Page 3 of 5 1 2 3 4 5
Re: 426 Hemi rebuild... [Re: INTMD8] #2862333
12/19/20 09:10 PM
12/19/20 09:10 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Went with Holley efi and flex fuel so will be running E85.
Because of that I ordered .027 Cometics and milled the heads for 12.4-1 compression.
Got the accessories figured out. Ported the intake and drilled the intake for rails (drilled the rails as well).
Re: 426 Hemi rebuild... [Re: INTMD8] #2862475
12/20/20 10:30 AM
12/20/20 10:30 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would still work outside if that was my garage (cleaner than my house) would be afraid of getting it dirty
Re: 426 Hemi rebuild... [Re: cudaman1969] #2862848
12/21/20 06:46 AM
12/21/20 06:46 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
That sure is some serious engine building. thumbs
Re: 426 Hemi rebuild... [Re: INTMD8] #2862915
12/21/20 12:48 PM
12/21/20 12:48 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Very nice, both the building and the hemi. I have racking over my tool boxes similar to you but some dummy (me) set that shelf too low and I bang my head on it when I look in the top of the box. Have to fix that before blood is shed. whiney
Re: 426 Hemi rebuild... [Re: GomangoCuda] #2862985
12/21/20 03:23 PM
12/21/20 03:23 PM
moparx Offline
moparx  Offline
and what fun would that be ? biggrin
my tool boxes are positioned similarly, and it's ALWAYS fun "rubbing" the hair [what's left] off the top of my head. laugh2
beer
Re: 426 Hemi rebuild... [Re: INTMD8] #2863030
12/21/20 05:07 PM
12/21/20 05:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Coming along very nicely up
What are the cam specs? Did you decide to go with pushrod oiling?
(won't be offended if you'd rather not say)
Rich H.
Esse Quam Videri
Re: 426 Hemi rebuild... [Re: ZIPPY] #2863035
12/21/20 05:33 PM
12/21/20 05:33 PM
Missouri
galen Online content
galen  Online Content
Missouri
I could not build oil pressure with the same Morels in my world block at full lift. Due to the lifter design with the side cutouts. It pushed oil out like a sprinkler at full lift prelubing with a drill., I could not see the cutouts but close enough to the top it caused issues.. You might check it if you haven't. It may have just been the machining on my block but a different lifter design fixed it. Just passing it on because yours looks like mine in the pictures. Nice build, appreciate you sharing it.. I am doing close to the same EFI on my 572 hemi using holley dominator ecu and smart coils. Galen
Re: 426 Hemi rebuild... [Re: galen] #2863169
12/21/20 11:15 PM
12/21/20 11:15 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys.
Before I ordered the cam I measured the reliefs in the oil galleries to decide base circle and lobe lift. With .428 lobe lift on the intake it's .100 away from uncovering the oil gallery on both the base circle and at peak lift. Lifters measure .9035-.9036. Lifter bores .9052.
I did prime it already and everything looks very nice. No problem getting oil up to the top and nothing appears to be a 'gusher'.
I am running pushrod oiling.
Cam Motion ground the cam. I asked for 268/268 @.050 on a 112 lsa. Bob ground it 262/262 @.050 as it's a low lash lobe (.010 hot) and he said that would be rather comparable to the 268 I wanted if it were a standard lash cam.
So it's 262/262 @.050 112lsa .428/.421. Measured .658/.612 at the valve. I installed it at 107 ICL. PSI 1575 springs (1.4" OD) with Xceldyne ti locks/retainers. Intake 245lbs at 1.83 on the seat, 613 open. Exhaust 256 at 1.81 on the seat, 598 open.
Galen I suspect you are running a bit more lobe lift than me. It would help if the lifter bores didn't have a huge chamfer on the top. Yours sounds like a nice build! I'm going to try Ford Coyote coils.
