Page 1 of 3 1 2 3
Best Starter for high compression Big Block #2882051
01/30/21 02:21 PM
01/30/21 02:21 PM
WNY
Moparrob68 Offline OP
WNY
Have been using a good old Mopar mini starter for years in a 13 to1 compression 440 with locked dist. Starts great cold but when hot sometimes takes a couple tries cranking over with the starter then hitting the ign.Tried start retard in the 7AL3 and it kicked back badly. Never got around to phasing the rotor. Building a 493 with 14.5 to 1 comp this year.Wondering if the Powermaster XS Denso, Ultra Torque Hitachi or MSD starters would be a big improvement over the old Mopar mini starter.
Re: Best Starter for high compression Big Block [Re: Moparrob68] #2882071
01/30/21 03:23 PM
01/30/21 03:23 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I run the powermaster ultra in my 604" 16.5to 1 predator motor with 0 issues would highly recomend, the mopar (hitachi) starter will def.turn your motor over faster than the ultra (denzo )style, a 16 v battery will cure this.. your feeling rich Meziere builds from what im told is the best starter for mopar combos
Re: Best Starter for high compression Big Block [Re: boatracer572] #2882083
01/30/21 03:44 PM
01/30/21 03:44 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
MSD is junk , I have one and it's no better than a stock mini starter.. Just my 2Cents
6.50 @105.26
Re: Best Starter for high compression Big Block [Re: Kindafast] #2882095
01/30/21 04:50 PM
01/30/21 04:50 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Powermaster 9523 works very good. It's "clockable", and if you put a 16v battery in, it will turn a large (552 ci), high compression engine (14:1) over like it doesn't have spark plugs in it. I did have to trim a small corner of the aluminum clockable portion off
of the starter to clear on a mega block.
Brian
Re: Best Starter for high compression Big Block [Re: '72CudaRacer] #2882125
01/30/21 07:10 PM
01/30/21 07:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Just use an ignition run switch.
My 13.0:1 SB, locked @ 36, uses a stock Mopar starter & that works fine.
Re: Best Starter for high compression Big Block [Re: Moparrob68] #2882127
01/30/21 07:14 PM
01/30/21 07:14 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have been using just a stock chrysler mini starter for many years no issues, current engine is a 540 with 13 to 1 compression, locked distributor, I have a 16 volt battery. But if you retarded the timing with an MSD box and it kicked back something is wrong. If you have a crank trigger, the rotor phase needs to be done just to make sure it runs right, if the box retarded the timing and it kicked back due to improper rotor phase, then you must be very close to being off just to run the engine. One thing on rotor phasing the shorter the gap has to jump in the distributor, the more voltage is left for the spark plugs to fire, if the phase is off you may be losing voltage at the plugs.
I use the MSD digital 6 box, it retards the timing 20 degrees for starting, hot or cold it always starts, no kick back, unless the battery is low, I don't run an alternator on my car.
Re: Best Starter for high compression Big Block [Re: jwb123] #2882152
01/30/21 08:18 PM
01/30/21 08:18 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Meziere.....
Re: Best Starter for high compression Big Block [Re: jim sciortino] #2882294
01/31/21 09:22 AM
01/31/21 09:22 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted by jim sciortino
Meziere.....
I agree. My Meziere would spin my Hemi over as if the plugs were out.
2011 Drag Pak Challenger
Re: Best Starter for high compression Big Block [Re: jim sciortino] #2882295
01/31/21 09:22 AM
01/31/21 09:22 AM
pa
572charger Offline
572charger  Offline
pa
1989 dodge dakota mini starter in mine for 20 yrs 600 cuin hemi !!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Best Starter for high compression Big Block [Re: 572charger] #2882296
01/31/21 09:33 AM
01/31/21 09:33 AM
In a yard what is the best yr/make mini to ask for?
Re: Best Starter for high compression Big Block [Re: RapidRobert] #2882312
01/31/21 10:25 AM
01/31/21 10:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Factory mini starter with one XS 16 volt. 15-1, 572, 34 degrees crank trigger, ignition on, no retard. The key is 16 volt. Previously ran two 12 volt. The single 16 volt is WAY BETTER. Same starter 8 years, 700+ passes.
Doug
Re: Best Starter for high compression Big Block [Re: dvw] #2882314
01/31/21 10:36 AM
01/31/21 10:36 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Well in the last 20 years I have not killed one....Always kept a spare,,,,This year, I went thru two of them.....So I bought one of these high torque race units....I can let you know in a week or two
https://www.manciniracing.com/poxschstwica.html
Re: Best Starter for high compression Big Block [Re: Moparrob68] #2882492
01/31/21 05:21 PM
01/31/21 05:21 PM
WA
JD Dart Offline
JD Dart  Offline
WA
This is the one I've been using for the last 4 years after 7-8 mini starters finally stepped up couldn't be happier.
Powermaster 9413 - Powermaster Ultra Torque Starters
https://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=9413
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Best Starter for high compression Big Block [Re: JD Dart] #2882497
01/31/21 05:31 PM
01/31/21 05:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a Powermaster on the 605 and a Meziere on the 655. Dont buy MSD its just offshore junk since the Holley takeover.
Re: Best Starter for high compression Big Block [Re: Al_Alguire] #2882546
01/31/21 07:40 PM
01/31/21 07:40 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
The problem with Meziere is its longer and you will need custom headers.
And if you don't locate the little 5mm Allen works, the 2 pieces come apart and it's a bear to get out and back in.
And off the shelf headers such as hooked and this won't work.
Re: Best Starter for high compression Big Block [Re: Sammy] #2882702
02/01/21 09:38 AM
02/01/21 09:38 AM
an8sec70cuda Offline
I've had the MP mini starters on 2 cars for years w/ no issues. One is a 10:1 440 and the other is my 11:1 575" hemi.
I have a standard stock replacement mini starter off a '90 something model truck on a 14:1 440 for a long time w/ no trouble either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best Starter for high compression Big Block [Re: an8sec70cuda] #2882706
02/01/21 10:09 AM
02/01/21 10:09 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
My TTI headers are extremely tight fit in starter area , I had to buy a clock able one , gained just a tiny amount to make it fit
https://www.jegs.com/i/Powermaster/...uj-7I7gIVqvLACh2bxgcfEAQYBCABEgLDxfD_BwE
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Best Starter for high compression Big Block [Re: Moparrob68] #2882710
02/01/21 10:42 AM
02/01/21 10:42 AM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
I was just looking into this same thing. I have read some decent things about the RobbMC starters as they have clockable solenoid as well. Don't have any experience with it though sorry. I will be making the same decision soon, so will be following this thread.
Re: Best Starter for high compression Big Block [Re: Moparrob68] #2882734
02/01/21 12:40 PM
02/01/21 12:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stock V-8 Dakota starter....
Re: Best Starter for high compression Big Block [Re: Thumperdart] #2882758
02/01/21 01:48 PM
02/01/21 01:48 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Not to try and hack this post , but I hear about the 16Volt batteries. How would that voltage effect 12 Volt wiring and lights ?? I have always stayed away from 16 volt stuff from lack of knowledge about it..
6.50 @105.26
Page 1 of 3 1 2 3
