Removing poverty caps #2862486
12/20/20 11:10 AM
12/20/20 11:10 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I'm having trouble getting a dog dish hub cap off of an 8" wide wheel without scratching the wheel. I've thought about bending an angle into a flat screw driver and see how that goes. The wheel/tire combination makes it really hard to approach the hub cap from the side even with the longest screw driver.
Any suggestion?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Removing poverty caps [Re: cdstl] #2862487
12/20/20 11:14 AM
12/20/20 11:14 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
The subject has come up a few times before and there were several methods used by different members. I use a paint can lid removal tool with a little tape wrapped around the tab to remove my caps which works fine. They cost less than $2.
Re: Removing poverty caps [Re: cdstl] #2862500
12/20/20 12:51 PM
12/20/20 12:51 PM
Alberta
rustbuckett68 Offline
Alberta
Brake spoon. One end at ~90*, other at ~45*.
Re: Removing poverty caps [Re: rustbuckett68] #2862520
12/20/20 01:16 PM
12/20/20 01:16 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
A reg hub cap tool used at most all tire places, has a spoon end that’s bent to a 90 degree angle and a rubber hammer head to knock it back on
Re: Removing poverty caps [Re: cudaman1969] #2862558
12/20/20 02:44 PM
12/20/20 02:44 PM
iagree
The rubber end goes against the wheel to help pry the caps off without chipping the paint up scope
The only way to go up wrench
Re: Removing poverty caps [Re: cudaman1969] #2862559
12/20/20 02:49 PM
12/20/20 02:49 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Years ago member 340SIX(?) posted a picture of a small hole drilled on the back side of the hubcap that was out of view when installed. You were supposed to stick a small hook tool into the hole and use it to tug the hubcap off. I think it would work fine on a stainless cap, but not sure how an aluminum cap would hold up depending on how much force was required to pull it loose.
Re: Removing poverty caps [Re: Mastershake340] #2862635
12/20/20 05:57 PM
12/20/20 05:57 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Yeah, I’m sure that it has. I have several of those in my toolbox and never gave them a thought.
Re: Removing poverty caps [Re: cdstl] #2862730
12/20/20 09:27 PM
12/20/20 09:27 PM
GA
roadrunninMark Offline
GA
Plastic trim removal tool might work nicely as well. H.F. has a set for under 10 bux. I have this set and use it for quite a bit of things. https://www.harborfreight.com/trim-and-molding-tool-set-5-pc-64126.html
Re: Removing poverty caps [Re: cdstl] #2862736
12/20/20 09:34 PM
12/20/20 09:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've always used a brake spoon against an appropriately sized block of wood. beer
Re: Removing poverty caps [Re: TJP] #2862792
12/20/20 11:03 PM
12/20/20 11:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you use a ball peen hammer directly in the center they generally pop right off... hammer LOL
JB Rhinehart, Realist
A-Body's RULE!
Re: Removing poverty caps [Re: Rhinodart] #2862856
12/21/20 08:50 AM
12/21/20 08:50 AM
RWG75
RWG75
round end of a 12" prybar, shop rag between bar and rim.
Re: Removing poverty caps [Re: Rhinodart] #2862881
12/21/20 10:45 AM
12/21/20 10:45 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
10 pound sledge works for me
Abe Lincoln
Re: Removing poverty caps [Re: dart4forte] #2862884
12/21/20 10:56 AM
12/21/20 10:56 AM
fredericksburg,va
fredericksburg,va
Here’s the ultimate tool I talked about, MAC tool
Re: Removing poverty caps [Re: cudaman1969] #2862925
12/21/20 01:33 PM
12/21/20 01:33 PM
moparx Offline
moparx  Offline
i used to be able to just pull them off, but now my "slightly" older self lacks that capability............. laugh2
beer
Re: Removing poverty caps [Re: moparx] #2863147
12/21/20 10:12 PM
12/21/20 10:12 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If they are that tight coming off, when you put them back on, be sure the the bumps on the wheels match up with the dips in the caps, or you will bend the caps beating them back on! Gene
Re: Removing poverty caps [Re: poorboy] #2863409
12/22/20 03:32 PM
12/22/20 03:32 PM
moparx Offline
moparx  Offline
funny you should mention that ! whistling
i guess "massaging" a few caps back into [a semblance of] shape helps a guy remember certain things...........
beer
Re: Removing poverty caps [Re: moparx] #2863498
12/22/20 06:25 PM
12/22/20 06:25 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I like the larger one posted with rubber and partner shown above.
Restoring Stainless caps over the years has,shown a single hole drilled in them.
Not sure what year's did it but gave seen it on some and not other's.
I just know some have the hole and was,factory.
Here's a tool for single hole
VW did the same but 2 hole as well as other brands who did the same.
Just an example or two so you understand how easy it also works.
Have seen these for buck something the VW has 2 holes
Video of wire tool being used on a,VW
https://youtu.be/3OMqso7bOM8
Wire Tool
https://www.ebay.com/itm/263561492882
And a,Video we had a tool at the body shop we made like this too.
https://youtu.be/7PcmiL7AnMM
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Removing poverty caps [Re: 340SIX] #2863529
12/22/20 07:38 PM
12/22/20 07:38 PM
crlush Offline
crlush  Offline
I used an old screwdriver bent like a hook and polished the end so it wouldn't scratch the paint and put some shrink tubing on the shaft where you pry on the wheel.
Re: Removing poverty caps [Re: Neil] #2863826
12/23/20 10:49 AM
12/23/20 10:49 AM
340SIX Offline
340SIX  Offline
Not sure if it was my pic or not I take too many pics,or so i am told.
I personally think the ones produced for Ma Mopar had a hole for drainage.
It did work well with the wire tool.
But would only do so with Stainless Steel Caps.
The tried and true tool with black rubber and bent spade is the go to with a,towel or tape.
Re: Removing poverty caps [Re: 340SIX] #2863855
12/23/20 11:52 AM
12/23/20 11:52 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think the hubcap picture you put on here years ago was not yours, but it did show the small hole on the outside edge for the hook tool to go into.
