Re: 70 RR - Please help with Broadcast Sheet Decode on Wheels
[Re: Alaskan_TA]
#2882240
01/30/21 11:45 PM
01/30/21 11:45 PM
Posts: 581 Texas
Texican
Texas
Also see the wheels sections on line 4, does it show a paint code that matches the body color or TX9 for black if the body is not black?
Right after that is also the box for wheel covers / caps. Thanks Barry ~ Here is the info: Wheels Color: EB5 (Matches exterior paint) Wheel Cover: 88 This is a 70 R Code RR Coupe / 4-speed. When I got it, it had Rallye Rims. Thanks,
[Re: 6bblgt]
#2882245
01/31/21 12:01 AM
01/31/21 12:01 AM
Posts: 581 Texas
Texican
Texas
it originally had EB5 painted steel wheels (14x6.0" or 15x7.0") & the stainless steel "PLYMOUTH DIVISION" hub caps #2944088
what tires did it have? second line under "T - U - W" Thank You ! Tire Section: U84
[Re: Texican]
#2882246
01/31/21 12:04 AM
01/31/21 12:04 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
so, F60-15 RWL Goodyear Polyglas GTs mounted on 15x7.0" EB5 painted steel wheels #2944 450 - begs the question ...... what engine? 1970 RR US shipments:around 20% (<3,000 cars) of the 1970 Road Runner coupes were factory equipped with painted wheels & hub caps (STANDARD) around 400 1970 Road Runner coupes were factory equipped the F60-15s OPTIONAL ~$63.25
[Re: 6bblgt]
#2882247
01/31/21 12:07 AM
01/31/21 12:07 AM
Posts: 581 Texas
Texican
Texas
so, F60-15 RWL Goodyear Polyglas GTs mounted on 15x7.0" EB5 painted steel wheels - begs the question ...... what engine? Thank You Again. Engine: Elephant
[Re: 6bblgt]
#2882252
01/31/21 12:30 AM
01/31/21 12:30 AM
Posts: 581 Texas
Texican
Texas
so, F60-15 RWL Goodyear Polyglas GTs mounted on 15x7.0" EB5 painted steel wheels #2944 450 - begs the question ...... what engine? 1970 RR US shipments:around 20% (<3,000 cars) of the 1970 Road Runner coupes were factory equipped with painted wheels & hub caps (STANDARD) around 400 1970 Road Runner coupes were factory equipped the F60-15s OPTIONAL ~$63.25 I appreciate the info ! Thank You Very Much.
[Re: Texican]
#2882253
01/31/21 12:38 AM
01/31/21 12:38 AM
6bblgt
Las Vegas, NV
the typical 1970 Road Runner coupe has ~$600 worth of OPTIONs the $841 HEMI helps to push your Road Runner coupe OPTION total north of $1500!! got any pics of the car?
