'01 Dakota 3.9 has no reverse...
#2880862
01/27/21 12:36 PM
01/27/21 12:36 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Son found a clean '01 w/ 130k miles on it with no reverse but supposedly normal operation in forward gears. Simple fix or overhaul? As usual for me, search is no help. Thanks Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: '01 Dakota 3.9 has no reverse...
[Re: NITROUSN]
#2880920
01/27/21 02:34 PM
01/27/21 02:34 PM
Posts: 19,499 north of coder
moparx
one time, i had a 727 in a chrysler that had no reverse because when the previous owner adjusted the bands, somehow the band strut fell out, loosing reverse. put the strut back in, and all was well for thousands of miles afterwards. having the 3.9 engine, however, suggests there may be a 904 variant behind it, and i remember lots of stories about the band anchor spot welds breaking from the band, causing the "no reverse" symptom. in this case, the transmission definitely needs to come out. unless you always park so you don't need to back up..........
[Re: topside]
#2880995
01/27/21 05:28 PM
01/27/21 05:28 PM
I_bleed_MOPAR
Buford, GA
Thanks. Now that moparx mentioned it, I recall hearing that about the welds also. He found a '98 w/ a 5.2 we,re going to go look at. He would prefer the 5.2 over the 3.9 and the guy wants too much for the '01 w/ a trans problem anyway. Thanks again. Tim
[Re: I_bleed_MOPAR]
#2881137
01/27/21 11:36 PM
01/27/21 11:36 PM
Posts: 954 garnett kansas
rhad
garnett kansas
as i recall if the adjustment gets to loose the servo piston can pop out of the housing,it can be put back in the car,but,it means the band is most likely worn very thin
my ladder of success is missing some rungs
[Re: 383man]
#2881443
01/28/21 07:31 PM
01/28/21 07:31 PM
I_bleed_MOPAR
Buford, GA
Thanks, Ron. It was a truck for sale and he passed on it. Bought a '98 Club Cab with a 5.2 today. Very clean truck. Identical to his first Dakota after he graduated HS. Tim
[Re: 383man]
#2881764
01/29/21 03:51 PM
01/29/21 03:51 PM
Posts: 3,089 Michigan
A727Tflite
See if it has eng braking in low. If it does not then the low/reverse band is not working. If its the overdrive trans it can also have a problem in the overdrive that can also give no reverse. Ron Ron, PM sent