Re: 426 Hemi rebuild... [Re: INTMD8] #2863185
12/22/20 12:26 AM
12/22/20 12:26 AM
Missouri
Missouri
Good deal I'm glad you didnt have the same issue, I could not tell from the pics if yours was cut as deep as mine on top or not. I really liked the looks of the morel lifters . It was the world block , wedge head on my old 65 belvedere. They did get carried away on the countersink cut at the top of the lifter bore on mine. Lobe lift on that engine was in the .450+ range if I remember correctly. I just got the KB block back from machining for the hemi. I went ahead and had lifter bushings put in it with a .028 oil hole.. I have the same tone wheel, cam sync etc. that you have. I got everything from Rich Nedbal including two accufab throttle bodies. my intake is the stage V. I am still in the mock up stage though and quite a ways behind you., wiring, plumbing etc. I have a couple of cams I am going to try with the Efi I am putting in the 262/270@.050 Lift .710/.690 on 114lsa. Also have a 270/276@.050 .704/.690 on a 112lsa we may try down the road. My wife is in love with that Caddy by the way.
Re: 426 Hemi rebuild... [Re: INTMD8] #2863341
12/22/20 01:16 PM
12/22/20 01:16 PM
central il.
second 70 Offline
second 70  Offline
central il.
Dang my lifter's look short next to yours. If it hadn't been together for 10 years I would be scared they wouldn't work. Lol
Re: 426 Hemi rebuild... [Re: second 70] #2863425
12/22/20 03:55 PM
12/22/20 03:55 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Galen, I bought my parts from Rich as well. My vote would be for your 2nd cam considering your engine size. And thank you, the Cadillac is pretty beat up but it's a good old car.
second 70-
Not to far away from my cam! Events on mine are
IVO 24
IVC 58
EVO 68
EVC 14
Re: 426 Hemi rebuild... [Re: INTMD8] #2864501
12/24/20 09:33 PM
12/24/20 09:33 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I'm ready when you are to tune that SOB!
Great progress..I normally use the Crower Enduramax lifters that oil through the pushrod as well as high pressure to the roller. Never had one fail. Keep the pics coming.
Re: 426 Hemi rebuild... [Re: Mopar_Rich] #2924697
05/19/21 11:15 PM
05/19/21 11:15 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks Rich! Too many projects so working at a glacial pace....
Re: 426 Hemi rebuild... [Re: INTMD8] #2924704
05/19/21 11:32 PM
05/19/21 11:32 PM
Missouri
Missouri
Turning out really nice. anxious to hear how Rich's tuning goes. I'm plugging along but your glacial pace is making my pace look really slow.
Re: 426 Hemi rebuild... [Re: galen] #2924766
05/20/21 09:38 AM
05/20/21 09:38 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Very nice
2011 Drag Pak Challenger
Re: 426 Hemi rebuild... [Re: INTMD8] #2924768
05/20/21 09:42 AM
05/20/21 09:42 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice work with the coil mounting. clean! up up
What kind of coils are they?
Rich H.
Esse Quam Videri
Re: 426 Hemi rebuild... [Re: ZIPPY] #2924795
05/20/21 10:54 AM
05/20/21 10:54 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks guys!
The coils are Ford coyote.
Re: 426 Hemi rebuild... [Re: INTMD8] #2924873
05/20/21 02:35 PM
05/20/21 02:35 PM
moparx Offline
moparx  Offline
were any mods needed for the coil to the spark plug length ?
beer
Re: 426 Hemi rebuild... [Re: moparx] #2924898
05/20/21 03:20 PM
05/20/21 03:20 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Yes the boots have to be shortened a bit. I'll get you a measurement.
Re: 426 Hemi rebuild... [Re: INTMD8] #2924912
05/20/21 03:49 PM
05/20/21 03:49 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Is that a red Ferrari in the backround?
Jeez, a hemi AND a Ferrari, I feel so inadequate...LOL
Good for you!
Joe Latessa, yes, I'm Italian
