Re: Smart and/or wifi thermostat for home
[Re: MI_Custumz]
#2873587
01/13/21 10:20 AM
01/13/21 10:20 AM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
when we are gone for the day, we can drop the temp a bit and heat up the house before we get back home. This would be a PITA with a "programable". Ask me how I know !! With any of the WIFI thermostats you need at least 5 wires. If you have to rewire it, go with 7 wires. The "Nest" is probably the most expensive out there. There are less expensive alternatives. If you go to Lowes or HD, they have a full display where you can see them side-by-side and consider the features and price. But the wiring will be your issue. Rewiring should be no big deal ... secure the new wire to the end of the old wire (really well) and just pull it through.
[Re: Stanton]
#2873601
01/13/21 10:38 AM
01/13/21 10:38 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I can't help with the wiring but I have a first generation nest thermostat and it has been great. You can get pretty detailed in how you want it set up, you can set up a geo fence so that when your household phones are out of the area it will shut down to your "not at home" settings, and then resume when you return. I don't use much of those features though, I just like the scheduling aspect of it because it is easy to setup and works well. I also like being able to adjust it from my phone.
This model didn't need any extra wires. I pulled down a 30 year old thermostat and mounted this one right up no problem.
68 Barracuda Formula S 340
[Re: Stanton]
#2873609
01/13/21 10:47 AM
01/13/21 10:47 AM
Posts: 2,774 St. Louis, Missouri area
Cometstorm
"Beat It"
"Beat It"
I’m not sure if it fits your wiring needs, but we got this one off Amazon. Installed it myself replacing a programmable, and I’m no DIY wiz. We love it! We have two stage heat (heat pump, switches to propane under 35 degrees), humidifier on furnace, central AC). ecobee SmartThermostat with Voice Control, SmartSensor Included, Alexa Built-In https://www.amazon.com/dp/B07NQT85FC/ref=cm_sw_r_cp_apip_Nn6tUxxffWE3W
[Re: MI_Custumz]
#2873749
01/13/21 01:26 PM
01/13/21 01:26 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm sure if I had a furnace or electrician come in they could run new wires and hook it up no issues. The circuit board on the furnace isn't something I want to mess with. I came across this one and seems like a programmable one like we have now, but added wifi. My daughter has that one. Needs 5 wires.
[Re: Stanton]
#2873768
01/13/21 01:42 PM
01/13/21 01:42 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode.
[Re: John_Kunkel]
#2873770
01/13/21 01:49 PM
01/13/21 01:49 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
I liked my nest till it went crazy one day...put my heat pump into heating mode instead of cooling....by the time I got home it was about 115 degrees...
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: calmopar]
#2873917
01/13/21 06:59 PM
01/13/21 06:59 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
My ex-girlfriend had an Ecobee in her place, and the house I just bought has a Nest in it. The Nest looks far nicer and is beefier. I liked the Ecobee function and app a little better though.
As Andy mentioned, for what you're doing a normal programmable one would be fine without actually needing the wifi capability.
[Re: John_Kunkel]
#2874134
01/14/21 07:42 AM
01/14/21 07:42 AM
Bad340fish
Tulsa OK
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode. I'll try to remember to look at mine today. I think my nest is only setup with four wires and I do have the ability to control the fan alone. I have it set to run a little every hour during the day when we are not home and the system is set to "away temps".
[Re: Bad340fish]
#2874167
01/14/21 10:19 AM
01/14/21 10:19 AM
Posts: 5,651 Port Huron, Michigan
MI_Custumz
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode. I'll try to remember to look at mine today. I think my nest is only setup with four wires and I do have the ability to control the fan alone. I have it set to run a little every hour during the day when we are not home and the system is set to "away temps". Nest E is what I was looking into. It's an older model on clearance at Sam's for $80.
