Re: 65 Hemi
[Re: AndyF]
#2878096
01/21/21 09:38 PM
01/21/21 09:38 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
What is that top row? I never have seen that before? Maybe a rebuilders mark?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 65 Hemi
[Re: artie717]
#2879229
01/24/21 06:35 AM
01/24/21 06:35 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Nice find! Maltese cross is for undersized crankenshaft. If its a DIAMOND then its trouble...Bonky lifters...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 65 Hemi
[Re: Gtxxjon]
#2879560
01/24/21 07:26 PM
01/24/21 07:26 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
1965 Hemi engines has Aluminum heads and thin balancers. This is the casting date of my 1965 Hemi Block that was placed between the frame rails of a 1965 B Body. Not all 1965 Cast block went into 1965 car. Look at the top pad on what I am posting and that tells you this is a 1965 High Compression Hemi Block.
1971 HEMI E BODY REGISTRY
