Exhaust pipe flange gasket what size? #2865119
12/27/20 01:08 AM
12/27/20 01:08 AM
BlueRacer69 Offline OP
Hey guys I need to order 2 exhaust pipe flange gasket, but don't know the correct size to get. Are they 2 1/4" or 2 1/2". Car is a factory 69 383 Dart GTS. Car has a aftermarket 2 1/4" exhaust system. Thanks for the help.
Re: Exhaust pipe flange gasket what size? [Re: BlueRacer69] #2865239
12/27/20 01:18 PM
12/27/20 01:18 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Go to the local parts store and buy both then just return the ones you don't use. shruggy
Re: Exhaust pipe flange gasket what size? [Re: stumpy] #2865887
12/28/20 09:56 PM
12/28/20 09:56 PM
I'd like to order these gaskets online. So does anyone know the correct size? Does it go by the size of the exhaust head pipe? Thank you.
Re: Exhaust pipe flange gasket what size? [Re: BlueRacer69] #2865904
12/28/20 10:56 PM
12/28/20 10:56 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Factory was 2 1/4".
Re: Exhaust pipe flange gasket what size? [Re: BlueRacer69] #2865929
12/29/20 12:07 AM
12/29/20 12:07 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
2-1/4 sound correct.
You're ordering stock gaskets so it shouldn't be an issue.
Rock auto exhaust flange gaskets.
The most expensive ones are literally only $1.66 each, I'd be buying extras. laugh2
Re: Exhaust pipe flange gasket what size? [Re: SNK-EYZ] #2866162
12/29/20 07:15 PM
12/29/20 07:15 PM
Thanks guys. Now, does anyone here know what the factory size tailpipes were on a 68-69 big block Dart? I'm thinking they were smaller then the exhaust head pipes, but not sure.
Re: Exhaust pipe flange gasket what size? [Re: BlueRacer69] #2866501
12/30/20 02:37 PM
12/30/20 02:37 PM
Anyone know the answer?? Where's rinodart when you need him. grin He should know.
Re: Exhaust pipe flange gasket what size? [Re: BlueRacer69] #2866935
12/31/20 12:29 PM
12/31/20 12:29 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Factory tailpipes were a two piece welded unit. 1969 units front half exiting from the mufflers were 2-1/4” O..D. The rear half was 2” O.D. which was slid into the front 2-1/4” section and welded. The rear where the exhaust extension was attached was opened to 1-7/8” I.D. for the chrome extension to slide into. By the time the exhaust exited the hole in the exhaust extension it was only 1-5/8” I.D. Not much flow. Big block tailpipes and 340 tailpipes were the same units. In 1968 the tailpipes were 2” O.D. exiting the mufflers and sized down to 1-7/8” at the rear. 1967 Big block tailpipes were also 2” but were only turndown style without extensions. Hope this helps.
https://www.accurateltd.com/One-Pair-of-Tail-Pipes-for-tips--225-or-250-A-Body_p_202.html
Pictures are on this page. Click the thumbnails on the RS of the page.
Re: Exhaust pipe flange gasket what size? [Re: Tom Swope] #2867122
12/31/20 07:25 PM
12/31/20 07:25 PM
Thanks Tom, You've been a great help. up
