Whos running 11s with a 5.7 NA? #2868907
01/04/21 03:51 PM
01/04/21 03:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Whos running 11s with an NA 5.7 and whats your weight and combination?
Re: Whos running 11s with a 5.7 NA? [Re: GTX MATT] #2869271
01/05/21 12:58 PM
01/05/21 12:58 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Re: Whos running 11s with a 5.7 NA? [Re: GTX MATT] #2869320
01/05/21 02:17 PM
01/05/21 02:17 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I ran my 73 Challenger a couple of times NA and ran 11.86 at 111.30 mph. The torque converter was loose and very inefficient. ET and MPH would have picked up with a converter adjustment.
2018 5.7 Hemi
Prefix Cascar Intake
Holley 1000CFM Throttle Body with Holley HP Engine Management
TSP Cam 226/235 .582" .582"
727 Trans 4600 stall 9 1/2" converter
4.10 gear
29.5" x 10.5" tire
3650 lbs
I have since added a Torq Storm supercharger and went 10.49 at 130 mph.
Re: Whos running 11s with a 5.7 NA? [Re: 416challenger] #2874966
01/16/21 01:50 AM
01/16/21 01:50 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Not an 11 second pass but very close.
1st time out in 100 F temps
12.01 @ 111
3525lbs race weight
5.7 eagle, SRT car headers, 209/216 @.050 crower cam and 6.4 intake manifold.
727 5k stall
4.88 gears and 28" tire.
Still a fair bit left in the tune
Re: Whos running 11s with a 5.7 NA? [Re: L4staero] #2875547
01/17/21 02:36 PM
01/17/21 02:36 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
12.01 @ 111
3525lbs race weight
727 5k stall
Are you still running the dual runners on that intake with all that stall and gear?
Re: Whos running 11s with a 5.7 NA? [Re: SRT6776] #2875617
01/17/21 04:18 PM
01/17/21 04:18 PM
Australia
L4staero Offline
L4staero  Offline
Australia
12.01 @ 111
3525lbs race weight
727 5k stall
ArAreolae you still running the dual runners on that intake with all that stall and gear?
I played with it using both lengths and just the short. It was much better with the long runner as well. Made it flash on the converter and hit the tire harder.
For 345 cubes it had the bottom end torque of a LA 408 stroker
Re: Whos running 11s with a 5.7 NA? [Re: GTX MATT] #2885723
02/09/21 12:08 AM
02/09/21 12:08 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
My 2014 Ram RCSB 4x2 ran a best of 11.19 @118 , weighed in at 3800 race weight with the 518 trans ...truck was a rolling tin can at that point.
engine : stock short block with Katech ported Edelbrock 61159 heads ,Custom Comp cam, .240/241 @ 50 635/.635, Edelbrock intake and BBK 100mm TB, ARH headers
truck went 11.60s with the 65rfe , swapped in an 8sp, dropped to 11.40s swapped in a cope built 518 and dropped to 11.19, rear gear on the 11.19 run was 4.88 , broke #6 & 8 piston crown, my uncle and I built a 441CI BGE for it but I sold the truck last winter
My 04 Ram, is my current "play truck" it's gone a best of 11.86 @ 120 weighing in at 4650 race weight. Short block has a 6.2 Hellcat crank with the nose trimmed to work with inn the 04 block . , Manley pistons and Rods, 6.24 C to C rods and Pistons are 597405CE with 9cc dome , each one hand fitted to it's corresponding cylinder chamber, cam is a custom Bullet grind , 250/250 @50 .645/.660 solid roller cam using modified Isky High seat SBC lifters , stock Rockers with smith brothers push rods ,Heads are Frankenstein Eagles that my uncle modified , he left the exhaust port as is changed the valves to custom SI , 2.15X6mm intake. 1.63 X 7mm exhaust , Chambers were then softened 7 degrees , Intake port floor lowered and roof filled in the match, also the sides were filled in from the push rod hump towards the entrance , angled milled the heads towards the intake side. Intake is a modified Holley race sniper , front was cut and welded to use a 2014 GT500 twin 65mm BBK TB Headers are custom 2 inch , dumping in to 3 in collector then back to spintech mufflers , trans is a 727 5k stall 4.88s in a 9.25 rear .
Made 3 passes last summer at Island over in NJ , 1st off the trailer was 11.90 @115 , next was 12.20 at 110, last pass was 11.86 @ 120.8.
Intake valve size is actually 2.165 , not 2.15 listed above.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: Whos running 11s with a 5.7 NA? [Re: Taylor] #2894645
03/02/21 02:51 AM
03/02/21 02:51 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Man 120 MPH is hauling at that weight, what are you running for tires?
Re: Whos running 11s with a 5.7 NA? [Re: GTX MATT] #2896335
03/06/21 12:59 AM
03/06/21 12:59 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
M&H 275/50R17 Drag radials , I was wrong about the Intake valve size, it's a 2.165 X6 MM
