Cam Removal
#287811
04/13/09 09:13 PM
04/13/09 09:13 PM
Hello everyone, I am in the process of disassembling my first 440. It is on the engine stand. I have the crank, rods, pistons, everything else out of it but, I cannot get the cam out. It spins freely when a turn it by hand but, I have pulled and twisted and everything else you can think of and I cannot get it to budge. Anyone have any suggestions or advice?
Mike
Re: Cam Removal
#287812
04/13/09 09:17 PM
04/13/09 09:17 PM
RapidRobert
lifters out? Bolt cam gear on & use it to help you get it started coming forward
Re: Cam Removal
[Re: SomeCarGuy]
#287814
04/13/09 09:38 PM
04/13/09 09:38 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Take out the fuel pump and push rod. No way to get the cam out with the pump and push rod still in.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: Cam Removal
#287816
04/13/09 10:08 PM
04/13/09 10:08 PM
Thanks for all the responses. Well, the lifters, fuel pump and all that is out of the engine the only thing thers(I thought) was the cam. I did have the cam gear bolted on to use as a handle. However, I completely forgot about the fuel pump push rod. I have kinda quit for tonight but, I bet that is what the problem is. I will give that a try.
Thanks,
Mike
Re: Cam Removal
#287817
04/13/09 10:19 PM
04/13/09 10:19 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Is the dist drive out?Rocky
Chrysler Firepower
Re: Cam Removal
[Re: dave571]
#287819
04/14/09 06:51 AM
04/14/09 06:51 AM
MoparforLife
Upper Midwest
like said above the intermediate shaft too.
