Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880409
01/26/21 01:41 PM
01/26/21 01:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So... all new cars run hot for the first 500 miles...
Rubbish.
Boffin Emeritus
Re: Anybody else ever heard of this nonsense [Re: polyspheric] #2880685
01/26/21 10:36 PM
01/26/21 10:36 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Rubbish.
Tech department probably has a weekly contest for who can come up with the most retarded excuse to get a customer off the phone.
Kevin
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880689
01/26/21 10:44 PM
01/26/21 10:44 PM
NY
B1duster Offline
B1duster  Offline
NY
At least he’s getting some use out of it before it seizes up
Re: Anybody else ever heard of this nonsense [Re: B1duster] #2880816
01/27/21 10:58 AM
01/27/21 10:58 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well BTU's are heat/power, it has to come from somewhere, we know the approx mass of the engine assembly, it's reported 30F hotter, we should be able to back of the napkin figure out the HP that should be gained by the reduction of new engine break in friction causing heat gain, and see if motor improves its HP output on the first 500? miles break in. If Hp does not go up proportionally, everything else being equal, myth busted IMO.
1 btu/h = 0.00039 hp
Re: Anybody else ever heard of this nonsense [Re: jcc] #2880843
01/27/21 12:08 PM
01/27/21 12:08 PM
Washington
madscientist Offline
Washington
First off, the myth of slowing down coolant flow to keep the coolant in the radiator so it can “cool” is wrong. It has always been wrong and will continue to be wrong.
I read that guys post and I didn’t say much. It gets tiring saying the same [censored] over and over and over and it seems no one learns.
The longer the coolant stays in radiator, the longer it stays in the block. The longer it stays in the block, the hotter it gets.
Engine temperature control is about FLOW. Air FLOW and coolant FLOW.
Slowing the coolant down is ass backwards. You need a thermostat to set the LOWEST coolant temperature, not to set the maximum coolant temp.
If we can’t get that right, we can never control engine temperature.
Re: Anybody else ever heard of this nonsense [Re: madscientist] #2880929
01/27/21 03:01 PM
01/27/21 03:01 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I wouldn't want it to run at 190. That's too hot for me and completely unnecessary. Modern engines are run hot for one reason, emissions.
Air flow, fan configuration, coolant flow, tune up including lean, water pump, 4 corner coolant flow on the intake, etc.
Re: Anybody else ever heard of this nonsense [Re: CMcAllister] #2881284
01/28/21 02:02 PM
01/28/21 02:02 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Besides slowing down the coolant flow, he should put some perforated metal sheet in front of the radiator to slow down the air flow, so it has more time to cool off the water... work
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
