Page 4 of 7 1 2 3 4 5 6 7
Re: 1951 Plymouth Cambridge [Re: DynoDave] #2834067
10/17/20 10:20 PM
10/17/20 10:20 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Not much of an update right now, finally got the temps down, 100+ degree days takes a toll and work has been crazy lately, catching up after the covid slowdown.
My son and I got some maintenance time in today. We greased up all the zerk fittings on the car, there are 23 of them. Showed him how to check tie rods, kingpins, sway bar mounts, etc for play and looseness. Only iffy thing we found was the driver's side upper shock bushing had a bit of play. Since relocating that mount is on the list to do and that requires different shocks it will be addressed. Taught him how to remove the hubcaps, check tire pressures and reinstall hubcaps. I know it seems basic to us but hey when was the last time you saw a new car with hubcaps anymore? We also played around with my IR gun and discussed how the cooling system functions. We also went over camber, caster and toe as well as bumpsteer. These jobs tend to run long since almost everything is a learning opportunity for him so we go into the why things work alot.
I know the project is going somewhat slow, but I only get him one weekend a month and we squeeze in what time we can on it.
This worked out better than I had hoped, he's been enjoying it so much he signed up for collision repair class this year at school.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2834156
10/18/20 10:25 AM
10/18/20 10:25 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
ANY progress is better than NO progress. DAMHIK frowwn
Good to hear the project has had a positive impact on your son! thumbs
John
Re: 1951 Plymouth Cambridge [Re: SattyNoCar] #2866537
12/30/20 03:23 PM
12/30/20 03:23 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Sort of an update. I got a core engine to build and hop up since my original engine is in good shape I don't want to blow it up hot rodding it. Took the opportunity to go from a 218 to a 230. It got delivered today and as I was looking it over I noticed the engine number, a good omen?
Re: 1951 Plymouth Cambridge [Re: Sniper] #2866540
12/30/20 03:24 PM
12/30/20 03:24 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Use my home built gantry crane to pick it up off the pallet. I was a bit worried it may have been undersized for the load. It didn't even notice.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2875250
01/16/21 08:33 PM
01/16/21 08:33 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Started the tear down of the core 230 has begun. I am surprised how clean it looks behind the tappet covers. I expected it to be all sludged up. several valves are stuck, no biggie. It;ll get them loosened up.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2877728
01/21/21 09:55 AM
01/21/21 09:55 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
not bad at all!
1981 Dodge D150 360 auto
Re: 1951 Plymouth Cambridge [Re: basketcase] #2879204
01/24/21 12:09 AM
01/24/21 12:09 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Spent some time with my son on tearing down the 230, had to drag him away from Band of Brothers to do it though.
Got all the studs but two out of the manifold mounting area, going to leave those two for the machine shop as I already broke off an easy out in each and managed to remove the broken parts, which if you've ever had to remove a broken easy out you know how fun that can be. So my son learned some valuable information with that, first don't break an easy out, second how much fun it can be removing the broken one.
Pulled all the external stuff off of the distributor side, except the oil fill and dipstick tubes. No real issues there.
Got the plugs out, some of them really did not want to come out, used Kroil on them but even so number three was a bear. All of them had gaps in excess of .045" some well in excess. Wonder how well it ran? Number six looked a bit rich but the rest looked ok colorwise. This kind of thing will tell you how well it ran aforehand.
Pulled the head off, most of the head bolts came out ok, one or two were a bit reluctant but came out. Solid copper head gasket on it, no copper coat or sealant that I could determine, head popped off with no issues whatsoever, one moderate whack with a plastic headed hammer and the head moved. No idea what brand that head gasket was, couldn't see any name on it. Not planning to reuse it so it doesn't matter, might turn it into wall art for the garage. Some of the coolant holes in the deck were a bit goobery. It was interesting to see where, in the chamber, the carbon build up was. Tells a bit about the thermodynamic characteristics.
