Page 2 of 3 1 2 3
Re: To Clutch fan or Not to Clutch fan [Re: Sniper] #2865596
12/28/20 09:34 AM
12/28/20 09:34 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Originally Posted by Sniper
Originally Posted by 360view
This graph show the viscous clutch on the original Mopar 340 V8
Doubtful, the 340 isn't a 5.7L. More likely it's a SBC.
No, I have read those two footnotes and the fan/viscous data is from a Society of Automotive Engineers (SAE) on the then new 340 V8.
Some of the generator shaded area in the graph showing variation is from a SBC 350
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2865602
12/28/20 09:49 AM
12/28/20 09:49 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You'd think the SAE would know the difference between a 5.6 and a 5.7l engine. Of course one wonders where they found a 350 with a generator since they started using an alternator in 65 and the 350 came out in 67. Basic mistakes like that makes you doubt the data.
Re: To Clutch fan or Not to Clutch fan [Re: Sniper] #2865635
12/28/20 11:47 AM
12/28/20 11:47 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted by Grizzly
FFS's electric.Try ZERO horsepower loss. What is wrong with you people? shake_head
Except for the HP to run the alternator to run the fan, no free rides out there.
As long as you stay moving Sniper. My electric fan never runs. up
Mo' Farts
Moderated by "tbagger".
Re: To Clutch fan or Not to Clutch fan [Re: Grizzly] #2865642
12/28/20 11:58 AM
12/28/20 11:58 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Clutch or not to clutch.
Just how much gain is there to be had by a clutch?
Are you running pro stock where every last horse power needs to be there?
For me, a failing fan clutch is one less thing I have to worry about failing down the road. Be it a torgue drive or temp controlled IMO makes no difference. Sooner or later it will fail.
Ive heard the argument a direct drive fan is noisier , I'll call BS to that . Mine inst loud at all and I assure you I can not hear it windows open or closed, I surely cant hear it going down the road
Re: To Clutch fan or Not to Clutch fan [Re: DrCharles] #2865698
12/28/20 02:17 PM
12/28/20 02:17 PM
moparx Offline
moparx  Offline
Originally Posted by DrCharles
So I went to Contour fans and a PWM controller. No problem stirthepot
what controller did you use ? TIA.
beer
Re: To Clutch fan or Not to Clutch fan [Re: gtx6970] #2865716
12/28/20 02:47 PM
12/28/20 02:47 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Always room for one more opinion. Even when that opinion is the complete opposite of all the other posters.
Master, again and still
Re: To Clutch fan or Not to Clutch fan [Re: DaveRS23] #2865750
12/28/20 03:37 PM
12/28/20 03:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
So,,,,,,Just how much is to be gained by adding a clutch fan over a direct drive fan ? Anyone done a side by comparison
is the blade pitch any different between the 2 styles of fans
The diam and blade count is the same. Then makes since the only gain is horsepower. So whats the side by side comparison ?
Re: To Clutch fan or Not to Clutch fan [Re: gtx6970] #2865789
12/28/20 05:12 PM
12/28/20 05:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Other than keeping original is there any good reason not to do an electric? If your rad and cooling system is up to par the electric should never kick on unless you're sitting in traffic.
Re: To Clutch fan or Not to Clutch fan [Re: gtx6970] #2865863
12/28/20 08:52 PM
12/28/20 08:52 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
It is not a big deal nor is it worth arguing about. Virtually all OE manufacturers went to the clutch fan as they became available and cost effective. Especially our Mopars. If you want to live in the pre-68 +/- era, that is your prerogative. For the rest of us, post '68 with a clutch fan or post '85 +/- electric fan is the way to go.
Your opinion goes against 50+ years of experience for the OEs and most posters here. And you are welcome to it.
Re: To Clutch fan or Not to Clutch fan [Re: gtx6970] #2865894
12/28/20 10:12 PM
12/28/20 10:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
There are no simple answers to your question as the size, pitch and number of blades all come into the equation. Normally a Clutch fan will have a more aggressive draw when engaged than a non clutch version but only drains the power when it's needed. The non clutched version on the other hand is a constant drain on the output of the motor whether it's needed or not.
I believe when people say a direct drive is noisier they are likely referring to an aftermarket flex fan some which can be very noisy.
If I remember correctly articles in the past have claimed a 7-10 hp difference on a healthy V8
A post over at A bodies only claims a 15 HP difference was verified on a dyno, I'd like to see the article as the only way to confirm that is if they used the same exact fan w and w/o a clutch and repeated the test several times
LINK TO A BODIES POST
beer
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2866161
12/29/20 07:07 PM
12/29/20 07:07 PM
USA
3
360view Offline
360view  Offline
3
USA
Some of the 18 wheel trucks now use fan clutches that you can engage or disengage electrically.
I would not mind trying one of those.
I liked my experiments running without any radiator fan,
except the one time I hit a near traffic stall on an Atlanta ring road
during hot weather when I wanted the AC to have airflow while barely inching along.