[Re: Bad340fish]
#2875084
01/16/21 01:27 PM
01/16/21 01:27 PM
Bad340fish
Tulsa OK
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode. I'll try to remember to look at mine today. I think my nest is only setup with four wires and I do have the ability to control the fan alone. I have it set to run a little every hour during the day when we are not home and the system is set to "away temps". Just to update this mine indeed does run off of four wires and can run the fan alone on command, or on schedule whatever.
[Re: MI_Custumz]
#2875106
01/16/21 02:17 PM
01/16/21 02:17 PM
Posts: 630 Ct
Wirenut
Ct
You say circuit board. Is it a zone panel that controls zone dampers ? If so it could complicate things depending on age . Honeywell is the best, and they make something called a common maker. Look into it , I think it’s simple.
[Re: Bad340fish]
#2875148
01/16/21 04:36 PM
01/16/21 04:36 PM
John_Kunkel
Rio Linda, CA
Heating and cooling or just heating?
[Re: John_Kunkel]
#2875319
01/17/21 12:29 AM
01/17/21 12:29 AM
Bad340fish
Tulsa OK
Heating and cooling or just heating? Both
[Re: MI_Custumz]
#2875378
01/17/21 07:00 AM
01/17/21 07:00 AM
Posts: 138 central pa
darted1
central pa
you need a common ( c ) wire for it to work properly
ED M
[Re: Wirenut]
#2875379
01/17/21 07:23 AM
01/17/21 07:23 AM
MI_Custumz
You say circuit board. Is it a zone panel that controls zone dampers ? If so it could complicate things depending on age . Honeywell is the best, and they make something called a common maker. Look into it , I think it’s simple. I meant the circuit board in the furnace where the wiring for the thermostat hooks into. No idea what a zone panel is. That's why I was hoping for a wifi thermostat that works without a C wire. I have heat and central air. If the Nest steals power when running, there are a few weeks when the furnace/AC is not on at all. Usually spring and fall when it's nice out.
[Re: Bad340fish]
#2875380
01/17/21 07:24 AM
01/17/21 07:24 AM
MI_Custumz
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode. I'll try to remember to look at mine today. I think my nest is only setup with four wires and I do have the ability to control the fan alone. I have it set to run a little every hour during the day when we are not home and the system is set to "away temps". Just to update this mine indeed does run off of four wires and can run the fan alone on command, or on schedule whatever. I see you have the extra blue wire there. Is that the C wire? How would you find out if a wire has 24V? I know a multimeter can check it, but one end on the wire and where would the other go?
[Re: MI_Custumz]
#2877979
01/21/21 05:25 PM
01/21/21 05:25 PM
Posts: 1,025 NJ
EV2RTSE
NJ
Not an expert by any means but I think you'll be fine. My gas company is running an incentive program right now offering the basic Nest thermostat for free, or the more expensive learning thermostat for $95 ($150 off). I ran the compatibility checker and came up with the result that my system (also 4-wire) 'should' work with it,so I said [censored] l'll get one...
I just installed it today. I have gas heat, central a/c forced air. In my case wires are red to RH, white to W, green to G, and blue to Y. I hooked it up the same way to the Nest and - good to go.
It won't let me test the a/c due to the cold outside temps (built-in safety feature) but the fan and heat work as they should. Power to the unit seems fine, the screen activates when you walk by as it should.
If your wires are thin, like 20 gauge single strand / solid then you have the low voltage (24v) setup. 120v I believe are braided like you might see in a lamp fixture or ceiling fan control module wiring, etc. and should also state this somewhere on the thermostat.
