Re: Header Studs & Gaskets....Need some Help.
[Re: Dragula]
#2867182
12/31/20 09:18 PM
12/31/20 09:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Arp 12pt nuts? McMaster Carr also has 3/8studs stepped down to 5/16. Or heat the tubes at the nut area and punch in some clearance.
[Re: Dragula]
#2867230
12/31/20 11:00 PM
12/31/20 11:00 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
[Re: Dragula]
#2867241
12/31/20 11:27 PM
12/31/20 11:27 PM
Cab_Burge
Their, Mr. Gasket, Ultra seal header gaskets work good, not real cheap either ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) How about using the Rem Flex 440-1 copper header gaskets ![work work](/ubbthreads/images/graemlins/custom/work.gif) Their oval shape, not round and not rectangular either ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: dthemi]
#2867429
01/01/21 11:57 AM
01/01/21 11:57 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Looks late for this, but with them off, put a bolt through, and then progressively beat larger and larger tubes over it till you have room for the nut, The small dimples won't hurt a thing, except the finish lol. That has crossed my mind.....
[Re: Leigh]
#2867659
01/01/21 04:29 PM
01/01/21 04:29 PM
Posts: 19,628 north of coder
moparx
don't forget to split the flange between the front/rear tubes from the center tubes and drill one hole on each set of flanges a couple of drill sizes over. this allows the individual pipe[s] to move around a little, helping a bunch to keep them sealed to the head. i stole this idea years ago from mr. P-body, and it has done wonders for sealing, using gaskets or just plain hi-temp RTV. works really well on thin flanges to keep them sealed up. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
