How much timing chain stretch before a - .005 set ? #286606
04/12/09 11:12 PM
04/12/09 11:12 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I have about a 1/8 inch play in and out(each way), should I try a - .005 timing chain set? I know I want it tighter, just not sure if this qualifies for the shorter set? It's a Big Block. Thanks.
Re: How much timing chain stretch before a - .005 set ? [Re: 4404dart] #286607
04/13/09 11:32 AM
04/13/09 11:32 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Here is a bump for you.
By the way,is that rust on your cam gear,or some sort of grease?
Re: How much timing chain stretch before a - .005 set ? [Re: 4404dart] #286608
04/13/09 11:48 AM
04/13/09 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest I dont think you could get the shorter
chain on, its designed for a block that the mains line bored,
moving the crank closer to the cam. That being said,
if you measure the distance now then move the cam
gear up by .005 (with the chain on)would tell you
if you could get away with the shorter chain. You
might have to do this off of the engine. But if you
look at the amount of slack you have now and split
that in half thats, it would be if you have the
shorter chain... without even going to the short
chain
Re: How much timing chain stretch before a - .005 set ? [Re: MR_P_BODY] #286609
04/13/09 11:52 AM
04/13/09 11:52 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
That looks awful tight already...Which is ok.
Re: How much timing chain stretch before a - .005 set ? [Re: B1MAXX] #286610
04/13/09 05:27 PM
04/13/09 05:27 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Most new sets I've put on have that much play when new. I'd be more worried about what's under that bandaid! Heh, man, I have a lot of bandaid shots as well! lol
Re: How much timing chain stretch before a - .005 set ? [Re: polkat] #286611
04/13/09 06:27 PM
04/13/09 06:27 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
if this makes you feel any better......
I have a Cloyes true roller set on my engine, it has at least 400 paSSES on it, and prob a couple thousand street miles. I just bought the chain only and the old one was so loose that the cam was 4* advanced with the new "tighter" chain. It still has a lil slack even new LOL
Maybe they have slack in them becasue.....DID you all know that a BigBlock Chevy is the SAME chain???? Yea, the same chain fits BB Chevy AND mopar sets...LOL
It looks like your fine with that chain, i like to oil them with nice sticky STP before putting the cover on
....BAD A$$ STREET CAR.....
Re: How much timing chain stretch before a - .005 set ? [Re: Dunnuck Racing] #286612
04/13/09 08:33 PM
04/13/09 08:33 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
It's an optical illusion? No it's the set from last year, but when I installed it on the other motor, it had about the same play. I ordered the same progear set, and was told the same thing as what you guys are saying, " fergetaboutit". I thought it was a little loose, but I guess not. Thanks to all that replied!
Re: How much timing chain stretch before a - .005 set ? [Re: 4404dart] #286613
04/13/09 08:55 PM
04/13/09 08:55 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
I usually only run an undersize set after a line hone is done (they usually need it) ...your tension looks about right to me on the "slack side", the driver's side will stay in tension, how's your valve timing look, actually a little retard at high RPM can be good for power
WIZE
In Car:
Re: How much timing chain stretch before a - .005 set ? [Re: Streetwize] #286614
04/13/09 10:29 PM
04/13/09 10:29 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks! As usual, I feel better after a few replies to a question.
