65 Hemi #2876960
01/20/21 12:44 AM
01/20/21 12:44 AM
north florida
artie717 Offline OP
artie717  Offline OP
north florida
Picked up another Hemi and was thinking it was probably in a 66 car ? My question is did all blocks have stampings on the lower ear? This block is blank there other then Maltese cross .This is a 65 block with matching 65 heads , B was 66 correct? Thanks
Re: 65 Hemi [Re: artie717] #2876986
01/20/21 01:35 AM
01/20/21 01:35 AM
AndyF Offline
AndyF  Offline
Yes, B is for 1966 model year.
Re: 65 Hemi [Re: AndyF] #2878096
01/21/21 09:38 PM
01/21/21 09:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What is that top row? I never have seen that before? Maybe a rebuilders mark?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 65 Hemi [Re: Hemi_Joel] #2878123
01/21/21 10:32 PM
01/21/21 10:32 PM
AndyF Offline
AndyF  Offline
That is what I'd guess. Some rebuild shop stamped the block with the date they built the engine. Looks like it was in 1985 so back before people cared much about numbers matching. My buddy parted out a Hemi car back in the 80's because it wasn't worth fixing then. So no surprise that a shop would stamp a Hemi block like that.
Re: 65 Hemi [Re: AndyF] #2878236
01/22/21 09:47 AM
01/22/21 09:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What are you doing with the block? What’s the casting date on the side?
Re: 65 Hemi [Re: cudaman1969] #2878710
01/23/21 12:25 AM
01/23/21 12:25 AM
north florida
artie717 Offline OP
artie717  Offline OP
north florida
It’s a pretty complete engine, heads are matching 65 also , not really sure what I am doing with it . I bought a 78 Ramcharger out of California I was thinking about putting in that for a wile. Looks like 8/16 or 18 of 65 is casting date
Re: 65 Hemi [Re: artie717] #2878727
01/23/21 01:09 AM
01/23/21 01:09 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
B just right for my 66 build date of Dec. Hemi cars weren’t started till Nov-Dec of 65, first batch of engines were August then feb
Re: 65 Hemi [Re: cudaman1969] #2879202
01/23/21 11:59 PM
01/23/21 11:59 PM
north florida
artie717 Offline OP
artie717  Offline OP
north florida
I will let you know if I decide to sell it , heads are M85 on both so I think there matching to engine, I paid pretty good money for it .
Re: 65 Hemi [Re: artie717] #2879229
01/24/21 06:35 AM
01/24/21 06:35 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Nice find!
Maltese cross is for undersized crankenshaft.
If its a DIAMOND then its trouble...Bonky lifters... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 65 Hemi [Re: Gtxxjon] #2879560
01/24/21 07:26 PM
01/24/21 07:26 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
1965 Hemi engines has Aluminum heads and thin balancers. This is the casting date of my 1965 Hemi Block that was placed between the frame rails of a 1965 B Body. Not all 1965 Cast block went into 1965 car. Look at the top pad on what I am posting and that tells you this is a 1965 High Compression Hemi Block.
5.5.64 hemi block.jpg1965 Hemi Block Machining Pad.jpg1965 Hemi Block Front Pad.jpg
1971 HEMI E BODY REGISTRY
