If you were building a engine for ......... #2879667
01/24/21 10:46 PM
01/24/21 10:46 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
A mid-late 80's pick up cruiser. I have enough stuff to build a 340 or a 408. The truck would have air and be used for (some) daily driving, cruising and occasionally towing my 18' aluminum boat. Most likely I'll run a hydraulic flat tappet but may consider a hydraulic roller, nothing wild, just something that will make good power and not need a very loose converter. The truck would start with either a 904 or 727 and later maybe a 93 or so overdrive transmission. Gears would be either 3.21 or 3.55's. Initally I'll run a carb but would like to try fuel injection after everything is sorted out. Either engine will need new pistons as my Edelbrocks have been milled to 55cc. The 340 was 11.4-1 and the 408 was 10.8-1 with these heads and a Fel-Pro 1008. The heads flow in the mid 290's.
So, what would you guys build?
Re: If you were building a engine for ......... [Re: justinp61] #2879724
01/25/21 01:17 AM
01/25/21 01:17 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have built and dynoed several 360, 410 low compression, small hydraulic cam engines for muscle cars and street rods, all made right at 400HP and idled with 16 inches or more of vacuum. Build the stroker. I would not waste a 340 block, I would use a lot cheaper 360, just me. I do a little hand porting to the heads, and usually some better valves.
Re: If you were building a engine for ......... [Re: jwb123] #2880071
01/25/21 06:48 PM
01/25/21 06:48 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yep get a 360 ad a 4 " crank for a truck !
Re: If you were building a engine for ......... [Re: calrobb2000] #2880089
01/25/21 07:09 PM
01/25/21 07:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cruise & tow RPM will help with cam selection, but a stroked 360 sounds best for that.
Did a 406" 360 for my 74 Duster. Cast crank & pistons, 340 rods, 9.5:1 CR, Thermoquad on Eddy Performer, iron 360 heads, pre-existing cheap headers, 8-qt pan & tray.
AT, AC car with 3.21s, 275/60R15s (28" tall), street car for city & highway.
Engle hyd FT with 214/224 @ .050 and .470/.504 lift, on 110 IIRC.
Great street manners, plenty of torque, ran strong & pulled 17 MPG @ 70-75.
That CR was pushing it with iron heads, aluminum would have been better.
Avoid the MP "stroker 360" pistons, they're actually for SBC rods.
Re: If you were building a engine for ......... [Re: topside] #2880135
01/25/21 08:49 PM
01/25/21 08:49 PM
W. Kentucky
W. Kentucky
Thanks guys.
The 408 ran 6.57 in the 1/8 in my 3240# 69 Dart so I'm looking to turn it down quiet a bit. The current pistons are Diamonds with a 20 cc dish and a .927" pin, so yes a GM size pin. The crank also has a GM size 2.10" journal, it opens up rod options a bunch.
Re: If you were building a engine for ......... [Re: justinp61] #2880184
01/25/21 10:10 PM
01/25/21 10:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Do what I am doing now , with a little less cam.
I am doing a 408 that will be around 10.5:1 with aluminum heads and a hydraulic flat tappet stick ............. 540 / 540 and 236 / 244 @ .050.
I plan on running A.C. but is going in an '80 Volare wagon that will be a grocery getter with occasional track blasts for the wife.
A cam with more attention toward the bottom end would be everything but economical for you.
But mileage isn't a huge concern for either of us I think.
Re: If you were building a engine for ......... [Re: tubtar] #2880195
01/25/21 10:27 PM
01/25/21 10:27 PM
W. Kentucky
W. Kentucky
No, mileage isn't a top priority. I'd prefer to keep it on 87 octane though.
Re: If you were building a engine for ......... [Re: justinp61] #2880255
01/26/21 12:55 AM
01/26/21 12:55 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What I should have said in my SBC rod remark was the pin end on the pistons was too narrow for a SBM rod; had to machine them wider.
I'm all for smaller diameter pins & etc.
Re: If you were building a engine for ......... [Re: topside] #2880332
01/26/21 10:38 AM
01/26/21 10:38 AM
gregsdart Offline
gregsdart  Offline
If you are serious about overdrive and 3.21 to 3.55 rear gear, the cam choice better be real short duration. I would opt for a 3.91 rear gear , 408 cubes and O.D. that will allow a bit more cam as your cruise rpm in OD will rise to somewhere around 2000 or a bit more. A custom lockup converter will almost be a must.
Re: If you were building a engine for ......... [Re: gregsdart] #2880337
01/26/21 10:49 AM
01/26/21 10:49 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree I have 3.91s behind my 518. That is a very good combination. 3.55s or especially 3.23s would seem too steep to me. The only concern with 3.91s could be drive shaft speed. Joints, balance, and angles need to be dead on to cruise at hiway speed.
Master, again and still
Re: If you were building a engine for ......... [Re: DaveRS23] #2880509
01/26/21 04:50 PM
01/26/21 04:50 PM
confused I tried 3:73, 3:91, 4:10 and 4:30 in my old pump gas Duster with the 518 C.I. low deck 400 stroker motor. That car ran the same ET and MPH, within .10 ET and .3 MPH, in both the 1/8 mile and 1/4 mile shock The car did spend less time in high gear with the lower 4:30 ratio in it than it did with the 3:73 and 3:91 in both the 1/8 mile and 1/4 mile shruggy
The higher ratio(4:10 and 4:30) would give it more starting line ratio than the other lower (3:73, 3:91) rear ratio would which in turn affected the stall speed in the converter, especially in low gear work
Dave when you say 518 are you talking about the C.I. or trans type? shruggy
Re: If you were building a engine for ......... [Re: justinp61] #2880765
01/27/21 07:48 AM
01/27/21 07:48 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Id move to the G3 platform and use a junkyard unit with a carb. Holley adds to their engine swap section continuously these past few months with new swap parts, and have a dedicated section to 80s pickups.
There are a million G3s put there, no $ for machining if you get a good one.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: If you were building a engine for ......... [Re: Cab_Burge] #2880793
01/27/21 09:42 AM
01/27/21 09:42 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
540 Hemi, 518OD, 3.91s in 8 3/4.
Unlike the new engines, our old engines especially with some cam, need more RPM to be comfortable cruising. My '18 Hemi Ram will lope along on the hiway at 1,600RPM. But my 2nd gen Hemi really wants over 2,200RPM to cruise comfortably. So, I think it is very possible to get too low of a cruising RPM with our engines. Wedges might need a few less RPM and EFI could help. But there might be some trial and error to find out how low an RPM the combo would be comfortable cruising with.
You've got the heads, so my combo would be: 408, 518OD, 3.91s. The cam profile will be the big determinate on how the thing cruises.
Would you be able to run 87 with 10.8 comp ratio especially when in OD or when towing?
Re: If you were building a engine for ......... [Re: DaveRS23] #2880829
01/27/21 11:21 AM
01/27/21 11:21 AM
W. Kentucky
W. Kentucky
Its a given that the compression is going to be lowered. The whole idea of this build is to use as many parts that I have on hand that I can. Other wise it just sets on the shelf and is worth $0.20 on a dollar.
