Page 2 of 8 1 2 3 4 5 6 7 8
Re: Mancini Selling Callies Blocks [Re: 440Jim] #2861223
12/17/20 11:33 AM
12/17/20 11:33 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Another nice thing about the powerglide aftermarket cases is they are SFI and no shields required. Aftermarket drums are cheap and my ATI case has a safety liner as added protection inside the case wrapped around the drum.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mancini Selling Callies Blocks [Re: 440Jim] #2861269
12/17/20 12:44 PM
12/17/20 12:44 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by 440Jim
Originally Posted by pittsburghracer
The dual Mopar powerglide pattern isn’t that big of a deal now. ATI and others offer some great products and in seconds you can switch your ATI case to powerglide, small block Mopar, or big block Mopar. If you are building any power you are pushing a stock 50 year old powerglide case so why not build some safety into your race program.
The safety shields for the PG have been around longer then I can remember.
I was going to use a stock case PG in my Daytona since it came with the TCI adapter midplate. But a previous owner cut the midplate out around the starter so it had no starter studs. So I had to buy a JW SFI bellhousing and cut the stock bellhousing off the PG.
The builder of the chassis even has a steel band welded around the flexplate area for added protection. But without an SFI tag, it is just added safety; an SFI flexplate shield is still required. (JW meets this)
Jim/anyone...Would you mind taking a pic of the UPPER LEFT DRIVERS SIDE metal bracket (what it looks like and where it bolts to) which mounts the shield to the case? For some reason my used shield didn't get assembled with this bracket. TIA!!!
Re: Mancini Selling Callies Blocks [Re: an8sec70cuda] #2861346
12/17/20 03:29 PM
12/17/20 03:29 PM
Texas
Chief Offline
Chief  Offline
Texas
iagree Having dual bolt patterns on the block is just adding unneeded complexity IMO. Everything needed to put a glide behind a stock style Mopar block is a phone call away.
I understand what you are saying, But, if you are at a multiday race and blow the tranny, with a dual pattern you could conceivably borrow your buddies chevy reid cased transmission and be back in the race..
Just thought I'd interject that thought.
Dave Covey
Re: Mancini Selling Callies Blocks [Re: Chief] #2862532
12/20/20 01:48 PM
12/20/20 01:48 PM
Houston, Texas
FastOrange Offline
FastOrange  Offline
Houston, Texas
INDY Cylinder Heads has the blocks listed on their website.
$3800 Smakaroos.
http://indyheads.com/images/price.2015.09.pdf
Re: Mancini Selling Callies Blocks [Re: FastOrange] #2862615
12/20/20 05:14 PM
12/20/20 05:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That’s from 2015
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2862665
12/20/20 06:50 PM
12/20/20 06:50 PM
A727Tflite Offline
A727Tflite  Offline
Read the bottom of the flyer - date effective 11/2020.
Re: Mancini Selling Callies Blocks [Re: A727Tflite] #2862683
12/20/20 07:53 PM
12/20/20 07:53 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
That listing is for a Mopar Performance block not a Callies. While similar, not the same thing. Indy will most likely sell them but not at that price. Kenny already has one ready to hit the dyno as of last week.
Todd
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2862692
12/20/20 08:20 PM
12/20/20 08:20 PM
A727Tflite Offline
A727Tflite  Offline
Todd
Why does it say Mopar/Callie’s then ?
Re: Mancini Selling Callies Blocks [Re: A727Tflite] #2862731
12/20/20 09:28 PM
12/20/20 09:28 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Exactly!
Callies was not making hemi blocks back then and the listing definitely says callies 👍
Re: Mancini Selling Callies Blocks [Re: Suregrip391] #2862819
12/21/20 12:21 AM
12/21/20 12:21 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You are correct sir it does indeed say that. The page format is the same as it has been for years. It does look updated recently over our most recent price sheets. AS of last Monday the Callies folks have not even finalized the dealer pricing as some recent tooling changes was changing the price of poker. Call them up and see if they will sell you one for that
317-862-3724 Indy
937-708-8563 New Indy in Ohio
Re: Mancini Selling Callies Blocks [Re: sasquatch] #2863515
12/22/20 06:57 PM
12/22/20 06:57 PM
Houston, Texas
FastOrange Offline
FastOrange  Offline
Houston, Texas
On that note......Promises and a back order slip can be truly disappointing. I guess we will just have to hurry up and wait some more. Glad to hear it's on the way though
Re: Mancini Selling Callies Blocks [Re: FastOrange] #2863525
12/22/20 07:25 PM
12/22/20 07:25 PM
So. Burlington, Vt.
So. Burlington, Vt.
I looked at the Indy link....... all the new iron block prices have a * next to them.
I didn’t see where it said what that referred to........ but I suspect it has something to do with people not actually being to buy them for $3800 when they’re finally “available”.
Edit- just looked again...... it appears there has been an update to the pricing......
The last two lines are the Callie’s blocks.
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2863579
12/22/20 09:11 PM
12/22/20 09:11 PM
A727Tflite Offline
A727Tflite  Offline
Someone is playing games or isn’t very proficient in updating the info. I just clicked on the link and now it says 6/2015 update.
Re: Mancini Selling Callies Blocks [Re: A727Tflite] #2863691
12/23/20 12:43 AM
12/23/20 12:43 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Mancini shows them unboxing a Hemi block on Facebook today but still won't give a definitive answer on price!
'63 Dodge 330
11.19 @ 121 mph
Re: Mancini Selling Callies Blocks [Re: GY3] #2863784
12/23/20 09:14 AM
12/23/20 09:14 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I talked to Indy and they were just Mid Edit, they now say 4800. You might be looking at an old cookie. Next time you go on Indies web site hit your F5 button and it will refresh it to the most current version. I am not sure that Callies has even given out final pricing yet.
Todd
Re: Mancini Selling Callies Blocks [Re: A727Tflite] #2863842
12/23/20 11:20 AM
12/23/20 11:20 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Yeah, but it also says they will sell you an R3 48* block. whistling
Re: Mancini Selling Callies Blocks [Re: usp4u] #2863854
12/23/20 11:51 AM
12/23/20 11:51 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
They might be able to didn't they have a ton of them at one time?
Re: Mancini Selling Callies Blocks [Re: 340Cuda] #2863857
12/23/20 11:54 AM
12/23/20 11:54 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mancini social media pix
Rich H.
Esse Quam Videri
Re: Mancini Selling Callies Blocks [Re: ZIPPY] #2863862
12/23/20 12:04 PM
12/23/20 12:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
I wonder who will end up owning that one. up
Re: Mancini Selling Callies Blocks [Re: fast68plymouth] #2864405
12/24/20 05:00 PM
12/24/20 05:00 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
So the price is being released all over Facebook today as being $4800.00 through Mancini.
Does anyone else find the "Mopar Tax" ridiculous?!
A Dart Big M BBC retails for $2500.
I get that the demand and sales will never be what it is for a BBC but DOUBLE the price of admission for a decent Mopar block?! flame
'63 Dodge 330
11.19 @ 121 mph
