Page 3 of 7 1 2 3 4 5 6 7
Re: More race truck progress [Re: GOT6PAK] #286697
06/14/09 06:36 PM
06/14/09 06:36 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
I made up the elephant ears pattern and fit the headers, I moved the engine forward about 1/2" and down about 1 1/2" to get things to line up better.
Re: More race truck progress [Re: GOT6PAK] #286698
06/14/09 08:58 PM
06/14/09 08:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I like it ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: More race truck progress [Re: Mopar Ron] #286699
06/17/09 09:50 AM
06/17/09 09:50 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
It's Looking Good Ron!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: More race truck progress [Re: Mopar Ron] #286700
06/17/09 11:48 AM
06/17/09 11:48 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
It looks like it is supposed to be there.
Re: More race truck progress [Re: Flipper1938] #286701
06/17/09 12:52 PM
06/17/09 12:52 PM
Thanks guys
Its really working out pretty good.
my $50.00 swapmeet headers fit great,
you can get at the plugs easy and the headers can be removed
real easy, I fit the radiator and that fits perfect too
I made the template for the engine plate larger to
so It will hook to the front roll bars at the top. Ron...
Re: More race truck progress [Re: Mopar Ron] #286702
06/19/09 02:19 AM
06/19/09 02:19 AM
I got the dr rear fender shortened now.
these fenders are off a 50 dodge PU and they have like a 33"
opening and I felt it was to large so I cut 2" out of the middle to shrink it a little and welded it back together. Ron...
here is the stock fender:
and now 2" smaller:
getting some more done on the race truck [Re: Mopar Ron] #286703
06/29/09 02:10 AM
06/29/09 02:10 AM
I have a little bit more finished up.
I cut the bed side out for tire clearance
and mocked up the fender.
I made a cardboard hood scoop to get a pattern for the one I want to make for it.
My friend Curt milled out the front engine plate and
I fitted it to the engine.
it fits great . here are a few pics. Ron..
Re: getting some more done on the race truck [Re: Mopar Ron] #286704
06/29/09 09:27 AM
06/29/09 09:27 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Cool.
Moparlee
Re: getting some more done on the race truck [Re: Robbins] #286705
06/29/09 10:39 AM
06/29/09 10:39 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Looks great Ron!
I would make sure that you are able to remove the rear tires without to much trouble. I am assuming that you will have long wheel studs. They can make it tuff sometimes. I've seen where guys have had to either deflate the tire to get it off, or remove the lower coil over bolt and drop the rear suspension to be able to remove the tires.
Keep coming with the pics!
Arno
Re: getting some more done on the race truck [Re: B1arno] #286706
06/29/09 11:40 AM
06/29/09 11:40 AM
good thinking arno
these tires are only for lineup, they are 31 tall
the ones I am going to run are 12" wide and 29.3 tall
so yes I will make sure I can get them off easily Ron...
Re: getting some more done on the race truck [Re: Mopar Ron] #286707
05/28/10 02:36 PM
05/28/10 02:36 PM
just a little update on the race truck and roadster PU projects. the Dana is now out of the truck, now that I have my measurement to get it narrowed, (I will drop it off Tuesday to be narrowed) and I cut the grill opening out and trimmed down the 58 ford grill to start fitting it to the willys nose
I also picked up a very clean "B" body 8 3/4 for the roadster PU and the body is at the sand blasters and should be done today or tuesday
I have been working on overkilling the frame for the roadster PU as you can see by the pictures
so anyway some work is getting done on both projects and that feels good to be going forward Ron...
I still need to finish up the back of the frame:
8 3/4 and roadster PU frame(upside down)
Re: getting some more done on the race truck [Re: Mopar Ron] #286708
05/28/10 05:01 PM
05/28/10 05:01 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
looking GOOD, I love seeing projects like this
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: getting some more done on the race truck [Re: deansrr] #286709
05/29/10 12:53 AM
05/29/10 12:53 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
RON very kool, dont know how i missed this topic,,your card board scoop sorta looks like a shelby scoop used on the 05-09 mustang and the ac cobra,, it looks great,,you may want to check out one of those as to not building one,,,
and yes tire fitment issues,,ill try posting a pic,,33 tall x 22 wide radials on stock early A wheel wells,, only have to deflate the tire if the car is high enough off the ground rear end hanging on the 4 link and shock,,the key is a rounded side wall tire,,,hoosiers and a few others have a rounded side wall like a dirt roundy round tire,,mickeys have a more squared off side wall making it harder to get a big tire on and off
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: getting some more done on the race truck [Re: fstfish66] #286710
05/29/10 11:35 AM
05/29/10 11:35 AM
here are some pics out side with the new wheels before i took it apart
Re: getting some more done on the race truck [Re: Mopar Ron] #286711
05/31/10 11:08 PM
05/31/10 11:08 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
RON that thing is wicked looking
2015 cherokee
2013 R/T classic
Re: getting some more done on the race truck [Re: fstfish66] #286712
06/02/10 10:44 PM
06/02/10 10:44 PM
Thanks Don, It's good to be working on it again,
I dropped off the rear end today to be narrowed
and we removed the front end and the hood and I am starting to figure out the firewall and start doing the floor and the body should be finish sand blasted tomorrow Ron...
Re: getting some more done on the race truck [Re: Mopar Ron] #286713
06/03/10 10:00 AM
06/03/10 10:00 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Ron Your Work is Fantastic...love seeing the progress
What was I thinking....
Re: getting some more done on the race truck [Re: 72blubird] #286714
06/03/10 01:51 PM
06/03/10 01:51 PM
Amherst , Ohio
1972cudaguy Offline
Basement Office
1972cudaguy  Offline
Basement Office
Amherst , Ohio
super cool you took bits & pieces and really made something !!!
looking forward to further progress
Re: getting some more done on the race truck [Re: Mopar Ron] #286715
06/04/10 12:10 AM
06/04/10 12:10 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
more pics,,, more info on this build,,,kool
2015 cherokee
2013 R/T classic
Re: getting some more done on the race truck [Re: Mopar Ron] #286716
06/08/10 01:27 AM
06/08/10 01:27 AM
Torrance, Ca
Fig Offline
Fig  Offline
Torrance, Ca
Hi Ron,
It's commng along great! Who do you use for sandblasting? My buddy needs his roadrunner blasted and he lives in Ramona. I need to get back to Barona!!!!
Thanks!
1937 Plymouth R/S Coupe
440/727
