Header Studs & Gaskets....Need some Help. #2867180
12/31/20 09:13 PM
12/31/20 09:13 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So I had new headers made with 2-1/8 to 2-1/4 tubes....With my old 2" headers I ran 3/8 studs in my aluminum heads in all positions. On my new ones, the middle two tubes I can't fit the larger nuts that close.The nuts hit the tubes....Is there any options to still run studs somehow?
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867182
12/31/20 09:18 PM
12/31/20 09:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Arp 12pt nuts? McMaster Carr also has 3/8studs stepped down to 5/16.
Or heat the tubes at the nut area and punch in some clearance.
Re: Header Studs & Gaskets....Need some Help. [Re: TRENDZ] #2867216
12/31/20 10:19 PM
12/31/20 10:19 PM
Dragula Offline OP
Dragula  Offline OP
I will check out the stepped ones from McMaster Carr....Hopefully those work....
Next question, where fo I get larger header gaskets? The TTI's don't fit, they are D shaped with the arch at the top and outside the flange, the Mancini remflex are too small...
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867230
12/31/20 11:00 PM
12/31/20 11:00 PM
Have you used or tried the Mr. Gasket M.W. header gaskets yet up scope
I used the 7/16, 3/8 or the 5/16 wrench size header bolts on my big tube step headers up scope
I haven't used the ARP 3/8x16 header studs though shruggy
Re: Header Studs & Gaskets....Need some Help. [Re: Cab_Burge] #2867231
12/31/20 11:05 PM
12/31/20 11:05 PM
Dragula Offline OP
Dragula  Offline OP
No, and Mr Gasket is like low on the list like Walmart. Most items I have purchased from them are just junk.
Seems switching to the larger headers is causing all my normal stuff to not fit.
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867241
12/31/20 11:27 PM
12/31/20 11:27 PM
Their, Mr. Gasket, Ultra seal header gaskets work good, not real cheap either shruggy
How about using the Rem Flex 440-1 copper header gaskets work Their oval shape, not round and not rectangular either scope
Re: Header Studs & Gaskets....Need some Help. [Re: Cab_Burge] #2867306
01/01/21 09:40 AM
01/01/21 09:40 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Looks late for this, but with them off, put a bolt through, and then progressively beat larger and larger tubes over it till you have room for the nut, The small dimples won't hurt a thing, except the finish lol.
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867343
01/01/21 10:57 AM
01/01/21 10:57 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Just use copper high temp RTV. Maddog header suggested it to me a few years ago and have had no issues with it yet. Let it set up over night and your good.
Re: Header Studs & Gaskets....Need some Help. [Re: dthemi] #2867429
01/01/21 11:57 AM
01/01/21 11:57 AM
Dragula Offline OP
Dragula  Offline OP
That has crossed my mind.....
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867431
01/01/21 12:03 PM
01/01/21 12:03 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
No gaskets needed . Red hi temp silicone and that’s all you need
....BAD A$$ STREET CAR.....
Re: Header Studs & Gaskets....Need some Help. [Re: Dragula] #2867450
01/01/21 12:29 PM
01/01/21 12:29 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Take some hex stock, and turn the hex to the o.d.you need. The oem manifold nuts were like this.
Re: Header Studs & Gaskets....Need some Help. [Re: Leigh] #2867659
01/01/21 04:29 PM
01/01/21 04:29 PM
moparx Offline
moparx  Offline
don't forget to split the flange between the front/rear tubes from the center tubes and drill one hole on each set of flanges a couple of drill sizes over.
this allows the individual pipe[s] to move around a little, helping a bunch to keep them sealed to the head.
i stole this idea years ago from mr. P-body, and it has done wonders for sealing, using gaskets or just plain hi-temp RTV.
works really well on thin flanges to keep them sealed up.
beer
