Repl. Crankcase Breather (was 3 nipple) #2882645
01/31/21 11:35 PM
01/31/21 11:35 PM
N. Calif
rantonio Offline OP
rantonio  Offline OP
N. Calif
Hi Guys,
I have a 360 in my 1970 Barracuda. It has stock valve covers and a triple nipple crankcase breather. I want to replace the valve covers with something to dress up the engine. I am looking for a crankcase breather that has at least one nipple for the fuel tank vapor line and fits into the typical 1 inch ID grommet on aftermarket valve covers. Or is the answer to find a chrome triple nipple breather?
Thanks!
.rob.
Re: Repl. Crankcase Breather (was 3 nipple) [Re: rantonio] #2882653
02/01/21 12:41 AM
02/01/21 12:41 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Don't forget you will also need a pcv on the other valve cover. So the breather also needs a way to pull air in.
Re: Repl. Crankcase Breather (was 3 nipple) [Re: stumpy] #2882657
02/01/21 01:28 AM
02/01/21 01:28 AM
WA
tman Offline
tman  Offline
WA
Re: Repl. Crankcase Breather (was 3 nipple) [Re: stumpy] #2882712
02/01/21 11:10 AM
02/01/21 11:10 AM
N. Calif
rantonio Offline OP
rantonio  Offline OP
N. Calif
Yep, I figure I need to keep the PCV valve. I was looking for a nice looking breather with one nipple.
Thanks!
.rob.
Re: Repl. Crankcase Breather (was 3 nipple) [Re: tman] #2882714
02/01/21 11:16 AM
02/01/21 11:16 AM
N. Calif
rantonio Offline OP
rantonio  Offline OP
N. Calif
Hi,
I guess what I was look for is something that looks like this:
https://www.jegs.com/i/JEGS/555/50382/10002/-1
but with a nipple for the fuel tank line. Then I can run the PCV in one valve cover and remove the breather and fill through the second valve cover.
Does anyone make such a beast?
.rob.
Re: Repl. Crankcase Breather (was 3 nipple) [Re: rantonio] #2882717
02/01/21 11:28 AM
02/01/21 11:28 AM
md
mopars4ever Offline
mopars4ever  Offline
md
maybe something like this? https://www.ebay.com/itm/401900706565
Re: Repl. Crankcase Breather (was 3 nipple) [Re: mopars4ever] #2882966
02/01/21 11:40 PM
02/01/21 11:40 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i had a 71 sweptline 318 factory air 4spd,it had a multi nipple breather cap on the passenger side
my ladder of success is missing some rungs
