Big block exhaust valve/cylinder wall clearance #2869395
01/05/21 04:22 PM
01/05/21 04:22 PM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
Happy New Year to all! I have a 4.350" bore early iron mega block. I've been triple checking all clearances and fit of all parts before final assembly.I have measured (actual) clearance at gross valve lift, between the cylinder wall and the exhaust valve and come up with .030" at the closest point.I am fully aware of the shrouding effect it presents.My concern is this an acceptable operational clearance for a 7-7,500 rpm race only moto??. Relieving the top of the cylinder bore is out of the question as it is too close to the top ring territory.It was exactly why I didn't go with a 2.250 intake valve upgrade with Victor heads on this relatively small bore motor. Figured that the shrouding efffect of the bigger valve in that bore size would be an expensive cost with very minimal or no gain.All feedback welcome here. Seems acceptable to me but Imay be missing something here . Thanks in advance. Bill
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869404
01/05/21 04:38 PM
01/05/21 04:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
.030” radial clearance from the exhaust valve to the bore wouldn’t bother me.
Since the valve and bore are not on parallel lines...... and the direction that the valve is moving vs where it is in the bore...... as the lift increases, the clearance decreases.
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869461
01/05/21 06:46 PM
01/05/21 06:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How close?
Even a 1/16" radius will help some.
Boffin Emeritus
Re: Big block exhaust valve/cylinder wall clearance [Re: fast68plymouth] #2869481
01/05/21 07:55 PM
01/05/21 07:55 PM
iagree
I've ran less with no bent valves or witness marks on the valves or block, you should check all 8 exhaust valves in the head your going to use on the side of the block your going to run them on to make sure what you have on all of them twocents scope
Re: Big block exhaust valve/cylinder wall clearance [Re: polyspheric] #2869485
01/05/21 08:14 PM
01/05/21 08:14 PM
St.Pete,Florida
St.Pete,Florida
.030" was the absolute minimum radial clearance measured at full gross valve lift.I left the .023" valve lash as a cushion. With this I would have a few thousands more radial clearance. Top ring land is .250" down on the piston,and the piston is .020"in the hole.Not a lot of options here as the closest point of contact is not at the very top of the bore but near top ring territory making a die grinder taper not very effective at the point needed the most.
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869557
01/06/21 12:43 AM
01/06/21 12:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is that with a 2.19 intake valve ? Ron
Re: Big block exhaust valve/cylinder wall clearance [Re: 383man] #2869605
01/06/21 09:51 AM
01/06/21 09:51 AM
St.Pete,Florida
St.Pete,Florida
Ron, I am using the as supplied 2.20" int. & 1.81"exh. valves that came with the Edelbrock Victor heads w/ an extra half thou. guide clearance added per recommendation by Kris at Nelson Competition.Most race time will be during the the hot climate in Florida.My thoughts are that radial cyl. wall/exhaust valve clearance can be tighter than piston to valve radial clearance due to the fact that piston and aluminum rod growth don't enter the equation. I am "all good" with piston to valve clearance.Has anyone else used Edelbrock Victor heads on a big block with a 4.350 bore and .690" lift cam? Thanks, Bill
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869668
01/06/21 12:38 PM
01/06/21 12:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've often wondered about the notching of the top of the cylinder to match the contours of the cylinder head and the possible effects on flow related to this unshrouding. I would think there should be some video or technical papers of the flow changes by researchers somewhere.There were masses of research as far back as WW1 in the aircraft engine research files.
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869670
01/06/21 12:41 PM
01/06/21 12:41 PM
BigFish69 Offline
BigFish69  Offline
Yes I'm running 4.350 bore with victor mw port head .720 lift with no problems don't know valve to cylinder wall clearance 3400 with driver 6.00 in the 1/8
Re: Big block exhaust valve/cylinder wall clearance [Re: BigFish69] #2869672
01/06/21 12:52 PM
01/06/21 12:52 PM
St.Pete,Florida
St.Pete,Florida
Thanks all for the input.I know it is close but with the info at hand ,I believe I wil be good. Gonna roll with it. Bill
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2869912
01/06/21 05:45 PM
01/06/21 05:45 PM
A727Tflite Offline
A727Tflite  Offline
How much margin do you have to play with. You may be able to reduce the valve OD a smidge if you can’t sleep over the current clearance.
Re: Big block exhaust valve/cylinder wall clearance [Re: A727Tflite] #2870602
01/07/21 06:52 PM
01/07/21 06:52 PM
St.Pete,Florida
St.Pete,Florida
Re-installed heads w/only all the exhaust valves w/checking springs installed. No pushrods, and mechanically opened each valve to the maximimum valve lift that this camshaft has. This allowed me to turn the crankshaft get the throws out of the way for realworld accurate measurements between the cylinder wall and the exhaust valve. Sounds corny but used a measured paper clip as a wire gauge (.029") and each valve had very close to the same clearance allowing the paper clip to slide easily through between the wall and the valve. Increase the valve lift and the clearance goes away quickly.Not high tech but pretty darn accurate.I used .690" as my lift number. Ithink a.750- .800 lift cam (actual) would have trouble here in this 4.350" bore. I talked with the tech dept at Hughes engines,(where the heads were purchased and ported) and they said the've had no complaints at that bore.
Just doesn't look like any camshaft upgrades at this bore. Thanks for all the input here. Bill
Re: Big block exhaust valve/cylinder wall clearance [Re: lancer493] #2871737
01/09/21 04:14 PM
01/09/21 04:14 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
any chance you can move the heads up the block ? offset dowel pins .015-.030 " reduce the intake manifold with a side cut.... ? maybe move the valves // angles..
Re: Big block exhaust valve/cylinder wall clearance [Re: ek3] #2871802
01/09/21 06:29 PM
01/09/21 06:29 PM
St.Pete,Florida
St.Pete,Florida
I believe that can be an option, but would also need to recheck the radial clearance in the piston valve reliefs as this would be reduced by moving the heads upward. I am comfortable with the .030" clearance after a lot of research. Not a lot offered on this subject. I spent a lot of time on it.Glad, now that I didn't go to a much higher lift cam in that small bore Thanks all. Bill
