Re: 80’s or early 90’s MP “recipe” 440 build article
[Re: fast68plymouth]
#2867427
01/01/21 11:54 AM
01/01/21 11:54 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Who would ever have thought that a post about 80's and 90's technology would be the second or third most popular post on the first page of Moparts......7,100 views....lol
RIP Monte Smith
[Re: CompWedgeEngines]
#2867449
01/01/21 12:28 PM
01/01/21 12:28 PM
fast68plymouth
So. Burlington, Vt.
Well...... it does have two favorite items in the article. Iron heads and purple shaft cams. ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif)
[Re: Uberpube]
#2868882
01/04/21 02:42 PM
01/04/21 02:42 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
Keywords to increase views (an experiment to see what happens to the numbers)
Direct Connection Mopar Performance Pinion Snubber Slapper Bars Pinion Angle J converter M1 Torker TM7 TM6 Tunnel Ram
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2869077
01/04/21 09:00 PM
01/04/21 09:00 PM
Posts: 9,104 Rogue River, OR
Jeremiah
Rogue River, OR
I just scored a set of blue anodized Direct Connection valve covers for my '68 GTS. It has a cable drive tach and sounds like the old .533 juice or .557 solid cams : D
It's not a record setting pound on your chest all over yellow bullet combination. It's old school nostalgic fun for me. Back when things were simple and Sunoco 110 was like $2.75 a gallon out of the pump.
[Re: Jeremiah]
#2869091
01/04/21 09:23 PM
01/04/21 09:23 PM
Posts: 3,105 Michigan
A727Tflite
For me, it seems that the mid 70’s hot tip was still the Racer Brown SSH-25 or 44 hydraulic cams but the Purple Shaft cams of similar lift were gaining in popularity.
The GK cams like the A5H288B were kicka$$ cams too.
Had a Mini Express in my SS car in 1973, then went to the GK roller late that year and all of 74.
It’s a shame GK closed shop, Tewles and Brookshire where up there in talent equal to Crane and the others.
[Re: ZIPPY]
#2869155
01/04/21 11:48 PM
01/04/21 11:48 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
PAW B1 Thin wall 6 pack rods 3/4 race full race
[Re: Uberpube]
#2869225
01/05/21 10:10 AM
01/05/21 10:10 AM
ZIPPY
S.E. Michigan
PAW B1 Thin wall 6 pack rods 3/4 race full race ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) 800 views added overnight. Success or failure? You be the judge ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2869258
01/05/21 11:59 AM
01/05/21 11:59 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
PAW B1 Thin wall 6 pack rods 3/4 race full race ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) 800 views added overnight. Success or failure? You be the judge I think the answer to that is YES lol
68 Barracuda Formula S 340
[Re: lewtot184]
#2869273
01/05/21 01:01 PM
01/05/21 01:01 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It’s kinda funny and pathetic at the same time reading this and thinking back. The funny part is Direct Connection gave us the Bible on running anything from 8’s-14’s with junk parts. Lots of us were running high 9’s to low 10’s with factory heads, stock cranks, and TRW or Sealed Power heavy weight pistons with 2800-3200 pound cars and Super Stock springs. Now with stroker engines, cnc’d heads, lite-weight pistons, better tires, better suspensions, better traction at tracks, etc very few an put the total package to run fast at the track. Impressive DYNO numbers and somewhat pathetic track times. I see guys weekly that are t happy with their performance so instead of working to fix it throw a NOS kit on it. Laugh if you want at the old school ways but I know they had some pretty smart guys putting these packages together. Anyone look looking for those old cams may find them on their Dads parts shelves. I know I still have mine.
[Re: pittsburghracer]
#2869321
01/05/21 02:23 PM
01/05/21 02:23 PM
ZIPPY
S.E. Michigan
I resemble that remark ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) And yes, there is a .620 purple shaft in the basement just in case anyone wants one.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2869402
01/05/21 04:36 PM
01/05/21 04:36 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I resemble that remark ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) And yes, there is a .620 purple shaft in the basement just in case anyone wants one. I am porting a set of speedmaster heads for my son in Colorado and will be checking a couple purple shaft cams I have. I’m almost positive I have a 501 cam that they recommended for four speeds but hopefully have a 484 lift cam. He purchased a 340 so that would work perfect in the 1974 duster he is rebuilding. He just bought a J convertor while he was home from a buddy of mine. I’m trying to help as much as I can but I’m 2400 miles away.
[Re: ZIPPY]
#2869440
01/05/21 06:04 PM
01/05/21 06:04 PM
Posts: 3,505 DFW
mr_340
DFW
800 views added overnight. Success or failure? You be the judge Are the Dominion machines adding views at 3AM?
Floyd Lippencott IV
[Re: mr_340]
#2869626
01/06/21 10:46 AM
01/06/21 10:46 AM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I remember in the 80s and 90s all the magazine builds were 350 chevy. Even for a mild build the thing would get gold roller tip rocker arms. On the rare occasion a magazine did a mopar it got roller tip rockers when stamped steel would have been perfect. Applying that Hot Rod and Car Craft Chevy mentality to mopars. A set of Crane adjustable rocker arms for a chevy in 1988 was like $90. A set of Harland Sharps for a mopar was $350 plus but they still threw them on. Thats why the mopar magaazine builds that used OEM parts were so appealing. Real world.
Keep old mopars alive.
[Re: Steve1118]
#2869643
01/06/21 11:26 AM
01/06/21 11:26 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
You guys are speaking my lingo, John. This is the first thread I've seen where I knew what anyone was talking about..... Yeah, this thread has been fun to read and very familiar, bought my GTX in 1975 bone stock. With G60 14s and my granny shifting it ran a 15.20, it was my daily driver, first thing my "expert" buddy said was you need headers and a 4.56 gear in that thing...with headers, purple hornies, 7" cheater slicks and better shifting I managed to get into the low 14s. The funny/scary thing about this read is how many of these old parts I still have on my shelves ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
#2869699
01/06/21 01:59 PM
01/06/21 01:59 PM
Posts: 4,701 On the parachute mount
n20mstr
First time i might agree with you...lol In the early 90s i had a .030 over 440. lightly ported 906's .509 hyd cam, stock pushrods and rockers. Strip dominator and propart headers. that thing is shifted low enough LOL went 11.90's all day long. A plate with an .073 jet (175ish HP) went 10.40's. Yea it was real basic a lot of stock parts, and yea it was relatively fast back then
....BAD A$$ STREET CAR.....