[Re: EV2RTSE]
#2878205
01/22/21 06:52 AM
01/22/21 06:52 AM
MI_Custumz
I don't see any warning about high voltage on the thermostat cover or front of the unit. Will have to check behind the unit where it meets the wall, but would assume it would be posted somewhere easy to see. I have a red going to the RH with a jumper to RC, Yellow to Y, Green to G, and White to W. The wires appear to be solid and thin. The thermostat wires in the furnace show Red=R, Yellow=Y, Green=G, Blue=C, and White=W. It has some wires tied into the blue one, but no blue to the thermostat. I really don't want to start crossing or tapping into wires. I have a humidifier control under the thermostat that we don't use and think one of the wires comes from the C wire in the furnace. Not wanting to swap wires either until I get the ok from the HVAC guy. May hold off until they come for their yearly cleaning and ask questions then. I don't really want one that turns on and off when we leave the house because we have pets and a kid that stays home when we go on date nights. Rather have it set on a schedule where we can manually tweak it on the phone. Heard Nest may cycle the furnace to draw power to charge the battery. Hoping it would get enough charge to not cycle the furnace to the point it put wear and tear on the unit that it may not need. They sell plug in adapters to substitute the C wire I could do, but then have to hide the wire since there is not a plug real close to the thermostat.
[Re: MI_Custumz]
#2878235
01/22/21 09:46 AM
01/22/21 09:46 AM
Posts: 1,025 NJ
EV2RTSE
NJ
I did read in the instructions that if you have any jumpers to not use them with the Nest- and this would seem to confirm that as well - https://support.google.com/googlenest/answer/9250973?hl=enSo installation should be as simple as Red to RH (or just R), Yellow to Y, Green to G, and White to W I believe power comes from red, are the batteries in your original thermostat just a backup for your settings possibly? It is fully programmable with the Nest app and you can do away with the turning on and off when you leave the house and just run it more like a regular programmable thermostat. I will be doing the same thing, as my wife is working from home all the time for now whereas I still go in to the office a couple of times per week. Not trying to sell you on one brand over another.
[Re: EV2RTSE]
#2878322
01/22/21 12:53 PM
01/22/21 12:53 PM
MI_Custumz
I did read in the instructions that if you have any jumpers to not use them with the Nest- and this would seem to confirm that as well - https://support.google.com/googlenest/answer/9250973?hl=enSo installation should be as simple as Red to RH (or just R), Yellow to Y, Green to G, and White to W I believe power comes from red, are the batteries in your original thermostat just a backup for your settings possibly? It is fully programmable with the Nest app and you can do away with the turning on and off when you leave the house and just run it more like a regular programmable thermostat. I will be doing the same thing, as my wife is working from home all the time for now whereas I still go in to the office a couple of times per week. Not trying to sell you on one brand over another. Was looking into the Emerson Sensi because it's like the one we have now, but with wifi. Battery operated and no C wire required, but not sure how long the batteries last. I usually change all house batteries twice a year when we change time for DST. https://www.homedepot.com/p/Emerson...Thermostat-for-Smart-Home-ST55/301231478Sam's also has the Nest Thermostat E on sale for like $80. Not sure if they still have them in stock. Leaning towards the Nest because it's been around and proven, but the Sensi has a 3 year warranty and may not need to cycle the furnace for power. Current thermostat loses settings and display when batteries are pulled. Not sure if it works or not without batteries. Never tried it.
[Re: John_Kunkel]
#2878545
01/22/21 06:23 PM
01/22/21 06:23 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I'm told you can run a wi-fi with four wires but you have to forego the continuous fan mode. IOW, the fan will only work in the AUTO mode. The module or the fan burnt up in my Trane so no A/C and gas furnace. Installed late 2007 every thing new as swapped from electric to gas. New everything even the ducts and pan. Still used the same type gray 4 wire to the stat. My friend since high school is my HVAC guy and close friend. He swapped the motor and module out and upgraded the thermostat and use the same 4 wires again when he swapped the parts. Took 5 10 min. To just pull it and stick the same 4 wires on. Is a Vive Comfort one and works well and is programmable like the OP asked about. Does all kids of stuff this old fart does not need.
[Re: sogtx]
#2878752
01/23/21 07:00 AM
01/23/21 07:00 AM
MI_Custumz
Should have 5 wires Nest will produce issues eventually without a C connection Had one for year at a customers with 4 wires . , worked great until it updated automatically Ran a proper wire , its working great now.
