Cheap 90 MM throttle body?
#2877479
01/20/21 07:32 PM
01/20/21 07:32 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Any one use those $140 90mm bodies off fleabay yet? If yes what results and other info did you find?
Re: Cheap 90 MM throttle body?
[Re: HotRodDave]
#2877804
01/21/21 12:37 PM
01/21/21 12:37 PM
Posts: 114 Katy, TX
Bakaruda
Katy, TX
I bought a G-Plus on amazon 90mm LS style drive by cable. If this is what you are referring to. If you use quality sensors they are fine. If you are asking about the drive by wire sorry no clue.
1969 Barracuda GENIII Hemi 2019 Ram 1500 Laramie
[Re: Bakaruda]
#2877829
01/21/21 01:09 PM
01/21/21 01:09 PM
HotRodDave
Kalispell Mt.
looking at the drive by wire as a cheap upgrade for the 6.4 srt8 in my 1/2 ton 2011 truck
[Re: HotRodDave]
#2879118
01/23/21 07:05 PM
01/23/21 07:05 PM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
I have no answer on your cheap throttle body question, but I do have a question on increasing throttle body size.
What are the gains from increasing throttle body size?
Horsepower, torque, throttle response?
The 2010 Challenger SRT I just got has an Arrington 85mm throttle body on it. It was done at the same time as a Comp Cam kit, Kooks headers and hi-flow cats
[Re: SNK-EYZ]
#2879914
01/25/21 02:32 PM
01/25/21 02:32 PM
HotRodDave
Kalispell Mt.
Well if it is the restriction in the intake then you can get more peak HP . Also since it should flow more even at part throttle then it should improve throttle response and MPG by making the same TQ at a lower throttle angle thereby keeping the trans from downshifting quite as frequently.
I guess I am gonna have to be the guineapig on this as I can't afford a name brand one right now.
[Re: HotRodDave]
#2966039
09/21/21 02:06 PM
09/21/21 02:06 PM
HotRodDave
Kalispell Mt.
In case anyone is still wondering about these, I tried one, looks very nice to hold in your hand, I was easily able to grind out the intake to fit butt it kept giving me all kind of codes about impossible throttle position and stuff. I suspect if you wanted to take one apart to adapt to a throttle cable it would be nice cheap way for that. I tried it on 3 different 2011 trucks and all were giving me the same codes, I also bought one for a 2014 but the customer who was going to let me try it out never showed up...
