I need more brake help #288210
04/14/09 12:14 PM
04/14/09 12:14 PM
Killen, Al
dbc105 Offline OP
dbc105  Offline OP
Killen, Al
I am planning on a disc conversion a little later on but I need to replace my master cylinder(M/C) now. I have a '68 Satellite with power drums. I would like to go ahead and upgrade the M/C to a disc brake M/C. Can I do this? is the lack of a residual valve in the front brake circuit going to cause me trouble? has anyone done this before? also, is it possible to remove the residual value from the M/C I have now and install it in the new M/C?
DC
Re: I need more brake help [Re: dbc105] #288211
04/14/09 12:43 PM
04/14/09 12:43 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
You need to use a disk master cylinder with disk brakes and a drum master cylinder with drum brakes. You might want to speed up your disk brake conversion as a result. Visit your local wrecking yard and find some M-bodies and you'll have almost all the parts you need.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