I recommend hw from Home Depot or Lowes Inexpensive . Easy app.
That one looks like it requires a C wire.
[Re: MI_Custumz]
#2879794
01/25/21 11:26 AM
01/25/21 11:26 AM
Posts: 2,252 New York
rarefish
New York
How would I check the wires for 24V of power? I have a electrical tester for plugs and wires, but that isn't sensitive enough to go off for the thermostat. I have a cheap Harbor Freight multimeter, but not sure where to put the black end. I would assume the red goes to the wire I'm testing, but not sure about the black. Also assuming the furnace wouldn't need to be running to see which one has constant power. Heat/cool ones should have power when running, but not when it's not running correct? To check for 24 vac at the T-Stat with a meter, you would need to have a common wire present. You should have "around" 24 vac between the Red wire found on the RH/RC terminal and usually a Black wire that would be found on the C terminal. A lot of older systems do not have the 5th wire aka "C Wire" available at the T-Stat. Reason is that it is not necessary unless you have to power a Smart T-Stat with 24 vac.
[Re: rarefish]
#2879857
01/25/21 01:27 PM
01/25/21 01:27 PM
MI_Custumz
How would I check the wires for 24V of power? I have a electrical tester for plugs and wires, but that isn't sensitive enough to go off for the thermostat. I have a cheap Harbor Freight multimeter, but not sure where to put the black end. I would assume the red goes to the wire I'm testing, but not sure about the black. Also assuming the furnace wouldn't need to be running to see which one has constant power. Heat/cool ones should have power when running, but not when it's not running correct? To check for 24 vac at the T-Stat with a meter, you would need to have a common wire present. You should have "around" 24 vac between the Red wire found on the RH/RC terminal and usually a Black wire that would be found on the C terminal. A lot of older systems do not have the 5th wire aka "C Wire" available at the T-Stat. Reason is that it is not necessary unless you have to power a Smart T-Stat with 24 vac. I have a humidifier that is wired under the thermostat. I think one of those is wired into the C wire in the furnace. I was hoping to test those to see if one has constant power and possibly use that for a C wire since we don't use the humidifier. The thermostat wiring has 6 wires, 4 for thermostat and 2 for humidifier. Just thinking about options on how to do it since I tend to rush into things and end up redoing them later.
[Re: MI_Custumz]
#2880117
01/25/21 08:20 PM
01/25/21 08:20 PM
rarefish
New York
How would I check the wires for 24V of power? I have a electrical tester for plugs and wires, but that isn't sensitive enough to go off for the thermostat. I have a cheap Harbor Freight multimeter, but not sure where to put the black end. I would assume the red goes to the wire I'm testing, but not sure about the black. Also assuming the furnace wouldn't need to be running to see which one has constant power. Heat/cool ones should have power when running, but not when it's not running correct? To check for 24 vac at the T-Stat with a meter, you would need to have a common wire present. You should have "around" 24 vac between the Red wire found on the RH/RC terminal and usually a Black wire that would be found on the C terminal. A lot of older systems do not have the 5th wire aka "C Wire" available at the T-Stat. Reason is that it is not necessary unless you have to power a Smart T-Stat with 24 vac. I have a humidifier that is wired under the thermostat. I think one of those is wired into the C wire in the furnace. I was hoping to test those to see if one has constant power and possibly use that for a C wire since we don't use the humidifier. The thermostat wiring has 6 wires, 4 for thermostat and 2 for humidifier. Just thinking about options on how to do it since I tend to rush into things and end up redoing them later. If you don't use the humidifier and more and the two wires for it are at the same location as the T-stat, then I would say, go ahead and use one of those wires for the T-stat "C wire". Back at the furnace, you will need to disconnect the two wires that are for the the humidifier and move the one that will be the T-stat "C wire" to the C terminal on your control board.
