Correct paint for 1970 Rallye center caps? #2863645
12/22/20 10:58 PM
12/22/20 10:58 PM
MN
JERICOGTX Offline OP
MN
Where can I get correct paint for refinishing a set of 1970 Rallye center caps?
Thanks.
69 GTX 68 Road Runner
Re: Correct paint for 1970 Rallye center caps? [Re: JERICOGTX] #2863676
12/23/20 12:14 AM
12/23/20 12:14 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I've had good luck with this place.
https://8774paint1.com/
inherited a 69 roadrunner from my grand pop.
Re: Correct paint for 1970 Rallye center caps? [Re: JERICOGTX] #2863787
12/23/20 09:22 AM
12/23/20 09:22 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I’d contact Mike and see if he has any material left before it’s all gone.
He did the center caps for my AAR and they are beautiful!
http://www.alltrim.com/inventory.html
Re: Correct paint for 1970 Rallye center caps? [Re: AAR#2] #2865294
12/27/20 03:28 PM
12/27/20 03:28 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I've had great success with Rustoleum Textured Metallic Silver paint......and it's available at Lowes and Home Depot.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Correct paint for 1970 Rallye center caps? [Re: JERICOGTX] #2865353
12/27/20 05:32 PM
12/27/20 05:32 PM
WV
Little Detroit Offline
WV
you cannot to the best of my knowledge get the correct paint for the center caps due the original formula was in lacquer by Ditzler (PPG) I do have the formula here somewhere and have a quart of it left and its not for sale , ,am trying to find some of the metallic and chems that maybe close as well as lacquer toners. you might be able to convert formula to base coat ith a matt clear coat.
Re: Correct paint for 1970 Rallye center caps? [Re: Little Detroit] #2870525
01/07/21 04:13 PM
01/07/21 04:13 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Try alltrim plus, he was selling his last stock of the original ppg a while back.
