No start/dead circuit after leaving key on 74 Plymouth #2869063
01/04/21 08:18 PM
01/04/21 08:18 PM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
Hey y'all. Trying to track down a wiring issue on my 74 Barracuda after leaving the key in the run position by accident for at least 3 weeks. I went to move the car and found it, tried to start it and no go. Turns over but no spark with the Mopar msd 6al box. I tested the box and its good. For some reason when I rewired the engine bay of this car years ago I triggered the msd box in run off the oil pressure/gauge terminal, position 17 (g6?) in my bulkhead. I deleted all the unused circuits then and must have used it considering it was a free keyed 12v source? I also left the ballast for whatever reason. Anyway, Im sure I could trigger the box there but I really would like to know what I burned up leaving the key on. No blown fuses, no obvious burnt wires that I can see crawling under the dash. There is no power on the inside at the bulkhead on #17 either. I tried to track the circuit in a service manual but I don't totally understand where this goes, how it works. Anyone out there that can read wiring diagrams better than me and can explain it to a moron?
At first I thought it was ignition switch related but everything seems to be doing its job there. Non rallye cluster, no oil gauge etc
Thanks!
Stuff I own Self promotion Things someone else said I claim as my own
Re: No start/dead circuit after leaving key on 74 Plymouth [Re: 408cuda] #2869072
01/04/21 08:43 PM
01/04/21 08:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I didn't see where you charged the battery up. Might be the voltage is too low to allow the MSD to work. Charge the battery up and try again.
Re: No start/dead circuit after leaving key on 74 Plymouth [Re: Sniper] #2869073
01/04/21 08:47 PM
01/04/21 08:47 PM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
Sorry, forgot to mention good charged battery. every connection I could check is good. so far its the only thing affected but I haven't run the car off a new wire until I feel good about it. Thanks
Re: No start/dead circuit after leaving key on 74 Plymouth [Re: 408cuda] #2869089
01/04/21 09:20 PM
01/04/21 09:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might try a different coil, it may have overheated and cooked itself twocents
