P4529345 cam #2875141
01/16/21 04:29 PM
01/16/21 04:29 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
I found a new MP cam and lifter package, along with pushrods and springs that I remembered ordering for a guy 15 years ago. Can’t find specs on cam, and box is difficult to read. It’s a Hemi cam. Anyone one know what it would be good for? Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: P4529345 cam [Re: BANDIT] #2875176
01/16/21 05:04 PM
01/16/21 05:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s the “590” cam, but for a hemi so the lifts are listed for the 1.57/1.52 rocker ratio.
Re: P4529345 cam [Re: fast68plymouth] #2875316
01/17/21 12:12 AM
01/17/21 12:12 AM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Thanks Dwayne, would it make a streetable cam in a 528 inch motor? I’d like to unload springs and pushrods and cam to a fellow if it would work. Jim.
4600 DA
Re: P4529345 cam [Re: BANDIT] #2875456
01/17/21 12:33 PM
01/17/21 12:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’s about 270@.050, and the lsa should be either 106 or 104.
It’s nothing I’d want to use on the street....... but I’m sure people have.
Re: P4529345 cam [Re: BANDIT] #2875688
01/17/21 07:05 PM
01/17/21 07:05 PM
A727Tflite Offline
A727Tflite  Offline
Sort of a clone of the old Racer Brown STX-22 drag cam.
A very popular cam in the late 60’, the RB STX was used in entry level SS cars before the move to rollers. Somewhere in between there was the Mini-Express mushroom cam.
This cam, 11.5-12 to 1, headers, 4 speed with 4.56 moved several local cars into the low 11’s in street trim.
