Please critique this 440 build #287601
04/13/09 08:09 PM
04/13/09 08:09 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
440 not bored yet but minimum as possible /probably .030
stock rods, stock crank, forged flat top pistons, molly rings
Speed Demon 750
Holley Street dominator intake (must use short intake to clear hood. Car has air grabber)
Eddy 84 CC heads worked by Indy with new valves and mild bowl work
Camshaft Specifications
Part No.: 23-000-5
Grind: CRB 5445/286H-3 HY110 (custom)
Type: Hydraulic flat-tappet, three-bolt cam sprocket
Duration at 0.006-inch tappet lift: 274* int./286* exh.
Duration at 0.050-inch tappet lift: 230* int./236* exh.
Valve lift (1.60:1 rockers): 0.523-inch int./0.523-inch exh.
Lobe displacement angle (LDA): 110*
Installed intake centerline: 106*
10 to 10.5 compression
windage tray
6 quart hemi oil pan with 3/8 pickup
stock oil pump
work oil system IAW MP engine book
1 7/8 header with 2.5 inch exhaust (TTI)
Car is 69 GTX 4 speed 3:54 rear
Re: Please critique this 440 build [Re: frank] #287602
04/13/09 08:12 PM
04/13/09 08:12 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
looks good
I want my fair share
Re: Please critique this 440 build [Re: SomeCarGuy] #287603
04/13/09 08:18 PM
04/13/09 08:18 PM
Montana
67DodgeCharger Offline
On vacation
On vacation
Montana
I would watch the deck height after bore and honing and deck. 84 cc heads might push your compression up more than you would like.
What year is the block? Might consider a stronger rod?
Robert
Re: Please critique this 440 build [Re: 67DodgeCharger] #287604
04/13/09 08:32 PM
04/13/09 08:32 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Block is 69 vintage. Original engine. Would 3 inch exhaust be too big? Engine should make about 550 hp
Re: Please critique this 440 build [Re: frank] #287605
04/13/09 08:51 PM
04/13/09 08:51 PM
SomeCarGuy Offline
SomeCarGuy  Offline
The block will be more than fine, any year would do, the block issue is the most overblown thing I have seen.
Rods will be fine if machined right, but might cost close to a new set so check it out. Would make it easy to go to the .990 pin.
3" might be a bit much, but won't hurt other than maybe kill a small amount of low end torque. If you want it loud that would do it though.
Re: Please critique this 440 build [Re: SomeCarGuy] #287606
04/13/09 09:01 PM
04/13/09 09:01 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
What is the advantage of the .990 pin?
Re: Please critique this 440 build [Re: frank] #287607
04/13/09 09:15 PM
04/13/09 09:15 PM
SomeCarGuy Offline
SomeCarGuy  Offline
It saves a ton of rotating weight in the engine. It isn't something to sweat if you keep the stock pin, which is somethign like 1.07
You might ask what it will cost to bush your stock rods to that size but don't spend a bunch to do so.
.990 is stock big block Chevy size, and those pins hold gobs of power. The Mopar pins were overkill, you know, normal for Mopar stuff of the day
Re: Please critique this 440 build [Re: SomeCarGuy] #287608
04/13/09 09:16 PM
04/13/09 09:16 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Most aftermarket rods come with that size, it is a very common pin size in new pistons as well.
Re: Please critique this 440 build [Re: SomeCarGuy] #287609
04/13/09 09:29 PM
04/13/09 09:29 PM
Central NC
gch Offline
gch  Offline
Central NC
That is stong combo.I would shoot for no more than 10.5-1 with that cam.Watch your timing curve.
I would run the 3" if you have to buy a system.It will support future upgrades if you plan to.It won't hurt low end much but will help the top end.Go with some turbo style mufflers to keep the noise down if that is a concern.
Re: Please critique this 440 build [Re: gch] #287610
04/13/09 09:35 PM
04/13/09 09:35 PM
SomeCarGuy Offline
SomeCarGuy  Offline
How much is Indy going to charge for the port work? Might be worth a call to Dwayne Porter(fast68plymouth on here). He has as good of a name as there is in the hobby and you won't be a number on a file there.
