 20+ yrs. and they have been used on a bunch of different cars back when I first used a open trailer, then 4 different trucks and 3 different enclosed car trailers since then, they work really great, I try and stop after one hour towing when I'm going to a race more than 200 miles away and retighten the rear straps after they have stretch and settled in. If I don't they will have a little slack, not a bunch, in them when i get to the races more than 100 miles away shruggy
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2883042
02/02/21 10:53 AM
02/02/21 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Like many have said, talk to Mac, they will give you a safe recommendation and sell you a quality product.
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: Ramrod39] #2883058
02/02/21 11:27 AM
02/02/21 11:27 AM
an8sec70cuda Offline
Never had an issue
iagree
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: 340Cuda] #2883059
02/02/21 11:30 AM
02/02/21 11:30 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: shanker] #2883191
02/02/21 04:47 PM
02/02/21 04:47 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is not the exact brand I have but it is the style.
Chain End Tie Down
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: vinnyd76] #2883294
02/02/21 09:12 PM
02/02/21 09:12 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Mac's with with integrated axle straps
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: 6PakBee] #2883303
02/02/21 09:28 PM
02/02/21 09:28 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I have the style that the OP shows in the first picture: bad setup, this might be tough to visualize, but, the hook makes me nervous because it likes to "climb" off whatever edge you put it on. I don't recommend them at all. I've used the style with the "flattened" hook and they are much more secure.
Chain End Tie Down
Now that's more like it, those would work on anything. I will definitely be buying a set of those. THANK YOU for recommending! beer
Mo' Farts
Moderated by "tbagger".
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: Grizzly] #2883378
02/03/21 12:00 AM
02/03/21 12:00 AM
5thAve Offline
5thAve  Offline
I've only ever had a problem with one kind of the round open hook style and it was because of the way that particular set was bent. I've found they hook better onto the trailer especially if you have to go to the sides and not the rings for whatever reason but the closed hook style feels safer on the rings and axle straps.
Re: Vehicle Ratchet Strap Recommendations Wanted [Re: 5thAve] #2883426
02/03/21 08:47 AM
02/03/21 08:47 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Maybe they were linked here but My Dad has some straps for his trailer that are the flat hook with the "locking tab" and they basically have an axle strap built into them and hook back onto themselves. They work great.
68 Barracuda Formula S 340
Summit [Re: Bad340fish] #2884601
02/06/21 05:22 AM
02/06/21 05:22 AM
Direct Enclosed Transporter
Trulyvintage Offline
Summit Racing Straps twocents
Been using them for years
@ https://www.summitracing.com/parts/sum-g7950
Jim drive
1967 Plymouth Belvedere in my trailer now
Picked up Wednesday in Northern Iowa
On it’s way to California
Secured by Summit straps up
