14” rally’s don’t fit after disc brake install
#2875714
01/17/21 07:56 PM
01/17/21 07:56 PM
Posts: 236 Richmond , Virginia
chagjr
Richmond , Virginia
Is there a 14” Rally wheel available that fit the Wilwood 3” hub? Installed the “A” body kit for 9” drum spindles. Installation went well except wheels don’t fit . I saw a Wheel Vintiques Series 56 14” wheel that appears to have a larger center bore, but Summit did not list that information. Help! And Thanks!
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: 14” rally’s don’t fit after disc brake install
[Re: chagjr]
#2875760
01/17/21 09:36 PM
01/17/21 09:36 PM
chagjr
Richmond , Virginia
I am looking at quite a few rally wheels on line. It appears that the 5X4.5 wheels have a larger diameter center bore for the hubs. Are the small bolt pattern (5X4) the small center hole only? Will the 5X4.5 the answer? Wheel stud location can be changed.
Harry
[Re: topside]
#2875780
01/17/21 10:01 PM
01/17/21 10:01 PM
chagjr
Richmond , Virginia
Unfortunately, new SBP axles from Dr. Diff are already installed. I am going for the stock sleeper look. Just going to purchase 2 wheels with 5X4.5 BP
Now I can sleep tonight. THANK YOU! 🙏
Harry
[Re: topside]
#2876068
01/18/21 02:04 PM
01/18/21 02:04 PM
Posts: 19,355 north of coder
moparx
all small bolt pattern factory steel wheels have a smaller hub register than do the large 4 1/2 bolt pattern wheels. i can't recall what the sbp register is, but the hub size of the lbp is 2.800 while the wheel register hole can be from 2.805 to 2.820 or so. this is from years of measuring wheel center holes of factory steel wheels.