Re: Please critique this 440 build [Re: SomeCarGuy] #287611
04/13/09 11:11 PM
04/13/09 11:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Should work well, although with that cam and that intake I would probably want more than a 3.54 gear but being a 4 speed I'm sure it'll be fine.
Re: Please critique this 440 build [Re: frank] #287612
04/13/09 11:21 PM
04/13/09 11:21 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I like this combo alot.
I think it is a nice real life build for a 354 geared street car.
BUT, I think you will need more cam(duration) to see over 500hp.
The rest of the motor is ready for it (worked heads etc)
I don't think you want more cam with these gears, and a 4 speed street car. I'm just saying this will probably be just a hair under 500.
And dont' worry about the comp being too high. Heads are aluminum, so it won't get too high.
Re: Please critique this 440 build [Re: dave571] #287613
04/14/09 12:04 AM
04/14/09 12:04 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My .02.
Id shoot for a minimum for 10.5 comp with the aluminum heads. Ditch the cam and get a solid around 250 duration at .050. That hyd cam you listed is a baby, to me anyway. The SD is a good intake, no problem with it.
My car weighs 3800 lbs, using a comp 259@.050 solid, with no quench whatsover. 10.6 compression. Ported 452's. Ive had 3.23's, 3.55s and 4.30s in the car. Car runs fine with all 3 ratios. I honestly cant feel a big seat of the pants difference between any of the ratios. Acts just fine on the street.
I agree your combo wont make 550 HP. As planned Id say more like 450 or so. My stuff might make 525 if Im lucky.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Please critique this 440 build [Re: Von] #287614
04/14/09 12:20 AM
04/14/09 12:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree its a nice combo and as was said a nice solid cam would give it more power. I use 10.0 comp with 906 heads and i have good quench. I also use the MP .557 solid in my 63's 440 and it is is around 250 at .050. My eng is close to 500 hp and it has pushed my 3700 lb 63 to 11.50's so far. I believe you will be making closer to 450 to 475 hp with that cam. But it is a good build that should run fine its just that a nice solid cam will wake it up more. Good luck with it as you will have a nice running car. Ron
Re: Please critique this 440 build [Re: 383man] #287615
04/14/09 02:46 AM
04/14/09 02:46 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Combo looks good, fairly simular the the CarCraft Edelbrock headed 440 built many years ago that made 535 HP, and really good torque (with unported heads.)
Re: Please critique this 440 build [Re: 451Mopar] #287616
04/14/09 08:49 AM
04/14/09 08:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't believe the numbers that mag articles throw out on engine builds ESPECIALLY if the engine was run on the HAPPY WESTECH DYNO . No way that build above is going to make 550HP with that tiny HYD. cam . Also if you are shooting for 550HP ditch the stock rods , it makes zero sense to run them considering the low cost of better quality replacements available .
Re: Please critique this 440 build [Re: JohnRR] #287617
04/14/09 09:45 AM
04/14/09 09:45 AM
Check out a carb website and company called AED in Richmond Va --New Holley 750 HP all hand built for just a little more than the Demon--The Demons are OK if you get a good one if not don't count on BG to have any mercy on you--The AED Holleys are fantastic! They come out of the box about two jets rich for my stuff but are wonderful carbs! Check them out! AED customer service can't be beat!
Re: Please critique this 440 build [Re: frank] #287618
04/14/09 06:03 PM
04/14/09 06:03 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
check out 440 Source Platinum Series I-beam rods before you spend any $ on the stock rods.
The rest you will be very happy with.
Re: Please critique this 440 build [Re: JUST_N_TIME] #287619
04/14/09 06:14 PM
04/14/09 06:14 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
It's probably just me, but those Indy-worked heads kinda throw up a red flag. I guess I'm just spoiled by MCH.
Re: Please critique this 440 build [Re: frank] #287620
04/14/09 08:25 PM
04/14/09 08:25 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks all. The cam came from an old Car Craft 440 build article as some have noted. I have a set of Indy EZ heads but they won't fit under the hood. I will look into a solid cam and better rods. Thanks again.
