Re: 4x4 440 motor mounts on a 1979 dodge w series
[Re: Joesixpack]
#2872567
01/11/21 02:16 PM
01/11/21 02:16 PM
Posts: 355 Sparks, Nevada
MoparMike23
Sparks, Nevada
I'm not sure on if the T-case makes a difference, but I recall there being a change in the engine cross memebers at one point. It might be 78' and newer had a beefier cross member, which could effect the mounts. Another thing, there are different engine mount brackets between 4wd and 2wd but I'm not sure how to tell the difference. Might be worth your time to check out www.ramchargercentral.com. There's way more info there. Mike
1969 Superbee 440-6 1977 D-150 Adventurer 2000 Jeep TJ 2018 Challenger Scat Pack Shaker 2019 Ram 2500 CTD
[Re: 440_Offroader]
#2873028
01/12/21 09:15 AM
01/12/21 09:15 AM
RWG75
RWG75
What he said mostly.
2wd and 4wd tin grilles do have different front cross members for suspension but they use the same mounts. They all have 2 sets of mount holes - small block, big block. Shiney mounts in first pic are big block, the hole in one of them being for the oil pump. Used ones look like small block and IIRC 318/360 use the same on one side, different on the other. there is a pdf of the 78-81 truck parts book somewhere on the net.
[Re: Joesixpack]
#2874418
01/14/21 06:43 PM
01/14/21 06:43 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
or are these the ones i need? Could you get me the measurement From the bolts holes to the mounting surface? So i can drill mine The narrow ones
