Re: Big block swap
[Re: cudaman1969]
#2867710
01/01/21 07:12 PM
01/01/21 07:12 PM
Posts: 15,874 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life. Interesting. Are you talking piston slap or is that a different term?
Facts are stubborn things.
Re: Big block swap
[Re: larrymopar360]
#2867717
01/01/21 07:26 PM
01/01/21 07:26 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
So much to deal with. I need a shop around the corner that has done a couple. Mike, I have a high mount PS pump. Really prefer to stay 727 auto. I do love manuals with that granny gear, but my left leg gets tired quick and I want to drive it a lot. I read I'll need truck oil pan for sure. I really don't want to lift the truck anymore than stock (it does have bigger tires), but I did buy the "add-a-leaf" as recommended on another thread to level front with rear ( https://www.offroaddesign.com/1-zero-rate-add-a-leaf-kit-2-1-2-wide.html) so maybe that's enough for booster clearance. I want stock valve covers. I'm taking notes. I'm vacillating between built small block and the cubes of a big block with all the necessary mods/swaps. As written before, I really think I would need to buy a crate engine. I'll have enough to deal with just with peripherals.
Re: Big block swap
[Re: larrymopar360]
#2867813
01/01/21 09:46 PM
01/01/21 09:46 PM
Posts: 422 montana
BANDIT
montana
I think I may still have 1 or 2 truck oil pans laying around. Think I may have a high mount pump, also. now I'm curious, have to make a trip to farm and see what I do have. Jim EDIT I have 2 used pans, and 1 hi-mount P/S pump and bracket, if your still looking.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: Big block swap
[Re: larrymopar360]
#2867841
01/01/21 10:39 PM
01/01/21 10:39 PM
Guitar Jones
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life. Interesting. Are you talking piston slap or is that a different term? If you were to look at the stroker piston and a late model engine piston you would see it's not an issue. The stroker piston isn't really a short piston in comparison to engines built today. Let's do some math. The difference between a 4" stroke and a 3.58" stroke is .42". Half of that moves the pin up .21" . That is less than 1/4" . The only reason to shorten the skirt is for crankshaft counter weight clearance and maybe a little skirt to rod clearance. Again, not a big deal. I built a couple stroker small blocks and none of these were an issue. Shortening a skirt reduces piston weight and this is where most aftermarket and late model pistons save weight. If you were really worried about it you could use a 6" chevy rod then the pin height would only change .087" .
Re: Big block swap
[Re: Guitar Jones]
#2932592
06/12/21 07:02 PM
06/12/21 07:02 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I would love to get this parts vehicle I'm looking at online but I don't think it has any linkages. I have some more questions to ask. I wish I had room at my house for parts vehicle.
I'll update on parts vehicle and mancini stuff.
Re: Big block swap
[Re: larrymopar360]
#2932854
06/13/21 04:18 PM
06/13/21 04:18 PM
Posts: 16,820 Between Houston & Galveston TX
SattyNoCar
So, it's a factory BB truck missing its engine? Is it a 4wd truck? How hacked/trashed is the rest of the truck? As shown by moparmarks, with the right stock valve covers, a 440 will clear the booster, so this may not be a mandatory part. Any linkage present? A majority of the wiring is just a matter of extending a few wires. I'd take a quick inventory at what that parts truck has on it and do a little comparison shopping. You might be able to sell off/scrap what's left of the parts truck when you're done to offset costs. If you're buying it JUST for booster and mounts, go aftermarket.
John
Re: Big block swap
[Re: SattyNoCar]
#2932858
06/13/21 04:22 PM
06/13/21 04:22 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
John no engine. I'm waiting to hear back if the linkages are there. He said he would go out and look after rain stopped.
Re: Big block swap
[Re: larrymopar360]
#2932862
06/13/21 04:29 PM
06/13/21 04:29 PM
SattyNoCar
OK. You mention 'linkages', if you're retaining the same style transmission, the main thing that is different is the kickdown and throttle cable bracket. On my truck, the kickdown from the car was a one piece rod that wouldn't clear the firewall. The 400 truck had a two piece (three piece?) kick down. Not sure how well an aftermarket kickdown cable would work instead.
John
Re: Big block swap
[Re: SattyNoCar]
#2932873
06/13/21 05:14 PM
06/13/21 05:14 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yes I'm sorry I should be referring to it as "kickdown". I don't hear great things about Bouchillan cable. Maybe I can find a used one out there to buy.
Re: Big block swap
[Re: larrymopar360]
#2932983
06/13/21 10:12 PM
06/13/21 10:12 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
If the engine is gone don't count on the engine mounts still being there. Plus you'll still need the oil pan and pick up, trans linkage, manifolds, etc.
1981 Dodge D150 360 auto
Re: Big block swap
[Re: basketcase]
#2934203
06/17/21 11:25 AM
06/17/21 11:25 AM
Posts: 70 Souderton
Taylor
Souderton
If the engine is gone don't count on the engine mounts still being there. Plus you'll still need the oil pan and pick up, trans linkage, manifolds, etc. Agreed , I doubt any of that is there . Any BB 3 piece kick down set up will work ,probably better off buying the parts separate. the booster is the same for the HD trucks 200(250)300(350) trucks
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi 2020 1320 Challenger....stock daily driver.
Re: Big block swap
[Re: cudaman1969]
#2934812
06/19/21 11:39 AM
06/19/21 11:39 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
“Any BB 3 piece kick down set up will work” Good to know Yeah! Scratchn was just telling that! Much rather have that than Bouchillon cable
Re: Big block swap
[Re: larrymopar360]
#2935037
06/20/21 12:49 PM
06/20/21 12:49 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Okay, I'm going to place order for BB any day now. I'm ready to order. I MUST get a complete engine assembly. I cannot build one myself. I see Blueprint engines does not have big blocks. I probably would've considered them. I don't like what I've read recently on CME's. Edelbrock only has two Mopar crates both Gen3 426 c.i.d. Mopar Performance doesn't even have an assembled crate engine 440. So two questions really; I'm thinking I should get a RB right? Or should I be thinking just BB? 2nd question; is there a slam dunk crate engine builder right now? What am I thinking? Standard bore 440, edelbrock aluminum heads and intake, probably roller cam setup and smooth idle don't want real lopey cam. Not looking to make racer out of truck and will have stock valve covers and Chrysler blue paint. Thanks. Anyone familiar with Blue Monkey Performance Parts in AZ? https://www.ebay.com/itm/123999898830?
Re: Big block swap
[Re: redraptor]
#2936311
06/24/21 08:19 AM
06/24/21 08:19 AM
Posts: 15,487 Florida
scratchnfotraction
Do those stock manifolds flow ok or get to hot? I thought they were ok, but, no one here likes stock manifolds. I didn't mind mine either but did swap to 2 center dump and ditched the rear dump on pass side. that makes it flow about as equal as you can get for manifolds. BUT I have the hedman 79250 headers now and would not go back to manifolds.