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2866285
12/30/20 12:55 AM
12/30/20 12:55 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Try running that big 7 blade fan without a clutch at 6000 rpm or more. You will be wasting 40 horsepower if the belt stays on. A fan clutch is the next best thing to electric. Better than a flex fan. On some cars, electric look/sounds too stupid, so you need mechanical.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2866290
12/30/20 01:14 AM
12/30/20 01:14 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I tried the electrically engaged Horton on my '96 Diesel Dually, I saw NO gains at all. When engaged it was NOISY. Later I got an FL-60 w/ Cat 3126, 250hp with a viscous thermostatically controlled fan. I went back to stock and sold the Horton. I'd like to try the Mercedes electric setup but don't really want to upgrade my '60's electrical system to deal with it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2866296
12/30/20 02:07 AM
12/30/20 02:07 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Mack has had that since at least 1980. I would turn the fan on when going down hill and use it for braking and max cooling then over-ride the fan and shut it off when climbing the other side. Yes, I said "braking": that's how much power that fan is making when it's locked up. Speaking of brakes, if the water temp was too much and you still had hill left to climb and had to switch the fan back on, it was like tapping the brake. blush
I took my fans off all my Rams. One has an electric and I never use it. But, I don't have gridlock to deal with either.
Carry on with your debate about clutch vs solid...........I'll stick with my electric or no fan at all. Less water pumps to replace too because that heavy turd is not beating on that little bicycle bearing that's in the water pump (which fails every time)
And Joel, yes, I agree with you the electric fan looks stupid on a vintage car, especially to folks like you and I that appreciate a stock appearance. But the benefits out-weigh the esthetics. Hide it inside the rad shroud, that's what I do.
Mo' Farts
Re: To Clutch fan or Not to Clutch fan [Re: 3hundred] #2866362
12/30/20 10:06 AM
12/30/20 10:06 AM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I ran the Mercedes fan on a blown Hemi A body I built a few years ago. There was no room for any kind of mechanical fan. It did a great job of cooling. I would have one on my Cuda today, but the clutch fan does a good job and I like the period correct look.
The only down side with the clutch fan was when I ran the KOS races at the local track. It was tough to keep the engine as cool as I wanted while sitting in the staging lanes when we hot lapped. No overheat issues, just wanted the engine cooler at the line.
Re: To Clutch fan or Not to Clutch fan [Re: gtx6970] #2866365
12/30/20 10:17 AM
12/30/20 10:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, I've run nothing but 5-7 blade fixed fans for decades on my toys, no complaints, then again for those that can hear their fan over their exhaust note, then their not driving a real "musclecar" in the first place....
Re: To Clutch fan or Not to Clutch fan [Re: DAYCLONA] #2866391
12/30/20 11:22 AM
12/30/20 11:22 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Who would have thought you could this much discussion over a fan?
Well it has been raging for many years and there is no definitive answer.
Form over function, stock or custom, how hot is too hot?
Most cars and trucks work well ‘most of the time’ with any fan type.
The poo hits the fan fan when it’s a hot windless day and you hit a JAM!
I haven’t daily driven a Mopar for many a year, but I have friends who do.
One uses an Ali rad with an electric fan and the other has an original rad and clutch fan.
Both live in around the biggest car park in Europe called the M25 motorway... violin
Well on the whole, they both do OK most of the time... panic
Once the engine gets really hot, it’s real hard to get the heat back out with an all iron engine... help
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: To Clutch fan or Not to Clutch fan [Re: Gtxxjon] #2868349
01/03/21 02:50 AM
01/03/21 02:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The one thing about the Mopar thermostat controlled clutch fan is how they say it will give more HP. Thats true when the fan is not kicked in but when the car is hot the fan will kick in until you pick up enough speed to get enough air through the rad. I know I remember my 83 Ramcharger with a 318 and clutch fan and AC would engage when I sat at a redlite for a minute or two in 80 plus temps. Then when I took off and got to third gear it sounded like it was still stuck in first or second as the fan was screaming. After about a mile at 65 mph it would disengage and then you did not hear it. And they work fine on the street but for a street strip I think the RPM style clutch fan may work best as it just slips more as the rpm goes up. I always thought if I was racing my car and had to wait for someone at the line and my car hit 180 or more the clutch fan may kick in and rob some HP when I take off. confused Course I dont know how much it would kill in HP but it seems the RPM would work best for that. Ron
Re: To Clutch fan or Not to Clutch fan [Re: 383man] #2868545
01/03/21 04:44 PM
01/03/21 04:44 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
It is all about trail and error. If you are a car show groupie then run a clutch and you can not hear it when the car is shut off. I have run and electric water pump drive on my motor on the street cooled ok but was a better choice for the track. Right now I run a 26 inch nice clean factory rad, mated water pump and housing rad has the shroud.I do not run a clutch on my factory 7 blade fan. I also have a hi flow thermostate 160. It is a 430 ci Hemi and it is more than stock and see a lot of RPM. Mech. gauge shows 163 degrees.I have driven it in 90 plus degrees and it still runs 163. I can see on the gauge move when the 160 opens up. These clutch fans have some noise to them so you might have to live with it. I have seen more than one fan come apart at the track so High RPM might not be a good thing for the factory clutch. Your choice of what you use, some times there is no answer to your question until you play with parts.
1971 HEMI E BODY REGISTRY
Re: To Clutch fan or Not to Clutch fan [Re: hemicar1971] #2868928
01/04/21 04:41 PM
01/04/21 04:41 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
With a clutch fan, I run the lighter weight aluminum 7-blade fan.... saves a little weight from the common steel blade fans that are with most clutch fans.
twocents
Page 2 of 3 1 2 3
