Re: More race truck progress
[Re: Flipper1938]
#286701
06/17/09 12:52 PM
06/17/09 12:52 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Thanks guys Its really working out pretty good. my $50.00 swapmeet headers fit great, you can get at the plugs easy and the headers can be removed real easy, I fit the radiator and that fits perfect too I made the template for the engine plate larger to so It will hook to the front roll bars at the top. Ron...
getting some more done on the race truck
[Re: Mopar Ron]
#286703
06/29/09 02:10 AM
06/29/09 02:10 AM
Mopar Ron
I have a little bit more finished up. I cut the bed side out for tire clearance and mocked up the fender. I made a cardboard hood scoop to get a pattern for the one I want to make for it. My friend Curt milled out the front engine plate and I fitted it to the engine. it fits great . here are a few pics. Ron..
Re: getting some more done on the race truck
[Re: Robbins]
#286705
06/29/09 10:39 AM
06/29/09 10:39 AM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Looks great Ron! I would make sure that you are able to remove the rear tires without to much trouble. I am assuming that you will have long wheel studs. They can make it tuff sometimes. I've seen where guys have had to either deflate the tire to get it off, or remove the lower coil over bolt and drop the rear suspension to be able to remove the tires. Keep coming with the pics! Arno
[Re: deansrr]
#286709
05/29/10 12:53 AM
05/29/10 12:53 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
RON very kool, dont know how i missed this topic,,your card board scoop sorta looks like a shelby scoop used on the 05-09 mustang and the ac cobra,, it looks great,,you may want to check out one of those as to not building one,,,
and yes tire fitment issues,,ill try posting a pic,,33 tall x 22 wide radials on stock early A wheel wells,, only have to deflate the tire if the car is high enough off the ground rear end hanging on the 4 link and shock,,the key is a rounded side wall tire,,,hoosiers and a few others have a rounded side wall like a dirt roundy round tire,,mickeys have a more squared off side wall making it harder to get a big tire on and off
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Mopar Ron]
#286711
05/31/10 11:08 PM
05/31/10 11:08 PM
fstfish66
levittown pa
RON that thing is wicked looking
[Re: fstfish66]
#286712
06/02/10 10:44 PM
06/02/10 10:44 PM
Mopar Ron
Thanks Don, It's good to be working on it again, I dropped off the rear end today to be narrowed and we removed the front end and the hood and I am starting to figure out the firewall and start doing the floor and the body should be finish sand blasted tomorrow Ron...
[Re: Mopar Ron]
#286715
06/04/10 12:10 AM
06/04/10 12:10 AM
fstfish66
levittown pa
more pics,,, more info on this build,,,kool
