2016 Ram 2500 Suggestions for good limited slip differential #2865236
12/27/20 01:07 PM
12/27/20 01:07 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Well after driving in the first significant snow of the year and checking my truck’s options and window sticker I’ve come to the shocking realization that my 2016 2500 diesel Ram 4x4 has an open rear differential. down
The truck has about every possible option so I assumed it had a limited slip rear end.
I’m shocked they would even build a heavy duty diesel truck with an open rear diff but the truck is from down south so maybe it’s not that much of a priority.
Driving in the snow with an open diff is almost impossible in 2wd.
I believe my 2500 truck has the 11.5 rear end and I think the factory limited slip differentials are the helical type.
So I’m wondering if the factory type limited slip diff would be good enough for my needs or are there better options.
I have no desire to take the truck off road and don’t need any type of manually operated locker differential nor do I want a super heavy duty diff that pops and creeks going around corners.
I just need a decent limited slip differential that works good and is quiet.
Any suggestions would be appreciated.
Re: 2016 Ram 2500 Suggestions for good limited slip differential [Re: KillerBee] #2878816
01/23/21 11:25 AM
01/23/21 11:25 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
The factory limited slip should be perfect. I have one in my 18 and I have no complaints. Works great towing or off road.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: 2016 Ram 2500 Suggestions for good limited slip differential [Re: KillerBee] #2878845
01/23/21 12:26 PM
01/23/21 12:26 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Heard of that happening........there's no excuse for a dealer to miss that option on a four wheel drive. Sorry for your luck.
Mo' Farts
Moderated by "tbagger".
Re: 2016 Ram 2500 Suggestions for good limited slip differential [Re: Grizzly] #2879154
01/23/21 08:37 PM
01/23/21 08:37 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks guys, got a new Eaton Tru-trac installed, all is good. up
