Head bolts. #2873477
01/13/21 12:49 AM
01/13/21 12:49 AM
Red Deer, Alberta
Greenwood Offline OP
Red Deer, Alberta
Okay guys. Who has the best trick for that center head bolt between the valve springs on a small block? There's got to be a better way than turning a couple of sockets down in the lathe. I now have four wrecked 1/2" drive 3/4" sockets because by the time you've torqued a head down, the socket is cracked.
Re: Head bolts. [Re: Greenwood] #2873518
01/13/21 03:04 AM
01/13/21 03:04 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Try a quality 3/8 drive one?
Re: Head bolts. [Re: Alchemi] #2873726
01/13/21 01:02 PM
01/13/21 01:02 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Are you trying to use a deep well? I use a short well with short extension.
Re: Head bolts. [Re: Alchemi] #2873774
01/13/21 01:51 PM
01/13/21 01:51 PM
moparx Offline
moparx  Offline
perhaps an impact 3/8 drive ? those sockets aren't as brittle as a standard chromed one.
what diameter does it need to be for the required clearance ?
beer
Re: Head bolts. [Re: moparx] #2873899
01/13/21 06:19 PM
01/13/21 06:19 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
They offer smaller headed bolts that addresses this. Are you using a stock size head bolts
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head bolts. [Re: pittsburghracer] #2873901
01/13/21 06:28 PM
01/13/21 06:28 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Grey Pneumatic offers a thin wall impact socket under the "Duo" branding. Might be worth checking. S/F...Ken M
Re: Head bolts. [Re: EchoSixMike] #2874098
01/14/21 02:31 AM
01/14/21 02:31 AM
Red Deer, Alberta
Red Deer, Alberta
I'm going to go visit my bolt supplier and see if he can source me a pair of proper length shoulder bolts. Those sockets look like a cool piece, too.
Re: Head bolts. [Re: Greenwood] #2874161
01/14/21 09:58 AM
01/14/21 09:58 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I wouldn't use anything but a purpose-made head bolt in there !!
Re: Head bolts. [Re: Greenwood] #2874324
01/14/21 03:47 PM
01/14/21 03:47 PM
AndyF Offline
AndyF  Offline
Use ARP head bolts
Re: Head bolts. [Re: AndyF] #2874343
01/14/21 04:27 PM
01/14/21 04:27 PM
Originally Posted by AndyF
Use ARP head bolts
iagree
ARP sells two different type head sizes on their head bolt, 6 point and 12 point, which are usually 7/16, 1/2 or 9/16 head bolt socket size depending on the kit part # and application.
OP, call ARP and ask them about buying two of those upper center head bolts you need to finish assembling the job twocents scope
Re: Head bolts. [Re: Cab_Burge] #2875584
01/17/21 03:25 PM
01/17/21 03:25 PM
Red Deer, Alberta
Red Deer, Alberta
That's a good idea, Cab. Thanks.
