Do they make a Gear drive F1R for the G3 yet? #2809573
08/16/20 08:01 PM
08/16/20 08:01 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Just curious, as I have not seen one....Would still need a 6.1 block.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: Dragula] #2809655
08/17/20 06:47 AM
08/17/20 06:47 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Like this? F3D106.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: fbs63] #2809945
08/17/20 09:14 PM
08/17/20 09:14 PM
Dragula Offline OP
Dragula  Offline OP
Yes wow! Isn't an F3 big for a G3? How long is that from the plate forward? Is that a SuperCharger Store Gear drive?
Re: Do they make a Gear drive F1R for the G3 yet? [Re: Dragula] #2810050
08/18/20 07:18 AM
08/18/20 07:18 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Its a ATF SPEED gear drive. They are the ones that made Rob Goss' gear drive. I made the engine mounting plate but they make it also. The F3D106 is an F2 with a higher gear ratio. 5.63 vs 5.4. I'll have to check the length.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: Dragula] #2810545
08/19/20 09:08 AM
08/19/20 09:08 AM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
The F3D-106 is basically a F1X with an F3 gear case so it's not as big as the traditional F3 series blowers. Also, most anyone that makes a gear drive makes one for a G3 hemi. Supercharger Store and Alston do for sure. I think the new one Procharger makes in house are offered for G3 also but I'm not sure. Rob Goss has the Alston version on his car.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Do they make a Gear drive F1R for the G3 yet? [Re: Runnoft] #2811694
08/21/20 04:54 PM
08/21/20 04:54 PM
Dragula Offline OP
Dragula  Offline OP
I want one, but I am not sure I want to cut up the car that much to put it in. Looks really long....
Re: Do they make a Gear drive F1R for the G3 yet? [Re: Dragula] #2811847
08/22/20 08:38 AM
08/22/20 08:38 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Yes, mines 18 1/2" from the front of the motor plate to the front of the blower. They use a different coupling now that's a little shorter. App. 1" total. Its in a 63 Dodge with the engine moved back as far as possible keeping the stock firewall location. You can see where it ends on the core support.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: fbs63] #2867900
01/02/21 12:21 AM
01/02/21 12:21 AM
Dragula Offline OP
Dragula  Offline OP
How is the build going?
Re: Do they make a Gear drive F1R for the G3 yet? [Re: fbs63] #2868693
01/03/21 11:24 PM
01/03/21 11:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That is awesome looking. but not sure what the gear drive upsides here are?
Care to share?
Re: Do they make a Gear drive F1R for the G3 yet? [Re: jcc] #2868759
01/04/21 08:02 AM
01/04/21 08:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The build is going slow. Built the headers (2 1/8 to 2 1/4 with 4" collector) and working on exhaust. Will be 4" aluminum with mufflers. The gear drive eliminates belt issues and allows a forward facing supercharger. Forward facing belt driven must be reverse rotation. The gear drive also allows 2 drive points for accessories.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: fbs63] #2868850
01/04/21 01:26 PM
01/04/21 01:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Thanks, are there performance advantages to "forward facing" or is mainly packaging?
Re: Do they make a Gear drive F1R for the G3 yet? [Re: jcc] #2868868
01/04/21 01:58 PM
01/04/21 01:58 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Basically the same as a sealed hood scoop. Fresh outside air.
Re: Do they make a Gear drive F1R for the G3 yet? [Re: fbs63] #3099942
12/05/22 09:15 PM
12/05/22 09:15 PM
Dragula Offline OP
Dragula  Offline OP
Any updates?
