Re: gas gage proublems
[Re: cupcake]
#287792
04/13/09 09:09 PM
04/13/09 09:09 PM
RapidRobert
power is cut to the gauge in start(ign 2)so you're Ok there
[Re: cupcake]
#287794
04/13/09 09:36 PM
04/13/09 09:36 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
to check the sending unit, you need to be able to move the float up and down. If the readings are between 73 and 10 ohms, you're good. The gauge is just reading the resistance at the sending unit.
you need to get a multimeter out and check continuity between the pin on the back of the gauge cluster and the connector on the sending unit.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: cupcake]
#287795
04/13/09 09:39 PM
04/13/09 09:39 PM
RapidRobert
When cranking power is cut to all non essential devices that are not neccessary to help start the car such as gauges/accessories(radio/fan/heater etc)so that as much power as possible is diverted to the starter and ignition to start the car. Like on star trek when Kirk would divert power from other systems(the invisibility shield for instance)so that the phasers would have max power. The exception is power is still available for the headlights/taillights/turn signals/flashers for safety reasons as they are not neccessary to start the car but a person can choose to shut them off at night if the car dies as long as you ain't in danger of being hit.
[Re: cupcake]
#287800
04/13/09 11:02 PM
04/13/09 11:02 PM
Posts: 32,976 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
This sounds weird but try moving the ignition switch wires at the base of the colume and at the bulkhead under the hood while in the run postion after the gauge quits. See if maybe you have a bad connection somewhere.Does the temp gauge quit also or just the gas gauge?
