Smart and/or wifi thermostat for home #2873543
01/13/21 08:34 AM
01/13/21 08:34 AM
Port Huron, Michigan
MI_Custumz Offline OP
I was wanting to get a thermostat so when we are gone for the day, we can drop the temp a bit and heat up the house before we get back home. Sam's Club has a Nest thermostat E on sale. Not sure if that will work. We have a G, Y, RH (jumper to RC), and W wire to the existing thermostat that runs on batteries. I do not see a C wire in the wall or further down the wiring sleeve. Would the Nest work or would I be better off getting a wifi one from Lowe's or online? I don't want additional fees or subscriptions. I want something we can manually turn up or down when we are home as well as a basic programming to keep it as a base line. We have a humidifier hooked to the furnace, but do not use it so not sure if that matters.
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2873572
01/13/21 09:55 AM
01/13/21 09:55 AM
Andrewh Offline
Andrewh  Offline
I don't think either wifi or smart ones are necessary for what you are asking.
A simple 7 day programmable is probably all you need.
you can set it for times when it turns off, or turns up and them override it when you get back home if you come home early.
The inlaws got a nest when they got their ac replaced, and I had to give them one of our old thermostats so they could use it again.
not saying it is complicated, but they were unable to keep the temps they wanted.
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2873587
01/13/21 10:20 AM
01/13/21 10:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
This would be a PITA with a "programable". Ask me how I know !!
With any of the WIFI thermostats you need at least 5 wires. If you have to rewire it, go with 7 wires. The "Nest" is probably the most expensive out there. There are less expensive alternatives. If you go to Lowes or HD, they have a full display where you can see them side-by-side and consider the features and price. But the wiring will be your issue. Rewiring should be no big deal ... secure the new wire to the end of the old wire (really well) and just pull it through.
Re: Smart and/or wifi thermostat for home [Re: Stanton] #2873601
01/13/21 10:38 AM
01/13/21 10:38 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't help with the wiring but I have a first generation nest thermostat and it has been great. You can get pretty detailed in how you want it set up, you can set up a geo fence so that when your household phones are out of the area it will shut down to your "not at home" settings, and then resume when you return. I don't use much of those features though, I just like the scheduling aspect of it because it is easy to setup and works well. I also like being able to adjust it from my phone.
This model didn't need any extra wires. I pulled down a 30 year old thermostat and mounted this one right up no problem.
68 Barracuda Formula S 340
Re: Smart and/or wifi thermostat for home [Re: Stanton] #2873609
01/13/21 10:47 AM
01/13/21 10:47 AM
St. Louis, Missouri area
Cometstorm Offline
"Beat It"
Cometstorm  Offline
"Beat It"
I’m not sure if it fits your wiring needs, but we got this one off Amazon.
Installed it myself replacing a programmable, and I’m no DIY wiz.
We love it!
We have two stage heat (heat pump, switches to propane under 35 degrees), humidifier on furnace, central AC).
ecobee SmartThermostat with Voice Control, SmartSensor Included, Alexa Built-In
https://www.amazon.com/dp/B07NQT85FC/ref=cm_sw_r_cp_apip_Nn6tUxxffWE3W
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2873622
01/13/21 11:00 AM
01/13/21 11:00 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
sounds like you only need a programable stat.. i have a nest and like it because i work different shifts and we do travel alot.. when gone we put the stst in eco mode that we set temps for.. when about an hour or so from home we take the stat out of eco mode and it goes to where ever i set it via pre program or where i decide to put it using my phone. you will need 5 wires though.. adding the 5th wires isn't too bad if its accessible to run the new wires..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Smart and/or wifi thermostat for home [Re: abodyjoe] #2873651
01/13/21 11:24 AM
01/13/21 11:24 AM
I'm sure if I had a furnace or electrician come in they could run new wires and hook it up no issues. The circuit board on the furnace isn't something I want to mess with. I came across this one and seems like a programmable one like we have now, but added wifi.
https://www.amazon.com/Emerson-Sens...p3Q&ref_=sbx_be_s_sparkle_mcd_asin_0
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2873749
01/13/21 01:26 PM
01/13/21 01:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
My daughter has that one. Needs 5 wires.
Re: Smart and/or wifi thermostat for home [Re: Stanton] #2873768
01/13/21 01:42 PM
01/13/21 01:42 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode.
Re: Smart and/or wifi thermostat for home [Re: John_Kunkel] #2873770
01/13/21 01:49 PM
01/13/21 01:49 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
I liked my nest till it went crazy one day...put my heat pump into heating mode instead of cooling....by the time I got home it was about 115 degrees...
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2873811
01/13/21 02:44 PM
01/13/21 02:44 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Wyze makes excellent products and is introducing a thermostat next month for $49.99. Here's their compatibility checker: https://wyze.com/thermostat-compatibility
Trying to enjoy life!
Re: Smart and/or wifi thermostat for home [Re: calmopar] #2873917
01/13/21 06:59 PM
01/13/21 06:59 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
My ex-girlfriend had an Ecobee in her place, and the house I just bought has a Nest in it. The Nest looks far nicer and is beefier. I liked the Ecobee function and app a little better though.
As Andy mentioned, for what you're doing a normal programmable one would be fine without actually needing the wifi capability.
Re: Smart and/or wifi thermostat for home [Re: Blusmbl] #2874123
01/14/21 07:04 AM
01/14/21 07:04 AM
Next days off I am going to see if the wiring in the wall has a 5th wire and if I can find what is on the circuit board on the furnace. It's under a great warranty, so I don't want to mess with the furnace part just yet.
Re: Smart and/or wifi thermostat for home [Re: John_Kunkel] #2874134
01/14/21 07:42 AM
01/14/21 07:42 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I'll try to remember to look at mine today. I think my nest is only setup with four wires and I do have the ability to control the fan alone. I have it set to run a little every hour during the day when we are not home and the system is set to "away temps".
Re: Smart and/or wifi thermostat for home [Re: Bad340fish] #2874167
01/14/21 10:19 AM
01/14/21 10:19 AM
Nest E is what I was looking into. It's an older model on clearance at Sam's for $80.
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2874244
01/14/21 01:20 PM
01/14/21 01:20 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Nest has a compatibility checker where you can put in the colors of the wires you have and then find if it will work-
https://nest.com/works/
Re: Smart and/or wifi thermostat for home [Re: calmopar] #2875021
01/16/21 10:25 AM
01/16/21 10:25 AM
I follow the Wyze group on facebook. Not sure if it's the thermostat having issues or people like me who aren't 100% sure on how to hook it up and it doesn't work like planned. I don't think I have a C wire in the wall. Will have to look on my next day off.
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2875040
01/16/21 11:24 AM
01/16/21 11:24 AM
boston mass-moving to long isl...
massdaytona Offline
massdaytona  Offline
my heating guy installed '4' smart thermostat's for each zone at my beach house.... unfort. i ain't 'smart' enough to learn how to use em... what a waste of 1500bucks
Re: Smart and/or wifi thermostat for home [Re: Bad340fish] #2875084
01/16/21 01:27 PM
01/16/21 01:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Just to update this mine indeed does run off of four wires and can run the fan alone on command, or on schedule whatever.
Re: Smart and/or wifi thermostat for home [Re: MI_Custumz] #2875106
01/16/21 02:17 PM
01/16/21 02:17 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
You say circuit board. Is it a zone panel that controls zone dampers ?
If so it could complicate things depending on age .
Honeywell is the best, and they make something called a common maker. Look into it , I think it’s simple.
