Re: Powerglide Transmission - 727 filter Question
[Re: 440Jim]
#2866118
12/29/20 04:45 PM
12/29/20 04:45 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
My Ultra Glide from Mikes transmission came with a adapter to use the 727 filter, I have change it several times since then and have had no issues with the tranny or filters No instructions as I didn't buy the tranny from him, it was in the car when I got it. Call him and ask about those questions at 661-723-0081 or who ever built your glide
[Re: 440Jim]
#2866165
12/29/20 07:28 PM
12/29/20 07:28 PM
Posts: 3,437 Dandridge TN
Dabee
Dandridge TN
Jim I used that kit on all the power glides I built. Never had a problem. If I remember correctly the adapter takes care of that hole.
[Re: Dabee]
#2866357
12/30/20 10:02 AM
12/30/20 10:02 AM
Posts: 16,928 NC
440Jim
NC
If I remember correctly the adapter takes care of that hole. There is no way the adapter in the TCI kit pictured covers that square hole, look at both pictures. It is nice to know the kit has no problems. Just wondering if that square hole is left open, something else is in the kit or instructions. Can anyone confirm, as somebody implied, the square hole is not used in PG's without the rear pump? Is covering it going to cause problems or does it need to be open to something? (standard filter or open to space).
[Re: 440Jim]
#2866368
12/30/20 10:20 AM
12/30/20 10:20 AM
Posts: 16,928 NC
440Jim
NC
Found this info on YellowBullet.com the smaller hole is a return from the pressure regulator... . I have a deep TCI pan with the factory style PG filter and extension. I switched over to the Chrysler filter and the new adapter only bolted to the larger port on the valve body. The small square port on the valve body was left open so I figured it was a return or bypass of some kind. I wanted to make sure before I filled it up with fluid.
This makes me think the square hole should NOT be blocked/covered. If it discharges fluid from the regulator, that might keep out any debris from wearing clutches, etc.
[Re: 440Jim]
#2866623
12/30/20 06:03 PM
12/30/20 06:03 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
Not much to add other than I went from the stock style PG filter with the extension for the deep pan to the same high flow Mopar filter with adapter extension you are talking about. You are right, that smaller square port is left uncovered. I changed nothing else at the time and it worked fine. This was with a stock GM valve body with a brake.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
