That's a crank stopper right there!
#2879647
01/24/21 10:15 PM
01/24/21 10:15 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I did the initial mock up on the 541 today. I foresee grinding in my future but it's not as bad as I expected.
The oil pick up boss is the only point of contact but that might change with less than .030" between the rod bolts and bottom of the cylinders. They're gonna be cozy with some heat and RPM. Gotta dust a bit off the bores.
Re: That's a crank stopper right there!
[Re: moparx]
#2879987
01/25/21 03:52 PM
01/25/21 03:52 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Feets, what is the stroke and rod journal diameter?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: moparx]
#2880045
01/25/21 05:51 PM
01/25/21 05:51 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
neat way you have the pick up tube adapter mounted zippy. how much did you have to move it ? did you just slot the mounting holes then move the adapter over for clearance, or did you plug the original holes, move the required clearance amount, then re-drill and tap new holes ?
It's an aftermarket block and comes that way. I stopped at this point, I didn't care much for any of the mods required to make the internal pickup work so I went external.
Rich H.
Esse Quam Videri
[Re: Hemi_Joel]
#2880214
01/25/21 10:57 PM
01/25/21 10:57 PM
feets
Senior Management
Senior Management
Irving, TX
Feets, what is the stroke and rod journal diameter? It's a 4.5" stroke with 2.2" journals.