Cylinder walls barely had a ridge, just enough to barely catch a finger nail. Might have just been carbon build up, haven't looked close at it yet. Might bust out the KaBar to see if I can scrape off the carbon or if it's a ridge. Both the KaBar and I have found other uses for ourselves these days, lol.
In the tappet picture above you can see some of the valves are stuck. I put some penetrating oil in through the ports three or four times since last weekend. Once we got the head off we squirted some more penetrating oil in thru the opening between the deck and the open valve. Then hosed down the valve stems as well. the objective being to loosen up the carbon and rust. I got all but two loose with nothing more than some penetrating oil and a plastic faced hammer. I will work on the other two some more tomorrow, they are soaking in penetrating oil right now.
More as it happens.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2889273
02/16/21 04:04 PM
02/16/21 04:04 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Jumping to the 230 eh? The big block of the Plymouth flat head sixes!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1951 Plymouth Cambridge [Re: DynoDave] #2891230
02/20/21 09:49 PM
02/20/21 09:49 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Found a good core for a reasonable price so I figured, why blow up my original engine hot rodding it?
Besides, no replacement for displacement
Re: 1951 Plymouth Cambridge [Re: Sniper] #2893206
02/25/21 09:51 PM
02/25/21 09:51 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
DynoDave
Member # 12304
Re: 1951 Plymouth Cambridge [Re: DynoDave] #2930349
06/05/21 07:12 PM
06/05/21 07:12 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Got a bit more progress into the 230, the water distribution tube was almost completely plugged up. Drained the oil and it smelled like oil, not gasoline or antifreeze. Looked liked oil too, no water in it.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2930350
06/05/21 07:13 PM
06/05/21 07:13 PM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Used one lifting eye in the center head bolt hole, worked great. I bought 4 lifting eyes, just in case. Neighbor gave me the engine stand, seems the arms will only bolt to the engine in one place.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2931045
06/07/21 07:38 PM
06/07/21 07:38 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
cool beans!
Re: 1951 Plymouth Cambridge [Re: basketcase] #2941113
07/08/21 10:10 AM
07/08/21 10:10 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
More progress today, of a sort.
Started taking out the valve train. Had a couple sticky valves that repeated applications of many different penetrating oils didn't affect. Started at the front of the block, working aft. Got to valve 7, of 12, when I dropped a valve keeper. Heard it hit sheet metal, didn't see it. I do have a sheet metal drip pan under the engine, no it didn't land there.
So, I drop the oil pan, which was on the list of things to do, but not right now. Such is fate. Keeper is in the pan. I see some minor sludge in the pan and run my fingers through to see what there is to see. I found Blackbeard's treasure. Number 6 cylinder skirt in the pan.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941118
07/08/21 10:18 AM
07/08/21 10:18 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Shot of the number 6 cylinder. Nothing catches my finger nail, heck there is virtually no ridge at the top of any cylinder.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941121
07/08/21 10:21 AM
07/08/21 10:21 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Inside the block is nice and clean. Oil pan didn't really have much sludge, more like thick oil that would have drained if the engine was hot. The oil pan pic I took is blurry, so no pan shot for now.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941123
07/08/21 10:23 AM
07/08/21 10:23 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
Here's a shot of the oil pick up. Pretty clean.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941124
07/08/21 10:24 AM
07/08/21 10:24 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
So I pull the #6 rod cap, taking care to not lose the lock washers, The Freewheeling Tony Smith says they are very hard to find.
Not the worst bearing I have ever seen.
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941125
07/08/21 10:25 AM
07/08/21 10:25 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
backside of the rod bearing. .001 undersize, hmm. No date code I recognize. Anyone have any ideas?
Re: 1951 Plymouth Cambridge [Re: Sniper] #2941126
07/08/21 10:26 AM
07/08/21 10:26 AM
nowhere
Sniper Offline OP
Sniper  Offline OP
nowhere
So I decided to pull a main cap to see what those bearings looked like.
Not bad, not sure why the bearing color is black though, both rod and main that I checked.
