Diesel cab vs. gas cab #2877422
01/20/21 05:19 PM
01/20/21 05:19 PM
Greenville, PA
redraptor Offline OP
Greenville, PA
I've been offered a 92 D250 12v 5spd 190k mile 4wd truck with no useable body panels (rust) except for the core support and hood. I see gas trucks local to me including a '91 D350 dump and wonder what works and what don't for swapping cabs onto the 250 cummins chassis. I think the 250 frame is salvageable as most gas 350's here are 2wd. Anyone got experience? wrench
Re: Diesel cab vs. gas cab [Re: redraptor] #2877548
01/20/21 09:16 PM
01/20/21 09:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The cabs are a direct bolt on. Diesel to gas wiring is different as well as some cluster items. So plan on gutting both cabs and using most of the diesel items in the gas cab. The 4wd has a floor hump you will need to cut out and fit into the 2wd cab. I assume you are going 4wd.
Re: Diesel cab vs. gas cab [Re: redraptor] #2877554
01/20/21 09:22 PM
01/20/21 09:22 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I would say there is no appreciable difference... I did a Cummins swap into a '80 cab from a '92 cab on a '83 chassis and the only thing I needed to change was the bulkhead opening and the heater box opening ( that was the difference between the '80 and '83 cab). Other than that I swapped the entire pedal assembly, elec. harness...everything straight bolt in. So a '92 to a 91 cab should be effortless.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Diesel cab vs. gas cab [Re: W.I.N. Racing] #2877725
01/21/21 09:52 AM
01/21/21 09:52 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
If the floor hump in the donor cab is different just reuse the hump from the diesel cab.
1981 Dodge D150 360 auto
Re: Diesel cab vs. gas cab [Re: basketcase] #2877756
01/21/21 10:59 AM
01/21/21 10:59 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That is a cut and weld not a bolt in.
Re: Diesel cab vs. gas cab [Re: NITROUSN] #2878006
01/21/21 06:49 PM
01/21/21 06:49 PM
Greenville, PA
Greenville, PA
That's what I thought. Outwardly the dashboard doesn't look much different than gas truck but I don't know. I know that the humps are different and I've done that before on my mud truck. This is a ton of work and have done it in the past. The only reason I'm considering this is it's a 2 owner truck and I know both owners. Never owned a diesel truck so I want to tinker.
Re: Diesel cab vs. gas cab [Re: redraptor] #2878074
01/21/21 09:07 PM
01/21/21 09:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The dashboard itself is the same. All the wiring and some of the other cluster and warning lights are diesel along with 4wd lights. With the steering column out along with the cluster, radio, and misc. The wiring harness should go in somewhat painless.
Re: Diesel cab vs. gas cab [Re: NITROUSN] #2878611
01/22/21 09:17 PM
01/22/21 09:17 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
it may be more work but I think you'll end up with a better truck if you consider the diesel a donor.
If the 91 dump is clean, I'd put the diesel in it rather then swap bodies and fix frames. Most of the holes are in the rails for the 4wd parts to go into.
Angry white pureblood male
Re: Diesel cab vs. gas cab [Re: ruderunner] #2878684
01/22/21 11:32 PM
01/22/21 11:32 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just so I'm clear, you're saying 4 wheel drive into a 2 wheel drive chassis is mostly a bolt in?
I know we're discussing 250 and 350 trucks so would the same be true for a 150?
Kevin
Re: Diesel cab vs. gas cab [Re: ruderunner] #2878757
01/23/21 07:38 AM
01/23/21 07:38 AM
Greenville, PA
Greenville, PA
Buried somewhere here is a thread on doing that conversion and it didn't sound easy. There's something different about the front besides the strut rod brace.
Re: Diesel cab vs. gas cab [Re: redraptor] #2878832
01/23/21 11:57 AM
01/23/21 11:57 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Converting a frame is not easily done. Better off having a good frame for the application and transfer over all the parts.
Re: Diesel cab vs. gas cab [Re: redraptor] #2879554
01/24/21 07:16 PM
01/24/21 07:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
To the best of my research, the only holes not present on a 2wd frame are for the shackles. Applies to all weight classes of D and W trucks.
Note, there's a big difference in steering design in the late 70s that makes the donor choice more important.
I'll be doing this swap next winter on my D250. I'm currently rebuilding a Dana 60 axle, have springs and mounts to freshen, picking up transmission parts tomorrow. If you have a complete donor truck it's much easier, I've gathered parts from various junkers over the years. There's plenty of parts that get changed, biggest bugaboo is cutting all the factory rivets.
There's a fellow on Cumminsforum who has done enough conversions that he can do them in 2 weekends.
Re: Diesel cab vs. gas cab [Re: NITROUSN] #2880838
01/27/21 11:42 AM
01/27/21 11:42 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
yes it is.not a hard thing to do.
Re: Diesel cab vs. gas cab [Re: basketcase] #2881055
01/27/21 07:23 PM
01/27/21 07:23 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Cut for sure, but I don't see any reason why it has to be welded.
