Stock 727 planetary with transbrake? #2862028
12/19/20 02:16 AM
12/19/20 02:16 AM
California
70Drop Offline OP
70Drop  Offline OP
California
I just put a transbrake in the 727 I have in my Duster. The car weighs about 3300 lbs. at the starting line. It runs mid-10's. It's a 500-inch big-block making about 600 hp. 4.10 gears, 4000 converter flash.
I haven't taken the car out yet, and I read some info about stock aluminum planetaries being questionable with a brake. I wouldn't want to take the car to the track and strip out the planetary splines. The rest of the trans has been well upgraded with a billet steel front drum and 16-element sprag. Is the risk I'm taking worth the cost and trouble of putting in a steel planetary at this point?
Re: Stock 727 planetary with transbrake? [Re: 70Drop] #2862045
12/19/20 07:03 AM
12/19/20 07:03 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
If it were me, I'd do it now. "Peace of mind", "done before it takes out other stuff with it", "ready for more motor" etc etc.
Re: Stock 727 planetary with transbrake? [Re: Tig] #2862059
12/19/20 09:17 AM
12/19/20 09:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it strips it won’t take anything out. Probably not a bad idea to go steel carrier. We’ve stated to twist the splines out of them. Always caught during inspections. For sure you can put a lot of power thru the stock carrier on a foot brake leaving hard. 1.2x 60ft 3350-3550.
Doug
Re: Stock 727 planetary with transbrake? [Re: dvw] #2862065
12/19/20 10:03 AM
12/19/20 10:03 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Doug
I had aluminium run through the 'box, cooler and lines after stripping one. It's just a PITA to clean out and my OCD had me freshen the 'box at the same.
Re: Stock 727 planetary with transbrake? [Re: 70Drop] #2862066
12/19/20 10:03 AM
12/19/20 10:03 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v change from a 3 planet to a 4 planet with alumina carrier and had no problem (1.27-130 60') with 4.56's 3350lbs.....I'm also looking to upgrade to a steel planet /277 1.st gear.
Re: Stock 727 planetary with transbrake? [Re: racerx] #2862068
12/19/20 10:13 AM
12/19/20 10:13 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
6 pin comes in the Cummins trans that fits the 727. They cost under $50. Years back I bought the A&A 4 pinion for $500 after wiping out the aluminum!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stock 727 planetary with transbrake? [Re: hemi-itis] #2862072
12/19/20 10:29 AM
12/19/20 10:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Hemi-itis.....is those 6-pin planets in the cummings steel or aluminum?
Re: Stock 727 planetary with transbrake? [Re: dvw] #2862077
12/19/20 10:46 AM
12/19/20 10:46 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Doug
I stripped one out shifting into 2nd and it was like missing a shift with a manual car. Engine instantly over revved. It may not hurt the tranny, but it could hurt the motor.
Re: Stock 727 planetary with transbrake? [Re: PolyDart] #2862096
12/19/20 11:46 AM
12/19/20 11:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Cummins planet is steel. But your output shaft has to have the correct spline angle to work. The amount of aluminum that came of the the ones we've hurt was gradual. Never saw much shrapnel. Over rev? A race car without a top end rpm limiter?
Doug
Re: Stock 727 planetary with transbrake? [Re: PolyDart] #2862122
12/19/20 12:49 PM
12/19/20 12:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When starting out in 1st, brake or not, both planetaries are sharing the load. but. When shifted to 2nd, the front planetary absorbs the load, so that's the common failure mode.
Re: Stock 727 planetary with transbrake? [Re: dvw] #2862311
12/19/20 08:30 PM
12/19/20 08:30 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs DVW up
Re: Stock 727 planetary with transbrake? [Re: John_Kunkel] #2862400
12/20/20 01:10 AM
12/20/20 01:10 AM
California
70Drop Offline OP
70Drop  Offline OP
California
Very interesting. Puts it into perspective. I've got probably 80 passes on the car, shifted into 2nd gear on every one of them, lol. I'll be sure to inspect carefully next time I take the trans apart, but I think I'll leave it for now
Re: Stock 727 planetary with transbrake? [Re: dvw] #2862403
12/20/20 01:17 AM
12/20/20 01:17 AM
California
70Drop Offline OP
70Drop  Offline OP
California
Doug
Do you know how I would check for the correct spline type for the Cummins planetary? I know there are early and late shafts, mine is the later (bigger) type.
Re: Stock 727 planetary with transbrake? [Re: 70Drop] #2862882
12/21/20 10:54 AM
12/21/20 10:54 AM
hemi-itis Offline
hemi-itis  Offline
I am no expert by any means,,,,,,but I think the 66 to 71 spline is the same work I wiped 2 aluminum sets foot braking off the line with 800 + HP @ 3900#
Re: Stock 727 planetary with transbrake? [Re: hemi-itis] #2862954
12/21/20 02:25 PM
12/21/20 02:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The output shaft spline included angles are as follows:
'62-'75= 90°
'76-'93= 75°
'94-on= 60°
Re: Stock 727 planetary with transbrake? [Re: John_Kunkel] #2862991
12/21/20 03:30 PM
12/21/20 03:30 PM
moparx Offline
moparx  Offline
so 94 on output shaft to use the 6 pinion planetaries ?
beer
Re: Stock 727 planetary with transbrake? [Re: dvw] #2863066
12/21/20 06:46 PM
12/21/20 06:46 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Doug
It happened on the street, actually getting onto I-10 after a car show. The car has a limiter, but it still redlined with no load which never feels good.
Re: Stock 727 planetary with transbrake? [Re: PolyDart] #2863188
12/22/20 12:53 AM
12/22/20 12:53 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Doug
It's called inertia. If the engine is under load at say 6500 and the load instantly goes away, the inertia of the crank and everything turning with it can accelerate it well past its redline, if only briefly.
A rev limiter will have zero control of that.
Kevin
Re: Stock 727 planetary with transbrake? [Re: Twostick] #2863225
12/22/20 08:28 AM
12/22/20 08:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Kevin
Zero control? So you don’t use one?
Doug
Re: Stock 727 planetary with transbrake? [Re: dvw] #2863314
12/22/20 12:35 PM
12/22/20 12:35 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Doug
Kevin
Doug
I don't currently have anything that requires one.
My point is if you lose the overrunning clutch anywhere towards the top of the RPM range, inertia can accelerate the engine past its redline regardless of any rev limiter.
Kevin
