Thoughts on using 2 solid motor mounts instead of plate #2862313
12/19/20 08:37 PM
12/19/20 08:37 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
I know its semi regular question .
I have my street/strip satellite with a 505 World iron block .
I use mity mounts and a solid torque strap .
Will solids affect the block ? Is this hearsay or not ?
I noticed the eng mounts run a cross bolt way smaller then hole in k frame . With cross bolt loose i could raise motor enough to fit 5mm wheel align shims (right side ) between mount and frame pedastal . . Schumachers run a larger cross bolt , 1/2" ?
At this point it wont get a plate , not sure i am ready for that plus it is tight for room between rad and motor/ fans .
I did have fan eat the radiator 2 weeks ago at the strip after lifting . Mounts are not broken , it looks like r/h side of motor may lifted just enough for clutch fan to clip shroud and that was end of that .
I have run the same fan/radiator for about 10 years . I had Mopar performance fan and a AFCO radiator .
I have another AFCO rad and a shorter hub clutch fan . Plus i may upgrade to the 1990s and try Aust Ford Falcon twin elec fans
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: tex013] #2862356
12/19/20 10:46 PM
12/19/20 10:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Do you have anything (usually a strut) that limits fore/aft travel ?
You're running rubber engine & trans mounts ?
Generally a torque strap only limits rotational travel.
My drag car's used solid R&L engine mounts and a rubber trans mount for decades, with either a 340 or (currently) R1 block.
It has an electric fan for post-run cooling with engine off.
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: topside] #2862375
12/19/20 11:38 PM
12/19/20 11:38 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Topside ,
Mounts are rubber but have bolt through them , must move more than the old schumakers i ran . . I had thought of fore/aft limiter . That will be this weeks job . Along with fitting new rad . I wiil fit from cross member to trans ear at rear r/hand side , seems easiest . Will measure it up tomorrow on the hoist .
I do run a transbrake leaving @ 4500 . And being in Aust means no ready available solid mounts , unless i made some .
Vibrations arent a worry
Tex
New best MPH 130.32
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: tex013] #2862384
12/20/20 12:15 AM
12/20/20 12:15 AM
st.louis,mo.
dart games Online content
dart games  Online Content
st.louis,mo.
i i used 2 solid motor mounts in the early 80s,shook my teeth out,leave the stock one one the pass side,or just get a engine limiter,make one or buy on from mancini
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: dart games] #2862427
12/20/20 05:26 AM
12/20/20 05:26 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I run solid mounts both sides on my roadrunner. It’s a street car. No issues, works well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: 68 HEMI GTS] #2862449
12/20/20 08:30 AM
12/20/20 08:30 AM
UK
rb446 Offline
rb446  Offline
UK
Same here with our street/strip RR with mega block motor...no probs.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: rb446] #2862453
12/20/20 08:40 AM
12/20/20 08:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My sons turbo car with a brake runs a solid left mount. The right mount is stock. Runs a brake, pro bracket M/Ts, and weighs 3775. Been that way since it was built.
Doug
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: dvw] #2862457
12/20/20 08:58 AM
12/20/20 08:58 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
JFI. You will have to remove the D/S motor mount if you ever go to a dual line oiling system though (at least on an E body you will)
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: Tig] #2862472
12/20/20 10:20 AM
12/20/20 10:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Not if you use the correct pump cover !!
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: Stanton] #2862473
12/20/20 10:27 AM
12/20/20 10:27 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted by Stanton
Quote
Hmm... there was no way it would work with a KB block and the Milodon sandwich plate on my car (74 Ebody) stock pump or any of the Milodon covers including billet ones. I even had to cut into the steering box bracket, it was the same on the QA1 tubular K member too. I might have got away with it using the Indy block as it has a built in dual line provision but it was already gone.
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: Tig] #2862483
12/20/20 10:47 AM
12/20/20 10:47 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run a solid mount on the drivers side. You can't tell anything is different from the rubber type.
Member farmboy made them for the '63 and after they were painted black they look stock.
He made both sides but I only used the drivers side.
'63 Dodge 330
11.19 @ 121 mph
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: GY3] #2862530
12/20/20 01:42 PM
12/20/20 01:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I use drivers side solid, passenger side stock rubber. Works good with one side note: the small movement that the rubber mount allows causes the solid to loosen slightly over time @ the main stud nut. I’m currently toying with the idea of adding a solid to the pass side simply to stop that issue, simply because it’s a pain to get a wrench to that bolt with my headers. The way it is now, you hardly notice any vibration at all. My car is a fairly mild street / strip deal, not as raucous as most guys here. I use the Moroso steel mounts.
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: StealthWedge67] #2862598
12/20/20 04:32 PM
12/20/20 04:32 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
ok thanks guys .
i really like simple , so i will chase solid mounts . Have to wait till i order something from the USA .
In the meantime i will make a limiter .
I am hoping to race Jan 8 BUT ........
Tex
New best MPH 130.32
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: tex013] #2862738
12/20/20 09:36 PM
12/20/20 09:36 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I bought a VE valiant years ago that had been raced quite a bit through its life, along with being street driven. I think it was a B/Street car back in the day. Anyway, whomever built the car, took a pair of the factory rubber isolators and welded some steel plates to the sides to make them solid. No idea how long they were in there for, but it looked like a while. Might be an option to try if you've got some mounts lying around.
I didn't notice the engines mounts causing vibration, the rear ladder bar set up this car had made enough noise and vibration, I didn't notice.
Alan Jones
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: LA360] #2862780
12/20/20 10:27 PM
12/20/20 10:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My suggestion is to use both solid mounts, and be sure to retain the isolated trans mount. Don’t solid mount all three.
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: TRENDZ] #2862828
12/21/20 01:03 AM
12/21/20 01:03 AM
iagree up
I've had two Dusters, one race car and one street and strip car, with Elephant ears for the front mounts and a stock tranny mount, worked good, lasted a long time up
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: Cab_Burge] #2862975
12/21/20 03:10 PM
12/21/20 03:10 PM
moparx Offline
moparx  Offline
with ears or a front plate, make sure you use a fore/aft limiter of some kind.
that keeps the front of the engine from doing bad things to the radiator or electric puller fan.
the engine/transmission combo moves around more than you think when using a plate style front mount.
beer
Re: Thoughts on using 2 solid motor mounts instead of plate [Re: tex013] #2863000
12/21/20 04:02 PM
12/21/20 04:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I just changed over to the Mity Mounts from solids on both sides. Haven't been to the track yet, but there is a definite difference in the vibrations in the car. My car, being a stick car, I'm concerned with how long these mounts will hold up. I broke many stock mounts with a turnbuckles in the past. I do most of my driving on the street, but love to run the car occasionally at the track. No turn buckle so far. May do that if required later on, we'll see??? I actually fabricated a stock mount to look like the driverside Mity Mount. So I have two driverside mounts on the car. Why? I actually torn the "K" member passenger side engine mount plate from the "K" member. I've re-welded it with additional support so it won't happen again.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
