Question for the GenIII Swappers #2869471
01/05/21 07:09 PM
01/05/21 07:09 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Anyone here running a GENIII swap with a 727? If so, just curious as to how you addressed the Kickdown?
Abe Lincoln
Re: Question for the GenIII Swappers [Re: dart4forte] #2869477
01/05/21 07:36 PM
01/05/21 07:36 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
There is actually a section on here for Gen 3 Hemi, let me see if I can find it for you.............
Mo' Farts
Moderated by "tbagger".
Re: Question for the GenIII Swappers [Re: dart4forte] #2869510
01/05/21 09:32 PM
01/05/21 09:32 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
For a carb'ed application or for fuel injection/OE hemi intake?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Question for the GenIII Swappers [Re: A39Coronet] #2869528
01/05/21 10:24 PM
01/05/21 10:24 PM
BDW Offline
BDW  Offline
I'm curious about hooking up the OEM FI intake with a 518/727 KD
Re: Question for the GenIII Swappers [Re: A39Coronet] #2869530
01/05/21 10:27 PM
01/05/21 10:27 PM
Mesa, Arizona
Mesa, Arizona
Stock intake and FI
Abe Lincoln
Re: Question for the GenIII Swappers [Re: dart4forte] #2869535
01/05/21 10:59 PM
01/05/21 10:59 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I have seen it done by routing a lokar type kick down cable system to the gas pedal. So the movement of the pedal is what moves the kick down lever. I have a pic of the setup saved somewhere I’ll try to find.
1972 Road Runner
1988 Shelby CSX-T
Re: Question for the GenIII Swappers [Re: dart4forte] #2869540
01/05/21 11:27 PM
01/05/21 11:27 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Found it, not my pic and I can't remember where I found it to credit the person for the idea but I think it's pretty slick and simple.
1972 Road Runner
1988 Shelby CSX-T
Re: Question for the GenIII Swappers [Re: dart4forte] #2871299
01/08/21 07:21 PM
01/08/21 07:21 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
I modified the factory throttle body for a cable, I did not take pictures when it was apart. I use the factory TPS. Currently I have a ford 2 wire PWM as my IAC. I think I will switch to a chrysler unit as I see a machined block is available.
There was an electric unit to control kickdown when I looked into it years ago. I decided I would rather have a cable throttle.
87 dakota 6.1 hemi
Re: Question for the GenIII Swappers [Re: Glen440] #2871780
01/09/21 05:36 PM
01/09/21 05:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
On my 2001 Ram Van with the 5.9 it uses a cable to the throttle linkage (pass side) don’t see why that couldn’t be made to work unless you have fly by wire. Use the 03-5 truck TB, it had a cable TB
Re: Question for the GenIII Swappers [Re: cudaman1969] #2872641
01/11/21 03:51 PM
01/11/21 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Wrong, no cable driven factory gen III hemis
Re: Question for the GenIII Swappers [Re: HotRodDave] #2873912
01/13/21 06:50 PM
01/13/21 06:50 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
I just used a manual valve body in mine.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
